Welcome to the North American Subaru Impreza Owners Club Monday February 17, 2020
Old 06-22-2007, 05:06 PM   #1
RobK0000
Member#: 62230
I started making this lip last Wednesday, it ~22 hours to make, I already finished the lip and thought I would share to you the steps it took to make this real.
Foam Lip after sanding:
Taped up with masking tape:
Hers what is looked like after the glassing?
RobK0000 is offline   Reply With Quote
Old 06-22-2007, 05:06 PM   #2
RobK0000
Member#: 62230
During Bondo Stage:
Dark picture, after primer:
After the CF materials and Clear coat, Also final mounting:
Good luck feels free to ask questions!
Rob K.
Old 06-22-2007, 05:14 PM   #3
yoshi8me
Member#: 72629
Too Low for
Nasioc MBR#014
looks good!
yoshi8me is offline   Reply With Quote
Old 06-22-2007, 05:15 PM   #4
Mechie3
Member#: 120152
That looks like crap. You should immediately toss it in the garbage can pictured and place it at the curb. (oh, and send me your address and the day you put it at the curb....wait, this won't fit my car....snap!)
When's the group buy start?
Old 06-22-2007, 05:19 PM   #5
lethal.adv
Member#: 95652
'12 Outback 2.5i
damn i would have had an awesome installgasm if i did that
nice work!
lethal.adv is offline   Reply With Quote
Old 06-22-2007, 05:27 PM   #6
legacy2003
Member#: 38338
2003 Outback Sdn H6
nice man! looks awesome!
legacy2003 is offline   Reply With Quote
Old 06-22-2007, 05:31 PM   #7
4wdrift
Member#: 1403
99 RBP GC8 Impreza
[Mr Burns]Excellent![/Mr Burns]
4wdrift is offline   Reply With Quote
Old 06-22-2007, 06:37 PM   #8
JRL
Member#: 106372
2006 Impreza WRX
Steel Gray Metallic
You got the hard part done. Now its time to pull a mold off that thing and make more.....which is way easier than the way you originally did it.
JRL is offline   Reply With Quote
Old 06-22-2007, 07:11 PM   #9
RobK0000
Member#: 62230
^well i wasnt planning on making more of this exact one, Im going to make a better one sometime soon and sell this one, already got offers and it hasnt been on for 24 hours! lol
Ill post up with new design and what i hope it will look like.
Old 06-22-2007, 07:14 PM   #10
mbs627
Member#: 99794
2013 FR-S
Darky dark
Hopefully you actually put a little effort into the next one.
Awesome lip, man.
mbs627 is offline   Reply With Quote
Old 06-22-2007, 07:28 PM   #11
paosti
Member#: 107227
2005 STi-PSM-Stage2-
08 Nissan 350z-bone stock
great job...looks good.
paosti is offline   Reply With Quote
Old 06-22-2007, 07:40 PM   #12
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
so you spent $325 bucks........ouch
B00st3dWRX is offline   Reply With Quote
Old 06-22-2007, 07:41 PM   #13
RobK0000
Member#: 62230
^ have enough material to cover my entire car 3 times over
so i didnt spend that much, make 6 lips just like this, sell them for 300 each, you do the math!
Old 06-22-2007, 10:07 PM   #14
clbd39
Member#: 104078
2013 WRX
looks nice, good job on the write up!
clbd39 is offline   Reply With Quote
Old 06-22-2007, 10:32 PM   #15
ST0ICH
Member#: 120306
2005 年ワ
I looks real nice for using with you can get at the hardware store. I love it!!!
Originally Posted by RobK0000 View Post
...~Fiberglass cloth material, 4 little bags 36"x36" - hoe depot - $30...
YES!
ST0ICH is offline   Reply With Quote
Old 06-23-2007, 02:00 AM   #16
TVC15
Member#: 148517
Looks good for your first cf fabrication. Not to be a jerk but nothing that you did was done right...from the fiberglass to the carbon fiber. You should have watched some videos on youtube about carbon fiber fabrication. Your lip will crack, spiderweb, and more than likely break very soon, especially if you touch a curb. The more epoxy you put on there the weaker the whole piece gets. I don't really understand the use of bondo. If you make a good mold, lay up the fiberglass right, you would never need bondo. Besides, CF doesn't stick well to bondo in the long run. It will crack. I'm not trying to bash you but I don't think anyone should use any of the techniques you have used here. The best way to fab a cf lip would be to vacuum bag it, not by hand, and you wouldn't even need to use fiberglass at all, just a few layers of CF. The biggest mistake with Carbon Fiber is too much epoxy and a bad mold. Also, a little trick for getting the carbon fiber to stick to a mold, super 77 stray adhesive...works great and doesn't affect the resin flow at all. Also, the fiberglass lay up, you shouldn't have overlapped it in small 3" strips like that, those are all now uneven areas and potential cracking points. I've been working with Fiberglass, carbon fiber, Kevlar, polyester and epoxy resins for over 10 years and have never used bondo, fiberglass, and carbon fiber together. There is some great vids on youtube about vacuum bagging/infusion and even hand layup like what you did. I wouldn't recommend anyone using this technique.
+ the whole point of carbon fiber is to reduce weight, tons of bondo = heavy as hell.
TVC15 is offline   Reply With Quote
Old 06-23-2007, 03:19 PM   #17
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
ow well in that case right on!!!!
Old 06-23-2007, 04:05 PM   #18
RobK0000
Member#: 62230
I oringinally intended on using only fibverglass, but i decied to switch to cf afterwrds, thanks for the info though.
Old 06-23-2007, 05:16 PM   #19
TVC15
Member#: 148517
I'm glad your not pissed at what I said ^. Sometimes things come across harsh online. Anyways, if you have a ton of Carbon Fiber left over and you want to really get into making other stuff with it, you should watch some vids or go to the library and rent some books on Auto carbon fiber fabrication.
There are basically 5 ways to do it:
(to simplify things, lets say you are making a a carbon fiber hood)
Wet layup--you would take a piece of cf, place on a flat surface and wet it out with resin, and squeegee out the excess with a roller. Then add another layer of cf on top and repeat the process until you have the desired layers needed. Then you would place the whole thing in the mold and roll it in.
This method is usually only used for making very small and flat pieces.
Dry layup--this is similar to wet layup but you would put the first layer in the mold first and the rest is the same. Again, only works for smaller flat parts.
Pre-preg laminating--in short, the cf is pre impregnated with the resin, you would then cut to desired size, place in mold, vacuum bag it, and bake it at about 300 degrees to cure the resin.
Vacuum bagging--to start you could do either a wet layup or dry layup. Then you would place cf on/in mold, put in a vacuum bag and suck out all the air keeping suction until resin cures. This is a very simplified version, there is a lot of prep for the bag. This method IMO works best for more contoured parts, large and small.
Vacuum infusion--This is the most time consuming and complicated process, and requires some expensive equipment. It is very difficult and there is little room for error. If you get a leak in your bag, you're screwed. It is the same concept as vacuum bagging. However, you place the parts into the vacuum bag without any resin in the cloth at all. Then suck out the air keeping constant vacuum. Then the resin is introduced through tubes and flow material and pulled through the cf material. This is commonly used for making cf hoods. Doesn't work well for extreme contours because it is difficult to get the resin to flow evenly. Again, a very simple definition.
If you get good at this you could definitely make some cash. A Seibon CF lip is about $300-$500. Cost of material for that lip is I'd say under $50. a 50" x 3' piece of carbon is like $70. You're gonna use not even a 1/4 of that for a lip, depending on how many layers you want. Eveyone thinks cf is soo expensive, it's not really the materials that are so expensive it's the time it takes to make the parts. Lots of prep time.
Here is some vids:
(these are some great vids on all different techniques, accept infusion)
http://youtube.com/watch?v=q_fKlDzemPY
http://youtube.com/watch?v=IWiSSLPf6JI
http://youtube.com/watch?v=s12pUg9ypVU
http://youtube.com/watch?v=bb8QnQf72Rg
(Vacuum infusion)
http://youtube.com/watch?v=fJuifMOEGqM
(Vacuum infusion hood)
http://youtube.com/watch?v=zLUnxUw3nnI
Old 06-23-2007, 05:41 PM   #20
RobK0000
Member#: 62230
Thanks for the post up, that helps out alot! Also i used bondo because i did the little strips of fiberglass, it wasnt smooth. So instead of sanding for the rest of my life i used the bondo and pretty much sanded it back down to the fiberglass filling in the holes and bumps with the bondo. there wasnt much of the bondo left on the mold.
Old 06-24-2007, 03:47 PM   #21
JRL
Member#: 106372
2006 Impreza WRX
Steel Gray Metallic
+1
Not to mention that bondo is a body filler, and not meant to be used in composites. 3M makes some really good vynil ester fillers. Or you can do what I do and make your own filler using tooling resin and Q-cells.
Old 06-24-2007, 03:56 PM   #22
RobK0000
Member#: 62230
bondo works great with fiberglass, not CF. I didnt know this until TVC15 mentioned this to me yesterday. I experianced absolutly no trouble with it.
Old 06-24-2007, 03:56 PM   #23
scarsofterror
Member#: 109589
- 02 rex/ae86
[email protected]
looks great bro!! now i wanna make one for my bugeye!!
scarsofterror is offline   Reply With Quote
Old 06-24-2007, 04:04 PM   #24
impreza_GC8
Member#: 123295
2001 2.5RS w/ EJ257,
6-speed, Brembos
Its people like you who make me wish I would get off my ass and build things like that. Where can I buy one LOL
NICE WORK!
impreza_GC8 is offline   Reply With Quote
Old 06-24-2007, 04:08 PM   #25
palmerx141
Member#: 58312
WRB Bugeye SQC 217
272whp/283wtq
It looks good but thats a pretty expensive DIY no?
palmerx141 is offline   Reply With Quote
Carbon fiber hood and cracked carbon fiber lip 04 STI subaru fan SCIC Private Classifieds 9 03-18-2010 02:42 AM
DIY Carbon Fiber Barong Interior & Exterior Modification 14 09-04-2008 05:40 PM
DIY Carbon Fiber Front splitter Dr. Ill Member's Car Gallery 16 11-19-2007 10:32 PM
OK, I need to get rid of this carbon fiber lip! mattjk Southern California Impreza Club Forum -- SCIC 2 09-03-2002 07:56 PM
Does anyone know of a Carbon Fiber lip for a GC8 wilddave1 Interior & Exterior Modification 6 05-31-2002 06:27 PM
