11-16-2008, 11:03 PM | #1 |
Member#: 186613
NWIC
Vehicle:1997 Impreza OBS Acadia Green 64C |
Phase 1 4EAT with 02 ECU?
Hello, I'm thinking about swapping an engine from an 02 WRX into my 97 OBS with the phase 1 4EAT. Will the new ECU work with the older TCU and trans, or will I get error codes etc. It looks like the 02 ECU has an additional input (AT load signal) for the A/T that the 97 doesn't. Can the new ECU do without this input? What has to be done to make the two work together? Thanks for any help.
11-17-2008, 02:09 PM | #2 |
Member#: 123347
NWIC
Vehicle:1993 POS burgandy legacy |
possibly if you can get the signal wires setup properly....but it most definitely is not a plug and play deal
I think your best bet would be a full conversion, not just the motor |
11-17-2008, 04:44 PM | #3 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
I played with this idea for a while. It seems like the "best" way to do it was to make the car think it's using a manual transmission and then take whatever signals are needed for the TCU Effectively splitting the two to work separately (other than the VSS signal).
11-20-2008, 01:27 AM | #4 |
Member#: 186613
NWIC
So no one's done this? Any other ideas?
12-04-2008, 06:30 PM | #5 |
Member#: 186613
NWIC
Anyone else?
Similar Threads | ||||
Phase 1 4eats - Some TC shafts have a nipple and some don't | ciper | Transmission (AT/MT) & Driveline | 0 | 11-17-2009 08:48 PM |
02 engine and ECU w/ Phase 1 4EAT | earlvb | Subaru Conversions | 5 | 02-26-2009 12:15 PM |
Phase 1 4eat wiring wanted | fateo66 | Transmission (AT/MT) & Driveline | 1 | 09-22-2008 01:29 PM |
4EAT with 16g ECU options | Twiztidunreal | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 07-27-2005 02:01 AM |
EJ22T + Phase 1 DOHC Heads + Link ECU | RS_NW | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 05-23-2003 01:59 PM |
