Welcome to the North American Subaru Impreza Owners Club Wednesday October 5, 2022
Old 05-02-2006, 12:27 AM   #126
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2017 BMW X5
Originally Posted by jblaine
NEW: ...oooooooooooooooOoo.......
OLD: ...oooooooooooooooooo.......
. = 13psi
o = 17psi
O = 19psi
SWEETNESS.
<sells 16g>
LOL
cdvma is offline   Reply With Quote
Old 05-02-2006, 12:36 AM   #127
hotrod
Member#: 14141
2002 Impreza WRX
awesome....i don't understand how to read compressor maps
If you want to learn about compressor maps you should read through this FAQ and the links on compressor maps.
http://forums.nasioc.com/forums/show....php?t=555332&
Larry
hotrod is offline   Reply With Quote
Old 05-02-2006, 12:45 AM   #128
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
So what kinda of numbers are tuners getting with the stock turbo on an EJ20 running 18+ psi of boost?
djerickd is offline   Reply With Quote
Old 05-02-2006, 01:05 AM   #129
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2017 BMW X5
Probably about 220 to 230 whp with tapering off boost.
Old 05-02-2006, 07:43 AM   #130
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
wow I was hoping for over 250, I made 217whp on a dynojet with 16.5psi.
Old 05-02-2006, 12:03 PM   #131
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
i ran 24+ psi for 6 months on the stocker untuned trapped around 103
SubasaurusWrex is offline   Reply With Quote
Old 05-02-2006, 01:14 PM   #132
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
seriously?
Old 05-02-2006, 01:58 PM   #133
motohead125
Member#: 79622
04 WRX STI
Java Black Pearl
Ok all this talk about the stock turbo holding boost at x psi...and being ok. At what point does x psi start to damage the actual engine?
motohead125 is offline   Reply With Quote
Old 05-02-2006, 02:21 PM   #134
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it doesn't work that way.
Old 05-02-2006, 03:36 PM   #135
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
Could you elaborate?
mneste8718 is offline   Reply With Quote
Old 05-02-2006, 04:33 PM   #136
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default ride5000's take on tuning...
there is no "safe" psi and there is no "unsafe" psi.
with a good tune and a turbo up to the task, ej205s have produced more than double factory power output... ~400whp.
ime what kills 80% of motors is det, plain and simple. the remaining 20% is made up of lubrication issues, honest overpowering (ie rods), and old age/wear and tear.
so if you keep the det away, your engine will be happy, and it will last quite a long time.
let's look at what happens with big boost (ie, overboosting) numbers...
1) turn up the boost.
2) compressor efficiency drops off. (notice i did not say "becomes inefficient/a hairdryer/a flamethrower." efficiency is a point on a continuum, it's not a binary on/off thing.)
3) as efficiency drops off, comp. discharge temp goes up.
4) undersized ic becomes overheated.
5) manifold charge air temps go up.
6) hot charge is more prone to detonate.
7) detonation causes spun bearings, snapped rods, cracked ringlands, etc.
interrupt this sequence at any one of the above steps and you stop it in its tracks. reduce the severity of any of the above characteristics and you increase the reliability of the system.
i can cause detonation with:
stock boost/fuel and too much advance.
or stock boost/advance and not enough fuel.
or stock advance/fuel and too much boost.
are there downsides to attempting to maximize one parameter at the expense of another? absolutely.
if you go for high boost, then you will increase lag. if the turbo has a higher pressure level to shoot for, then by definition it will take longer to get there. it will also probably overspin the turbo decreasing its lifespan. as stated earlier, you're also increasing charge air temps and therefore the combustion process is more likely to run away on you and det.
if you go for lean afrs, then you will increase EGTs. used to be around here 1600 was holy crap hot. as time went on, and more and more engines seemed to be lasting at that level, it was pushed to 1650. then even 1700. i don't watch my egt gauge when i do a highway pull, but i know it's hot. off the 1600* scale. by that time, i'm shutting it down anyway. if you're tuning a road racing track car, then you run it much richer so that you can keep things cool. waste of gas, throw away some power, get some longevity.
if you go for greatly advanced timing, it can be a wonderful thing... because it's "free." you don't really throw anything away when you bump things up a degree.. in fact, it buys you lower egts and more torque. but what you DO throw away is your knock margin. that's how much wiggle room you've got for a bad tank of gas, a heatsoaked intercooler, more load on the engine due to cargo, hills, gear selection, etc. your knock detection/control system is put more on the spot, and it'd better be up to the task. but as clark turner once said, remember one thing: timing is not a volume knob for power. on pump gas, we're generally octane limited, and more advance does get you some torque, but it also greatly increases the peak cylinder pressures. the crank is fewer degrees ATDC by the time the charge really starts lighting off. that means those chamber pressures go way up. so does torque, which is great, but peak pressures are very hard on the pistons/rods. in an extreme example, knock is really really high peak cylinder pressure. what you really want for big power output is greater MEAN cylinder pressures (hint: cramming air mass into the chamber is a great way to get more mean pressure).
by the time i pulled out the td04 i was running 20psi in the winter, and 18-19psi in the summer. i crept up to those levels slowly, and i never got greedy with timing. i had a wideband that i constantly monitored. i had a set of detcans with which i set my knock thresholds for more accurate knock detection. i had tens of thousands of lines of datalogs and i made small changes between pulls. i took my time and tried to be as patient as i could be. could i have run more boost? sure. would i be running more boost now if i kept it on the car? yeah, i'm pretty sure i would be!
in fact, looking at the vf23 maps i have in my utec now, they aren't that different from before i swapped turbos. i run about the same afrs, with the same advance, and about the same boost levels. the car is a LOT faster than it was with the td04. why? because it's pumping a lot more air. i could barely eek out a 4.4 mafv on the td04 on a very cold day. now i regularly pull 4.6 mafv. 4.4mafv = 237.87g/s = 31.47lb/min, 4.6mafv = 274.75g/s = 36.35lb/min. that's 50hp worth of air.
basically i kept turning up the boost until i had to drop too much timing to get things quiet and stable. i set myself a rule that i would not drop below 14* advance at torque peak. i didn't read that anywhere, it's just a metric that i determined for myself, since each car kind of has their own personality. i noticed that the car was not faster if i turned up the boost so much that i had to run 14 or less degrees at torque peak. i also made sure that when i added boost it resulted in a corresponding increase in mass air flow. without the added flow, boost is giving you NOTHING but hot charge, and high exhaust gas backpressure.
ahh, backpressure. a big result of quick spooling turbines. the bane of the td04. high backpressure ends up causing exhaust gas recirculation since the piston is not able to evacuate the chamber as effectively. now, here's a little sticking point--egr caused by egbp will increase your knock buffer. your engine will tolerate more advance before knock. this is why the oem wrx maps have such high (like 30* or more) advance at redline... the little turbine is choking exhaust flow. are you making more power with this additional advance? no. your decreased VE is forcing you to use more advance to get any decent torque output. the charge air is diluted, the airmass in the chamber is low, and there's all this spent gas left behind.
as VE increases, the advance necessary to develop minimum best timing decreases. the charge in the chamber is dense, the molecules are tightly packed in with one another, and the speed of flame front propigation is high. not only do you NEED less advance, but the engine will TOLERATE less advance before it knocks. look at the timing the "big turbo" guys run at redline... much less than the oem wrx maps do. again, does it mean less torque? you be the judge of that.
so i didn't intend this to be a dissertation, but it has kind of turned into one. the bottom line is that there is more than one way to skin a cat, and you've got to take in as much of the system as a whole as you can. ie, if you're running your injectors static at 19psi in the summer, and your afrs are already at 11.5:1, and you run 93 octane, you don't have a whole lot of fuel headroom... you've reached the limit of the fuel system. come winter when that turbo starts compressing better and the ic starts cooling better and you pump more air, you're gonna drift lean. so you might dial back the boost, pump a little less air, and run greater advance. OR you might go in another direction and lean it out even more to 12:1, get back 10% idc, keep boost the same and knock a degree of advance off. or, as another example, you crank up the boost to 20psi, and you find that you're not actually getting much more MAF. you've reached the limit of the turbo, and less boost/more timing OR less boost/leaner afrs are better tacks.
any of those solutions are PERFECTLY ACCEPTABLE and are all part of the inherent trading off process that tuning engines involves.
Old 05-02-2006, 04:44 PM   #137
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
"This one goes to 11..."
jblaine is offline   Reply With Quote
Old 05-02-2006, 04:46 PM   #138
dru_hill
Member#: 67661
2004 WRX sedan
^^ This is good stuff, read and understand it and you will learn something about tuning, and how engines make power.
edit: The volume knobs with "11" on them will not teach you anything about engines.
dru_hill is offline   Reply With Quote
Old 05-02-2006, 04:50 PM   #139
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
Well said.
Sometimes I really wish I had a better laptop + streettuner + supporting monitoring systems.
wall of tvs is offline   Reply With Quote
Old 05-02-2006, 05:18 PM   #140
mneste8718
Member#: 51562
2004 WRX Sedan PSM
Originally Posted by wall of tvs
Well said.
Then also I would like to be able to create a program which will control streettuner so that everything will change dynamically with the weather and such. Make it depend on the MAF voltage and AFRs... Its not that tough in theory heh, but thats about it. It would pretty much tune your car continuously for maximum efficiency.
Old 05-02-2006, 05:20 PM   #141
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
About backpressure with stock TD04L: can "monster" porting the exhaust housing really help? Or physically is it too small?
Old 05-02-2006, 07:35 PM   #142
xFactor
Member#: 65470
02 Hong Norr Wrx
rock chip red
What Ride5000 said should be considered gospel...
later, x
xFactor is offline   Reply With Quote
Old 05-02-2006, 11:23 PM   #143
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks for sharing, ride. Good info.
WRXRallyBlue is offline   Reply With Quote
Old 05-03-2006, 12:54 AM   #144
motohead125
Member#: 79622
04 WRX STI
Java Black Pearl
Very informative. Appreciate it much. Now i know that if anything will blow up on this car it will either a. be the turbo or b. be the transmission. This thread should be stickied just for your write up.
Old 05-03-2006, 08:43 AM   #145
qoncept
Member#: 44762
2013 BRZ
The backpressure isn't from the housing, it's the turbine wheel. Only way to get rid of it would be to clip it.
qoncept is offline   Reply With Quote
Old 05-03-2006, 08:50 AM   #146
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Ahh thank you
Old 05-03-2006, 09:17 AM   #147
TheMadScientist
Member#: 23717
2005 Big red
IMO it is a combinition of the two. A 5cm housing will have more EGBP than an 8cm. Same with the wheels an 04 wheel will have more EGBP than an 06 one. Mixxing a matching the two can give EGBP between the "normal" setups.
ie. 04 wheel in a 7cm housing will have less EGBP than the 04 wheel in a 5cm housing.
TMS
TheMadScientist is offline   Reply With Quote
Old 05-03-2006, 09:23 AM   #148
qoncept
Member#: 44762
2013 BRZ
Oh... So, could you port the stock housing all the way up to the wheel? Increase spool time a bit as gasses escape around it but let it breathe at higher rpms?
Old 05-03-2006, 09:30 AM   #149
TheMadScientist
Member#: 23717
2005 Big red
Porting is NOT going to make a real big difference in the mass flow of the housing. Mostly porting is to improve the spool of the turbo.
TMS
Old 05-03-2006, 09:37 AM   #150
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
TMS
i would agree.
look at the vf series, and how they mix and match exhaust housings.
or how the rotated mount garrett boys put on .63, .82, 1.06 a/r housings on the same chra to tailor the low end response vs. high end power.
Turbo Compressor maps DoucheAlmighty Newbies & FAQs 2 05-08-2008 06:07 AM
Blouch Dom-II turbo compressor map? veightkiller Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-07-2007 03:51 PM
HKS GT Turbo Compressor Maps? wlelandj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-26-2002 09:36 AM
PE turbo compressor maps... nmyeti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-28-2001 05:37 PM
14B turbo compressor maps? efoo New England Impreza Club Forum -- NESIC 1 05-03-2000 03:27 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
