Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 08-15-2008, 05:42 PM   #151
mattius
Member#: 178752
2004 WRX Wagon
JBP
Does anyone know of any issues with the wiring when swapping an 04 STi cluster into an 04 Wagon?
mattius is offline   Reply With Quote
Old 08-15-2008, 05:44 PM   #152
owencalouro
Member#: 172342
i am about to install a 04 sti cluster into my 05wrx with auto hvac. instead of tapeing the lights you dont want to come on like the ddc and the abs cant you just remove those lights from the cluster.
owencalouro is offline   Reply With Quote
Old 08-25-2008, 02:11 PM   #153
ACrAPPYRS
Member#: 121545
2005 Broken RS
Ok after looking through this thread I couldn't find answers to my question.
I have an 05 RS, I want an STi cluster. From what I gathered, an 04 STi cluster will be my best bet. Most of it will be PnP, with a need to ground certain wires to disable DCCD, ABS..ect. (would just taking out those corresponding bulbs work rather then grounding the circuit)
Is all this correct?
ACrAPPYRS is offline   Reply With Quote
Old 08-25-2008, 02:27 PM   #154
Chris05STi
Member#: 88248
2005 Subaru STi
Again, does ANYONE have a pics of that one plug where you have to shave it a lil. I got 2 out of the 3 plugs to go in correctly. I know which wires to cut, etc. I have a 2002 WRX and a 2005 STi cluster. ANYONE have ANY feedback and pics on this?!
Chris05STi is offline   Reply With Quote
Old 08-25-2008, 02:37 PM   #155
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
You can't take out those bulbs...they are LEDS that are wired into the circuit.
CoolRex is offline   Reply With Quote
Old 08-25-2008, 02:40 PM   #156
ProDriven Auto
Member#: 179000
2010 Outback
2007 T4R Sport
You can de solder them =) but that would probably be more complicated for someone then grounding the wires =)
by the way
I have 05sti and 06sti clusters. 350 each plus shipping.
ProDriven Auto is offline   Reply With Quote
Old 08-25-2008, 05:57 PM   #157
owencalouro
Member#: 172342
Tape it will be then. I have done so much wiring back their i just don't want to mess with it anymore.
Old 08-25-2008, 08:39 PM   #158
aznburn210
Member#: 84062
2008 Forester XT
Garnet Red Pearl
haha i just put an 05 STi cluster in my 05 WRXZ.. everything working correctly..
outside temp - check
no buzzing ( clips c9) - check
cruise control light still need to fix and move over
DCCD still on i havent had a chance to fix that yet
and rear temp light on ..
aznburn210 is offline   Reply With Quote
Old 08-26-2008, 01:11 PM   #159
owencalouro
Member#: 172342
so you didn't have any problems with blown radio fuse; you just plugged right in, and everything is ok (other than no CC light and 2 lights stuck on) what about the shift light does that all work ok.
Old 08-26-2008, 01:43 PM   #160
aznburn210
Member#: 84062
2008 Forester XT
Garnet Red Pearl
shift light works perfect.. and no fuses on the radio have blown.. although i have an aftermarket radio though
Old 08-29-2008, 12:49 PM   #161
owencalouro
Member#: 172342
OK so i got the 04 sti cluster in my 05 wrx and almost everything works without modding anything (just plugged right in)
here are my problems, maybe someone can help. The dimmer as described in this post doesn't work ("-Illumination levels are set by pressing the odometer reset until "ill" appears in the odometer display".) I press and hold the trip reset and nothing happens. I know that I can rewire the dimmer switch to work with my wrx, I will try that out later. Also, I am not sure, but should their be a difference in illumination between night and day(lights on and off), cause their is not.
The final problem is the speedo, it seems to be about 10mph slow at 70. This leads me to believe that because its a 160top speed and not 140 it is an inaccurate reading. Anyone else havening this problem and maybe an easy fix.
Other then that everything works great, shift light and beep works; so does the outside temp (I have auto hvac). Although the cruise light doesn't come on when I push the button, the set light does, so that's fine with me.
When I get my maddad gauges in I'll setup some pics, I have blue leds on everything with the red gauges, looks dam good I think
Old 08-29-2008, 12:56 PM   #162
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
You don't press and hold it. Press it and press it again. Should get Trip A, Trip B, ILL. At ILL use the other knob to adjust.
Old 08-29-2008, 01:20 PM   #163
owencalouro
Member#: 172342
ok kool thanks, is it also supose to change from day to night(lights on and off)
Old 08-29-2008, 01:30 PM   #164
mattius
Member#: 178752
2004 WRX Wagon
JBP
^^ yep, turn the knob like you were changing your shift points. If the illumination is set to "5", you will not see a diff. during night/day. Try again on a lower illum. setting.
Old 08-29-2008, 01:31 PM   #165
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
no it's always the same.
Old 08-29-2008, 01:35 PM   #166
owencalouro
Member#: 172342
cool ill go down to the parking garage and try this out.
what about your speedo is that working right, mine seems to be off
Old 08-29-2008, 02:00 PM   #167
mattius
Member#: 178752
2004 WRX Wagon
JBP
^^^ I think mine is off too. I passed one of those Radar signs and there was a 5-8mph difference.
Old 08-29-2008, 02:07 PM   #168
owencalouro
Member#: 172342
well maybe ill get pulled over for speeding less now, it's like setting your clock early so your never late..
Old 08-29-2008, 02:28 PM   #169
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Mine is off by 4-5 mph but I have 235/40/17 tires.
Old 08-30-2008, 12:09 AM   #170
6speedRegime
Member#: 172187
2016 WRX Limited WRB
15 FXT, 04 STi, 02/11 WRX
Default Radio not working after sti cluster swap
I just installed an 05 wrx sti cluster into an 02 wrx. Everything is working as expected, but my radio no longer works. Its not the fuse, i checked, so what is the problem??
6speedRegime is offline   Reply With Quote
Old 09-10-2008, 02:18 AM   #171
STL WRX
Member#: 88304
05 VF34 Aspen WRX
Whats the best year cluster to install into my 05 WRX? Will an 06-07 cluster work?
STL WRX is offline   Reply With Quote
Old 09-10-2008, 04:18 AM   #172
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
03wrxmarine, you need to cut a wire in order for the radio to stop blowing fuses and work properly. i had the same problem when i did mine. i want to say it is the orange wire you need to cut. but it was a while ago and im not 100% sure on that.
02blkwagn19 is offline   Reply With Quote
Old 09-22-2008, 06:18 PM   #173
mattius
Member#: 178752
2004 WRX Wagon
JBP
has anyone gotten the OAT sensor to work on a 2004 WRX w/ a 2004 STi cluster?
Old 09-23-2008, 11:18 AM   #174
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Ok so has anyone apart from prodrivedreams successfully installed a 04 cluster into a 06-07 wrx and switched the polarity of the abs light?? I have tried to contact prodrivedreams but he doesnt answer. He speaks of a relay, is it a standard relay or a special one??
Looking to install my cluster sometime this week.
WagonGGA is offline   Reply With Quote
Old 09-24-2008, 11:43 PM   #175
Norrberrt
Member#: 110021
2003 WRXSTi
Originally Posted by BlueSubeDude View Post
I'd leave some room on the connector side when clipping C9 so it can be pulled out and put in B4 to ground (B4 didn't have a wire in my case).
Also, I reprogrammed the STI cluster to match my current mileage. Good luck.
How did u reprogram to get correct mileage?.. i called Tacoma Speedometer.. and they said they cannot set it to what you want.. I want to set mines to Zero.. im installing a new Block.. im going with an 06 STi Block.. so i want my mileage to start off at Zero..
Installation of my 05 STi Cluster USDM in my 03 WRX..
Norrberrt is offline   Reply With Quote
can we get some mods to start deleting duplicate threads? [27] Political Playground 2 11-05-2008 03:01 AM
STi hare emblem? where can i get one... evoeater8 Interior & Exterior Modification 13 07-12-2006 09:53 PM
can we get something started in RDU???(nc) imprezivSTi04 Mid Atlantic Impreza Club -- MAIC 3 04-04-2006 07:47 PM
02 sti hood scoop?? where can i get one? slaterdrew Private 'Wanted' Classifieds 2 02-06-2004 12:37 PM
lighted keyhole ring, can we get one? makanouchi Interior & Exterior Modification 12 11-22-2002 09:38 PM
