Welcome to the North American Subaru Impreza Owners Club Wednesday October 23, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 02-17-2009, 03:48 PM   #1
awdtuning.com
Vendor Sales Rating: (59)
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
I've been using GrimmSpeed's 3-Port Boost Solenoid for some time now and have found their solenoid provides rapid boost response while maintaining the ability to make acute adjustments via turbo dynamics. While many other boost control solenoids react to adjustments too fast which can make them difficult to control with as much finesse as the stock bleed system. This solenoid can make micro-adjustments at the edge of target boost not only providing better spool, but overall more control. Additionally, the solenoid is plug n' play so you do not have to splice into the wiring harness for it's installation.
GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the market. Their aftermarket boost controller allows you to raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels. Using GrimmSpeed's solenoid you are able to spool your turbo quicker and maintain a rock solid boost level. They have made the solenoid to withstand 120psi, way more than any Subaru will see
Revolutionizing the Subaru boost solenoid market, GrimmSpeed has created model specific install brackets that allow you to directly fit our Boost Solenoid into your Subaru for a factory fit. No more Zip-tying! They give you the factory fitment you have been waiting for.
Staying with the OEM fitment theme, GrimmSpeed's Boost Solenoid uses a Subaru style wiring harness so you can simply unplug your OEM solenoid and plug ours in. No more cutting the oem wiring and crimping wires together!
Also new to the Subaru boost solenoid market, they have used ultra low-profile hose fittings to keep the unit as small and clean as possible. The hose fittings are nickel plated brass so you don't have to worry about them snapping off like the plastic hose fittings!
Features:
  • Direct plug and play into oem wiring.
    MAC Valve has completely custom made the valve for us(only MAC valve on the market to be custom made for automotive tuning use).
  • Users can use AN fittings with the solenoid.
  • Mounting bracket so its a direct bolt on into factory location.
  • Low-profile brass hose fittings(small in size so its compact, no chance of breaking fittings like the plastic ones our competitors use).
  • Specifically designed by GrimmSpeed to work safely with the factory Subaru ECU (requires tuning) and to reliably handle the vibrations and temperatures of your engine bay!
  • The only direct “bolt in” design for all Subaru models. Direct bolt in mounting bracket and hardware included! (specify which model before ordering)
  • Includes plug and play harness, no wire splicing required and easy to return to stock.
  • Allows you to raise the factory boost levels with adding more response and more control.
  • Allows you to get full boost sooner.
  • Faster response and greater flow than any other valve out there. (by more than 10%!)
  • Nickel plated brass fittings. (unlike the competitors failure prone plastic fittings)
This BCS will handle all your boost control needs no matter what your power goals are.
This will require a new tune, but it's real easy for your shop or tuner to tune. If you want information on any tuning services offered by awdtuning.com, please email [email protected]
GROUP BUY DETAILS
Closes on: Wednesday, March 4th (2 weeks long)
Participant limit: No-limit
Pricing structure: Tiered
Normal MSRP: 109.99
1-10 participants: 104.99
11-20 participants: 99.99
21+ participants: 84.99
Shipping will be $5 to anywhere in the 48 states. International shipping will be extra.
We will be accepting payments through paypal or credit card once the group buy closes.
PARTICIPANT LIST:
1. bisonjr - 07 WRX Paid
2. Daishi00 - 05 WRX Paid
3. omegax - 08 STi Paid
4. CKxx - 08 STi Paid
5.
6. Baay - 07 WRX Paid
7. DarkKnightBaku - 04 STi Paid
8. bryant53 - 05 WRX Paid
9. xazzu - 06 WRX Paid
10 scubywagon - 04 WRX
11. herewego311 - 2000 RS w/ 04 STi swap Paid
12. PSI_XTC - 02 WRX Paid
13. macio04 - 04 WRX Paid
14. blakaraknyd - 05 WRX Paid
15. sch3838 - 07 WRX Paid
16. dbedigrew - 05 LGT Paid
17. BreaknLoose - 04 WRX Paid
18. vodka9er - 07 STi
19. karnlax - 07 WRX Paid
20. Zor - 08 STi Paid
21. pookdizzlehtk - 02 WRX Paid
22. Silverpike - 02 WRX Paid
23. sxc-rex - 02 WRX Paid
24. wrxmaniac - 06 WRX - Paid
25. steverx05 - 05 WRX Paid
26. Dubstar112 - 07 WRX Paid
27. AlxSti - 06 STi Paid
28. ekw - 04 STi Paid
29. xreign - 06 STi Paid
30. jainuss - 05 STi Paid
31. Trox - 05 STi Paid
32. Verwilderd - 08 Lgt Paid
33. bcheck555 - 02 WRX Paid
34. praedet - 05 Lgt (08 STi) Paid
35. ammo0000 - 07 WRX Paid
36. wrxtasy555 - 06 FXT Paid
37. OZsuby - Liberty B4/ Legacy Paid
38. saintseiyaz - 00 GC8 Paid
39. jkurtonick - 06 STi Paid
40. 06blksubwrx - 06 WRX
41. MicMcKee - 08 WRX Paid
42. SXti - 08 STi Paid
43. SPT.WRX.2K8 - 08 WRX
44. Subartender - GC8 (06-07 WRX bracket) Paid
45. StripedRex -05 FXT
46. fraggle - 07 Spec.b Paid
47. RiSTi05 - 05 STi Paid
48. RBKSTL82 - 02wrx Paid
49. NE1AWD - 04 FXT Paid
50. Spider96 - 07 STi Paid
51. morroco88 - 97 LGT (06 WRX Bracket) Paid
52. Sea-Scooby - 05 FXT Paid
53. Jmanrex - 04 STi Paid
54. JimmaySTi - 05 STi paid
55. 305mouse - 05 WRX Paid
56. Stiblobeye - 05 STi paid
57. Lateralis - 06 WRX
58. Stikboy9 - 02 WRX Paid
59. Stikboy9 - 04 WRX Paid
60.
61. Boxologist - 96 Wagon (06 WRX Bracket)
62. Joker - 02 WRX Paid
63. V8 GTFO Lesbic WGN - 07 FXT paid
64. RcrMg - 04 STi Paid
65. RonJitsu - 07 WRX Paid
66. Fernown - 08 FXT Paid
67. rasheedn - 09 STi
68. Rageous - 08 STi Paid
69. sk84fun21 - 02 WRX Paid
70. funbutns - 03 WRX
71. mhspyder97 - 07 WRX Paid
72. swappedGF - 98 OBS GC/GF (06 WRX bracket) Paid
73. wrxmyers - 00 RS (06 WRX bracket)
74. mccanixx - 02 WRX paid
75. K-Dizzle - 06 WRX Paid
76. subiespeed - 06 STi Paid
77. Vmaxlvr - 08 STi
78. rcdragracer - 06 STi - Paid
79. jryan87 - 07 WRX Paid
80. blackcompany2000 - 07 STi Paid
81. MechEE - 08 STi
82. JDM Junkyard - 04 FXT Paid
83. howfast? - 03 WRX Paid
84. Massbmx - 04 WRX Paid
85. scuby04 - 04 WRX
86. scuby04 - 04 WRX
87. vdub2sube - 05 WRX Paid
88. stamps31757 - 02 WRX
89. jesterduck - 05 WRX Paid
90. WC LATHE WERKS - 04 WRX Paid
91. Jimmyz31
92. rendog24 - 06 WRX Paid
93. brain Juice - 06 WRX Paid
94. Fleadog - 06 STI Paid
95. Saloonracer -07 WRX
96. whontime - 05 STi Paid
97. Crestinghawk - 03 WRX Paid
98. snwman - 05 WRX Paid
99. youSTi - 07 STi Paid
100. Matrix021 -03 WRX Paid
101. 2kbill - 04 WRX Paid
102.
103.
104. XeonGT - 08 STi Paid
105. Salmacis - 02 WRX
106. zCivic - 02 WRX Paid
107. jstalford - 05 WRX Paid
108. baller_v24 - 06 STi Paid
109. bcs925 - 07 WRX Paid
110. Chin - 04 STi Paid
111. penusai - 02 WRX Paid
112. pinksOck12 - 07 STi
113. Sgmongoose - GC - (06 WRX)
114. SBundorjr - 04 STi
115. AK_ - 08 STi Paid
116. WastingTime - 06 WRX
117. SiHing - 02 WRX
118. Salmacis - 02 WRX
119. Juice7979 - 05 WRX Paid
120. zenstorm311 - 02 WRX (local)
121. RexTexWagon - 07 WRX (local) Paid
122. richirich - 06 STi Paid
123.
124. ronzogonzo - 07 wrx Paid
125. see red - 04 wrx Paid
126. jennspgt - 02 wrx Paid
127. calmdev - 06 WRX Paid
128. LaptopBrent - 06 WRX (local) Paid
129. kalani266 - 02 WRX Paid
130. iri_tuan - 06 STi Paid
131. iri_tuan - 07 WRX Paid
132. imstuner - 08 WRX
133. Hah72215 - 02 WRX Paid
134. WRXGONE - 02 WRX Paid
135. jeffman127 - 06 WRX Paid
136. Misanthrope789 - 05 STi
137. litowrx - 04 STi
138. bibs - 09 Forester Paid
139. zzSTI10 - 05 STi Paid
140. Magowin - 05 LGT Paid
141. tallterror - 05 WRX Paid
142. feint05 - 04 WRX Paid
143. LeiboWRX - 04 STi Paid
144. STimedic 05 STi Paid
145. kalani266 - 02 WRX Paid
146. woodys77 - 07 STi Paid
147. KUEDA - 07 STi Paid
148. Maxboost_50psi - 06 STi Paid
149. rmkcent - 03 WRX
150. easy jesus_151 - 03 WRX Paid
151. Jus Blaze - 02 WRX Paid
152. BlakeWRX06 - 06 WRX Paid
153. tramix - 98 RS
154. alwazsidwaz - 98 RS
155. Charcoalwan - 09 FXT
156. kayen - 02 WRX
157. SillyRabbitTrixR4Kid - 05 WRX Paid
158. Impreza WR Rex - 03 WRX Paid
159. wheatpaste -04 WRX Paid
160. mickeyd2005 - 05 LGT
161. VA05STI - 05 STi Paid
So if/when we get to the best pricing tier, you are looking at $89.99 for by far the most complete and compact boost solenoid on the market!
3 bracket variations fit all Turbo Subaru models!
Solenoid and Bracket attached to 05+ LGT and 08+ WRX OEM bracket
Solenoid and Bracket attached to 08+ STi OEM Bracket
awdtuning.com is offline
Old 02-17-2009, 04:22 PM   #2
AlxSti
Member Sales Rating: (19)
Member#: 94615
2017 VW GTI SE
2006 STi 341WHP/356TQ
subscribed
AlxSti is offline
Old 02-17-2009, 04:25 PM   #3
wrxtasy555
Member Sales Rating: (20)
Member#: 8293
2006 Forester XT
Crystal Gray Metallic
Interested.
wrxtasy555 is offline
Old 02-17-2009, 04:36 PM   #4
omegax
Member Sales Rating: (3)
Member#: 65347
sign me up!
omegax is offline
Old 02-17-2009, 04:37 PM   #5
mpsti05
Member Sales Rating: (14)
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
interested also
mpsti05 is offline
Old 02-17-2009, 04:46 PM   #6
wrxtasy555
Member#: 8293
2006 Forester XT
How does this compare to the Prodrive solenoid? What are the three ports used for?
Old 02-17-2009, 05:08 PM   #7
awdtuning.com
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
It is comparable to the prodrive one in operation but has a bit more granular boost control. It is also virtually silent in operation. Additionally the installation is actually oem replacement capable, the ports are also more substantial and will not break off under stress.
The center port goes to the Turbo outlet or vacuum source, then 2nd port goes to the wastegate actuator, and the 1st port goes to atmospher or inlet.
Old 02-17-2009, 06:18 PM   #8
jkurtonick
Member Sales Rating: (1)
Member#: 99196
2006 Subaru WRX STI
Russian Hammer
Subscribed!!!
jkurtonick is offline
Old 02-17-2009, 06:41 PM   #9
awdtuning.com
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
If interested please send a PM, and make sure to specify the year/model it is intended for so that the necessary hardware can be included and your zip code for shipping cost.
Thanks,
-Keith
Old 02-17-2009, 06:51 PM   #10
Daishi00
Member#: 78952
2005 WRX
I'm in.
Daishi00 is offline
Old 02-17-2009, 06:56 PM   #11
Mr. Ed
Member Sales Rating: (16)
Member#: 99211
2014 Legacy
money can't buy you love
hot stuff mang
Mr. Ed is offline
Old 02-17-2009, 07:14 PM   #12
Punctual
Member Sales Rating: (10)
Member#: 167098
2010 F-150 Raptor
2011 Ducati 1198
tempting!
Punctual is offline
Old 02-17-2009, 08:57 PM   #13
CKxx
Member Sales Rating: (26)
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Well...I need one. Sign me up.
CKxx is offline
Old 02-17-2009, 09:40 PM   #14
AlxSti
Member#: 94615
2017 VW GTI SE
how about the first 10 get one for $90 shipped.. and after that it jumps back up
AlxSti is offline
Old 02-17-2009, 10:40 PM   #15
PSI_XTC
Member Sales Rating: (7)
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
Soooooo tempting. What is the suggested method of payment for this GB?
PSI_XTC is offline
Old 02-18-2009, 12:03 AM   #16
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
will this be able to control my 35r setup using the AP and 3bar AEM map sensor? If so, I'm in!
Big-Sexy907 is offline
Old 02-18-2009, 12:45 AM   #17
awdtuning.com
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
Yes - it certainly will.
Old 02-18-2009, 12:48 AM   #18
Zor
Member Sales Rating: (2)
Member#: 47473
2008 WRX STI
I'm in for this
Zor is offline
Old 02-18-2009, 02:50 AM   #19
2006WRX4ME
Member#: 134286
2006 WRX Limited
Pm'd.
2006WRX4ME is offline
Old 02-18-2009, 11:22 AM   #20
gtasti
Member Sales Rating: (63)
Member#: 152036
2004 Sti
to bad i didnt see this before i cut my wires to install the GM BCS
gtasti is offline
Old 02-18-2009, 11:41 AM   #21
saintseiyaz
Member Sales Rating: (4)
Member#: 81159
2000 GC8
PRB
very tempting.... so, which version is for a swapped turbo GC?
saintseiyaz is offline
Old 02-18-2009, 11:49 AM   #22
scubywagon
Member#: 65967
2004 WRX WGN 2.5
Java Black Pearl
You can count me in....let me know what info you need and I can send payment now..
scubywagon is offline
Old 02-18-2009, 12:23 PM   #23
Baay
Member#: 139645
07 WRX
UGM
Come on Nasioc!
just a few more people to get on the 99.99
Baay is offline
Old 02-18-2009, 12:25 PM   #24
bryant53
Member#: 145412
nice sign me up!
bryant53 is offline
Old 02-18-2009, 12:30 PM   #25
AlxSti
Member#: 94615
2017 VW GTI SE
8 people signed up in one day.. is this over on iwsti and clubwrx too? we should send some people over here if not..
AlxSti is offline
Closed Thread
Unbeatable Pricing on New Grimmspeed 3 Port Boost Control Solenoids! maperformance Accessories & Misc 385 06-15-2010 11:03 AM
FS: Grimmspeed 3 Port Boost Control Solenoid, New lickwid Engine/Power/Exhaust 3 01-18-2010 12:18 PM
GrimmSpeed 3 Port Boost Control Solenoid- In Stock! awdtuning.com TXIC Vendor Classifieds 5 07-13-2009 01:49 PM
FS: Grimmspeed 3-Port boost Control Solenoid Ditchthefury Engine/Power/Exhaust 12 05-10-2009 02:10 PM
New Grimmspeed 3 Port Boost Control Solenoids In Stock / Free Shipping! maperformance Accessories & Misc 7 02-27-2009 02:50 PM
