01-28-2008, 10:20 AM | #26 |
Member#: 153982
Vehicle:2012 Impreza WRX 5dr Satin White Pearl |
Just ordered one as well awesome pricing. Thanks Perrin!
01-28-2008, 11:19 AM | #27 |
Member#: 6776
02-13-2008, 01:12 AM | #28 | |
Member#: 5673
BAIC
Vehicle:05 LGT, 02 WRX Hellcat CTR LC500 GRC |
02-13-2008, 01:50 AM | #29 |
Member#: 165212
Vehicle:2002 WRX Blaze Yellow |
I'll get that fixed ASAP, feel free to PM me your order and we'll get it to you. Sorry Ken Ken Jubb Sales PERRIN Performance 503-693-1702 Ex.113 [email protected] |
02-13-2008, 12:50 PM | #30 |
Member#: 6776
02-19-2008, 01:26 PM | #31 |
Member#: 165212
Time is running out, only a couple more days for the sale.
Just PM or call with questions Thanks Ken Ken Jubb Sales PERRIN Performance 503-693-1702 Ex.113 [email protected] |
02-19-2008, 11:03 PM | #32 |
Member#: 136553
Vehicle:02 fozz khaki |
is it me or does the perrin and whiteline subframe kits look the same but they install differant?
02-20-2008, 01:38 AM | #33 | |
Member#: 6776
[email protected] |
02-20-2008, 12:15 PM | #34 |
Member#: 147776
Vehicle:2001 Forester 2013 Scion FR-S |
How long is the sale for?
02-20-2008, 12:18 PM | #35 |
Member#: 147776
How long is the sale on?
02-20-2008, 12:34 PM | #36 |
Member#: 6776
It was extended through the end of February for now. Let me know if I can help with the order!
Thanks for asking! [email protected] |
02-20-2008, 05:16 PM | #37 |
Member#: 136553
i mean i am looking at both installs and the perrin loks like it is for the rear and the whiteline and kart boy are for the front it seems to me cause on the whiteline install guide it says nothing about the rear diff its all for the front
02-21-2008, 11:07 AM | #38 | |
Member#: 6776
VS. The subframe lock down shown in the DIY above. Each product does a different thing. The PSRS is an anti-lift system for the front suspension under braking and hard acceleration. Plus with the additional caster angle it dramatically improves steering response. (Hence the name Positiver Steering Response System.) The rear subframe lockdown system prevent axle trounce, driveline lash, improves throttle to drivetrain control etc. Thank you for the follow-up question! [email protected] |
02-21-2008, 09:53 PM | #39 |
Member#: 136553
oooo so the whiteline and kartboy kits are just a step blow the psrs system? instead of the psrs peice they use bushings? is that what you are telling me? and would it be wise if i made my own bushings for the rear diff bushings inserts because i have left over polyurethane bushgings from my energy suspension kit i got for my old car and im pretty sure if i trimmed them down i could make them fit do you think this would be wise?
03-03-2008, 03:31 PM | #40 |
Member#: 108091
Vehicle:2002 WRX |
Finally got around to installing mine last night. I love it!!! Easy install and small investment for a huge return in the feel of the car. Infreakincredible.
03-04-2008, 11:55 AM | #41 | |
Member#: 6776
Second you should be just fine. As long as you can get it to fit that is ok. You will be missing all of the metal piece to lock the subframe, but other than that you are a-ok! Let us know how we can help further! [email protected] |
03-04-2008, 11:55 AM | #42 |
Member#: 6776
03-04-2008, 01:15 PM | #43 |
Member#: 114530
Are you going to offer this for 2008+ Impreza? If so it should also fit 2005+ Legacy. Supposedly all the bushings are the same.
03-05-2008, 10:57 AM | #44 |
Member#: 168862
Vehicle:2007 ej253n/a 5speed Red Sox Nation Lifer |
ordered
ive had a list of parts of parts im working twords. its large. this rear subframe lockdown was on the list and now that its on sale i ordered it . let the suspension work begin . this is my first step in rear . next comes larger sway bar , end links , mounts, lateral links, trailing links , assorted chassis stiffening bars ,well see how it feels after all that in the rear if its too loose still ill look at coilovers. i just cant see swapping out the stocker struts and springs yet cause they still work . once they go bad ill upgrade , but we will see how other mods affect performance first.
03-05-2008, 11:13 AM | #45 | |
Member#: 6776
[email protected] |
03-05-2008, 11:14 AM | #46 | |
Member#: 6776
Thanks again for choosing PERRIN! [email protected] |
03-05-2008, 11:38 AM | #47 | |
Member#: 114530
http://legacygt.com/forums/showthread.php?p=1015596 |
03-05-2008, 01:01 PM | #48 | |
Member#: 6776
[email protected] |
03-07-2008, 01:35 PM | #49 |
Member#: 168862
questions
i ordered my kit and its on the way . ok the bushing upgrades i understand and im down. but the lock out bolts? ok do these lock out the rear diff??? like make it useless and make my rear axles act as one?this is what i understand a diff lock out to be . or does it just tighten up the suspension? im curious because i would love to lock my rear diff on the dirt , but on a road i like the function of the rear diff . can you please clarify what exactly the " lock out " bolts accomplish?
03-07-2008, 03:08 PM | #50 | |
Member#: 114530
Similar Threads | ||||
DIY Perrin Rear Differential Cover Installation | PERRIN_Ken | Transmission (AT/MT) & Driveline | 75 | 02-02-2016 04:07 AM |
Perrin Subframe Lockdown System (SLS) on 2010 WRX Sedan | Blue_Rex | Car Part Reviews | 5 | 04-12-2010 11:02 PM |
Rear diff bushings/ lockdown systems opinions? | mostasz | Newbies & FAQs | 14 | 09-20-2008 09:01 PM |
Perrin Rear Differential Subframe Lockdown | 06blacksti | Transmission (AT/MT) & Driveline | 6 | 01-19-2007 04:46 PM |
