Originally Posted by eld4au6
ok here are the pics, i think i may just vampire clip the 8-pin plug to the hu wiring adaptor to the right pulgs so if i want to put the stocker back in all i have to do is remove the clips and plug it back up. Please help me as i will be installing the Head Unit tomorrow
Wow, I didn't mean for you to pull the entire harness out of the car, but thanks -- those pictures (and the daylight) really helped.
So the right rear speaker output from the radio goes to the right input on the subwoofer (white and black wires), just like with the "old style" subwoofer harness.
The only thing different about this "newer style" harness is that they use the radio's 8-pin subwoofer jack for the left input on the subwoofer (violet and orange wires) instead of the left rear speaker output from the radio.
So yes, clamp a "vampire" tap on the
Violet wire near the square 8-pin subwoofer plug and bridge over to the Left Rear + wire going between the 14-pin forward and reverse harnesses (
Pin 5 -- should also be Violet).
Add a vampire tap to the
Orange wire near the square subwoofer plug and bridge to the Left Rear ***8211; (negative) wire (
Pin 13 -- should also be Orange).
Do not splice anything into the short gray loop wire on square 8-pin plug.
Check the
pin-out to verify.
Go by pin number position, as the camera may have altered the colors in the pictures a little (and Subaru may change the wire colors on different harnesses).
Annotated picture (click for full-size image):
(original unannotated picture was taken by WolfPlayer)
(If you followed a link from another thread and you're seeing this post by itself, be sure to see the pictures in post 18 and addional notes in post 21 in this thread too -- click on the "Thread" link at the upper-right corner to be able to see the whole thread).
