Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Old 01-19-2008, 11:44 AM   #151
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
I'm not sure what's going on with my engine now but I've been noticing bogging at about 4~5k. It feels as though like I forgot to clamp the hoses on my throttle body for my TMIC however I have upgraded T clamps there. I also have a APS turbo inlet installed but I don't have a proper tune on it. I never had this problem before and now it's starting to happen more frequently. I'm going to check it out after work today but wanted to know if anyone has an idea of what it could be. The only other thing that I have on the engine is a catch can. I'm running it the same way I used to on my WRX engine. Unfortunately, the APS turbo inlet does NOT have that rear nipple to run separate catch cans.
Any ideas?
Jon
iNfEk is offline   Reply With Quote
Old 01-29-2008, 11:44 AM   #152
Big_DeWeY
Member#: 37078
95 L
Blue-ish
This thread has sealed the deal for me. 207 FTMFW!
Big_DeWeY is offline   Reply With Quote
Old 01-29-2008, 02:28 PM   #153
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
I think my clutch might be going... LOL
I had to think about it for a while but it's all good
Old 01-29-2008, 02:31 PM   #154
Foska Oats
Member#: 144081
2003 WRX
Ditto that.
The thing is to find one.
Lots of guys are holding on to them and stroking them.
But they are the best, for what I want anyway.
But for now, I will stick to the 205
Foska Oats is offline   Reply With Quote
Old 02-29-2008, 02:56 PM   #155
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
we'll i've decided to go with a ECUTEK Reflash and a UTEC Delta along with a DTEC to tune my engine. I've also decided on a FP EVO III 16G
Now I have to wait till funds accumulate and will be having this tuned. The top priority right now is replacing my clutch since that gave me a scare a while back. I'm probably going with a Exedy Stage 1 with a lightened flywheel NO LIGHTER than 13lbs.
Jon
Old 02-29-2008, 03:02 PM   #156
crazymikie
Member#: 56321
2006 Honda El Camino
Green
why so many different EMs?
crazymikie is offline   Reply With Quote
Old 03-01-2008, 12:20 AM   #157
GTScoob
Member#: 68602
02 STi Wagon
Jon
I second the post above mine, why run 2 EMs and nother boost control system? 16G is also pretty small for this motor but its your car so do whatever you will with it.
I wouldnt worry as much about the flywheel, I've got I think a 12lb flywheel on mine and have never gotten a misfire cel.
GTScoob is offline   Reply With Quote
Old 03-01-2008, 12:25 AM   #158
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Just get someone to open source flash the ecu. There is no point to pay the money for the ecutek. Plus it locks the ecu.
The utec is great. I use one on my personal car. But its not even needed for the 16G unless you want to fine tune it yourself and or change maps with the switch.
I was never a fan of the Dtec. Just use the factory or the utec boost control.
Clark
AZScoobie is offline   Reply With Quote
Old 03-01-2008, 12:38 AM   #159
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
well the ecutek was a suggestion for more precise tuning. I haven't purchased yet. I like the dtec bc abilities. I'd like to learn so that's why utec and since its jdm and aus compatible.
Old 03-01-2008, 12:42 AM   #160
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Im not concerned about CELs for the flywheel but rather the driveability. E3 16G is for streetability and because the only event I have at the moment is autox. Big power isnt my thing. Thanks guys
Old 07-16-2008, 12:49 PM   #161
madkayaker
Member#: 57378
2002 wrx w/ sti swap
04 sti, 11 forester xt
anybody running 207 short block with 205 heads? My ej205 pooped out on me last week, and I have access to a 207 short block with a spun bearing. I was thinking about putting crower 272 cams in my 205 heads and bolting them to the 207. I know I won't have the benefits of avcs, but couldn't I still use my stock ecu and tune with my ap?
madkayaker is offline   Reply With Quote
Old 07-16-2008, 02:11 PM   #162
BoostedSti
Member#: 69649
2003 Wrx- 361whp
2003 Cobra- 520rwhp
I have a 207 with 205 heads, its for sale if you are interested :-)
BoostedSti is offline   Reply With Quote
Old 07-16-2008, 02:56 PM   #163
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yes. You can run the EJ205 heads. The Combustion chambers are a bit larger at 52cc vs 49 for the 207 heads. Also your 205 heads are small port where the 207s are likely to be big port heads. Still, This is a good solid combination thats been done time and time again. Your ECU will run the show just fine once tuned.
Clark
Clark Turner is offline   Reply With Quote
Old 07-16-2008, 07:11 PM   #164
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
wouldnt running a ej205 with high compresison pistons + big cams be kinda similar to a ej207?
mxpunk is offline   Reply With Quote
Old 07-16-2008, 08:07 PM   #165
Clark Turner
Member#: 178047
02 WRX STI Spec C
Not really. EJ207 is very different.
Clark
Old 07-16-2008, 08:21 PM   #166
Kaldar142
Member#: 151090
S197 boosted V8 FTW
what can you do to the Ej205 to make it on par or close to the EJ207?
Kaldar142 is offline   Reply With Quote
Old 07-16-2008, 10:41 PM   #167
madkayaker
Member#: 57378
sweet. thanks. I'm gonna finish tearing down my 205 some time next week and see exactly whats going on with it, then i'll start my 207 build.
Old 07-16-2008, 11:30 PM   #168
tein_scp
Member#: 184711
hi im new here, im from subaru club philippines, how will i know if my engine was a 205 or 207? btw my engine's box cant be reflashed.. so i think this is 205? really need some tuning on my gc8.. sorry for my question im new in subaru world i came from hondas so im really a newbie in this engine.. thanks in advance..
tein_scp is offline   Reply With Quote
Old 07-17-2008, 12:16 AM   #169
WRC-boxer
Member#: 147186
on your vin plate, look at the engine code, the first 5 numbers will tell you what engine it is.
cheers
-Evan
WRC-boxer is offline   Reply With Quote
Old 07-17-2008, 02:12 AM   #170
Clark Turner
Member#: 178047
02 WRX STI Spec C
To make an ej205 like an ej207 you would need to:
1. Change the block to a semi closed deck.
2. Change the crank to a forged double drilled unit.
3. Change the rods to forged rods.
4. Port the heads
5. Chang the valves to sodium filled.
6. Weld up the Combustion chambers and remil to 49cc
7. Change the headgaskets
8. Change the cams and cam buckets to the no shim design.
9. CHang the oil pump
10. Change the water pump.
11. Mill heads to accept AVCS and sensors
12. Obtain correct cam belt and cam wheels.
13. Change intake manifold to STI
14. WHY am I typing all this out?
15. I have no idea
16. I guess I am bored.
17. Sell 205
18. Buy 207.
19. DONE.
CLark
Old 07-17-2008, 11:23 AM   #171
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
clark, how would a 205 perform with higher compression pistons, forged internals, etc .. ?
Old 07-17-2008, 11:25 AM   #172
Big_DeWeY
Member#: 37078
95 L
Blue-ish
I'll be able to tell you in the not so distant future
Old 07-17-2008, 01:11 PM   #173
GeneralTJI
Member#: 152680
EJ205's come with a forged crank and rods... just FYI on that
But he 207 doesn't have a cross drilled crank, which seems to be a good thing for higher RPM's and keeping your rod journals from being starved for oil
But yea, EJ205 pistons are nothing to get excited over, upgrading those is a great idea... and the EJ205 rods even being forged still leave some room for improvement as well
I really want a ver7 207... but I just picked up a 205 block in good shape for $100. Hopefully I will be able to find some 207 heads or get an extra set and have them worked....
GeneralTJI is offline   Reply With Quote
Old 07-17-2008, 01:13 PM   #174
Clark Turner
Member#: 178047
02 WRX STI Spec C
EJ205s DO NOT have Forged Rods. I repeat. DO NOT have forged rods.
Clark
Old 07-17-2008, 01:57 PM   #175
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Clark
Lol beat me to it. All the more reason to get better stuff.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
