Welcome to the North American Subaru Impreza Owners Club Tuesday May 30, 2017
Old 08-16-2008, 11:44 AM   #1
takumi
Member#: 6964
2001 impreza
pearl ridge blue
Default problems problems 04 swap Cooling problems
quick run down on my car
01 rs
04 sti swap ( don't know the miles, but it should be low)
pe1818
FAL slim fans
Koyo legacy rad (53mm i think)
Okm, heres the story. the car is only driven on the weekends,
so i tooked it out, for about 2 hours, boosting here and there nothing crazy.
I get back to let the car cool down, once it sat ther for about 5 mins, i notice the temp gauge was almost to H, i went ahead and turned it off and let it cool down. Once it cool down a bit, i check the coolant, it wasn't that low, but i topped it off anyway. i started the car, and for a couple of mins later, the samething. So i went ahead and turned it off. What i also notice at that time that the Fans only click on for a second, and turn off when the engine was on. So i check all the fuse and relays, they are fine. once i started it back up, the idle started to flutter. I was told i just need to unplug the ecu and plug back after it resets itself. after unplugging it, i left it there for about a week. i plug back the ecu, i also check the coolant again, this time it was somewhat low, but still some left in the resvior, so i topped it off again. I started the car, fluttering was gone, waited for it to get to normal temp. I held it at 3krpm and turn on the heat, for about 10 mins, the temp stay at normal, i notice the fan did the samething, click on and then off. but it never pass the normal temp
I also check if there was coolant in the oil, there was none
now i am thinking, thermostat, or thermoswitch
anyideas... whats the next step?
takumi is offline   Reply With Quote
Old 08-17-2008, 09:55 PM   #2
takumi
Member#: 6964
2001 impreza
pearl ridge blue
anyone?
Old 08-17-2008, 10:32 PM   #3
Skatermxracer
Member#: 119329
1997 OBS WRX powered
blue/gray
gotta be something wrong with the fans... they should be running not clicking on
they might not be wired correctly
try plugging the check mode connectors together and see if the fans cycle on and off like they should
Skatermxracer is offline   Reply With Quote
Major cooling problem!!! subywrxtuner6969 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-03-2007 12:06 PM
EJ18 starting/cooling problems Pawl Normally Aspirated Powertrain 5 02-22-2006 10:12 PM
Cooling problems chrismindless Normally Aspirated with bolt-on Forced Induction Powertrain 20 04-29-2005 11:25 AM
Cooling Problems/Catalytic Converter Fault beege_mi Newbies & FAQs 1 12-13-2004 12:27 AM
03 Outback Sport Engine Cooling Problem ? JC123 Service & Maintenance 3 11-10-2004 06:38 PM
