Brakes & Suspension Forum sponsored by The Tire Rack |
06-01-2010, 11:53 PM | #26 |
Member#: 108248
Vehicle:2006 WRX Black |
I agree, this is a good write-up! I have the STi adj. coilovers that are making noise, so I am going to do this soon and hope they werent a waist of money. Ill have to see how it goes...
07-03-2010, 02:10 PM | #27 |
Member#: 243972
one question...is there any particular type of grease to use?
07-06-2010, 10:13 AM | #28 | |
Member#: 145351
South East
Vehicle:0000 RIP 2006 STi 04 FXT / 89 SE30 |
Coilovers you can't do that to the coilovers different technology unless you meant STi "pink" struts. |
07-06-2010, 10:15 AM | #29 |
Member#: 145351
South East
07-06-2010, 10:20 AM | #30 |
Member#: 145351
South East
As far for my setup over month on those modified struts and everything so far so good. I was little worried about my front struts since when I drilled out those I found out they are not same like rear struts as far for the "teflon section" placement but everything seams ok only adding grease to the front struts is little bit harder bc there is less space to squeeze the grease. What is important no clunk what so ever.
07-08-2010, 02:10 PM | #31 |
Member#: 73055
Vehicle:04 STi White |
First, thank you hwy61 for the great writeup. The pictures really helped me understand the issue and prepare for the job. I repacked my rear struts this weekend. I decided to just repack with white Li grease instead of installing the fittings, although I did buy the fittings and a grease gun, hahaha. I chickened out on the drilling. If the issue ever comes back I will install the fittings. The job is pretty easy and if you work on your car much you can do it. It only took me about 2 hours to do the whole job and that includes getting interrupted by wife, kids packing off tools, etc. It also helped that I have removed and replaced my struts/springs a few times so I have a bit of experience.
The noise is obviously gone but I wanted to point out how much better my car seems to feel and drive and I haven't seen that noted much anywhere. It is much smoother and more predictable than before and seems to handle better as well. Maybe it's just me but it seems like night and day. Also, before the fix, when turning sharply left or right at slow but spirited speeds I heard clunking (or a rubbing sound) coming from what I thought was the front of the car and I suspected steering rack related. It was also rough and did not feel stable. However, after the repack of my rear struts this is gone as well. To me, this indicates that the clunking is something you need to fix for a variety of reasons including safety. Just my observations for what it's worth. I do have one question, though. Is this procedure also recommended for the fronts? Do they tyically develop clunk as well? I haven't heard much about that but I think they are a different design. Still, if this worked so well for the rears I'm wondering if I should do the fronts as well while I still have the spring compressor rented. Does anyone know how the fronts are designed as far as the damper, bushings, grease, etc.? Last edited by decaman; 07-08-2010 at 02:19 PM. |
07-08-2010, 03:32 PM | #32 |
Member#: 145351
South East
No fronts usually stay quite... I just did mine for giggles but if you are talking about re-greasing than I will say go for it but only if you have really good spring compressor. Front STi struts are PITA to reassemble with stock springs.
07-08-2010, 03:40 PM | #33 |
Member#: 73055
I have Espiler GT springs. Try those babies sometime. They are like 40% stiffer than stock or something. Hahaha! When I did them I used ropes in a come-along fashion. It worked well but was not the safest. This time I just rented (for free, mind you) the spring compressors to do it right. It's like 20 mins to drive over, pick them up from Kragen, and drive back home.
07-08-2010, 09:49 PM | #34 |
Member#: 73223
SCIC
Vehicle:2009 STI |
The fronts don't seem to have the side loading that the rear geometry causes. Never heard about stiction from the fronts.
07-08-2010, 10:58 PM | #35 |
Member#: 245634
Vehicle:2003 Impreza wrx wag Wrbp |
just curious, can you take the strut out of the strut body on a wagon like u can on the sti?
07-08-2010, 11:07 PM | #36 |
Member#: 73223
SCIC
Vehicle:2009 STI |
Nope.
07-08-2010, 11:13 PM | #37 |
Member#: 245634
piss was gonna put sti struts in wrx strut housing
07-09-2010, 02:47 PM | #38 |
Member#: 243972
http://i3.photobucket.com/albums/y66/1917-1911M/IMG_2955.jpg
ok so i snapped the one of the three bolts that are holding the strut into place... any one know where i could get that whole replacement part? |
07-09-2010, 02:59 PM | #39 |
Member#: 73055
You could just pick up a used tophat. That should be pretty cheap and people usually have those lying around. I don't remember if those bolts can be replaced easily or not.
How did you snap that bolt? It should only be torqued to like 14.5 ft-lbs. |
07-09-2010, 03:05 PM | #40 |
Member#: 243972
yeah i was tightening it...wasnt using a tourqe wrench...whats a tophat?
07-09-2010, 03:09 PM | #41 |
Member#: 243972
nvm dumb question....top hat...lol where do u guys think would be the easyest place to get one? can i get that on line somewhere
07-09-2010, 03:12 PM | #42 | |
Member#: 73055
http://forums.nasioc.com/forums/show...light=top+hats |
07-09-2010, 03:18 PM | #43 |
Member#: 243972
alright cool thsnks alot for the help
07-11-2010, 08:46 AM | #44 |
Member#: 234485
NESIC
Vehicle:2004 STI Rally Blue |
So you are saying you need a spring compressor for the front not the back struts? I'm doing the most research on what I need to do this job. The sound is really bad on my STI.
07-11-2010, 11:30 AM | #45 | |
Member#: 145351
South East
They are easy to replace you just need hammer Hit them from a top couple times and they popped out. I just replace all my studs on rear top hat bc I used 1" spacers to level my car. |
07-11-2010, 11:31 AM | #46 | |
Member#: 145351
South East
Well at least on my set which should be the same as yours. I have 04 STi stock struts/springs on my forester and to make my ride height even I have to use 1” thick spacers. With those spacers I have to use longer bolts so my top hat has to go. I was surprised when I popped my rear top hat and didn’t shoot across the shop :-) Anyway to answer your question yes I didn’t use any spring compressor for rear struts. |
07-11-2010, 06:55 PM | #47 |
Member#: 234485
NESIC
I removed the strut but I can't remove the nut at the bottom of the strut that holds the damper it just spins even with the spring assembled
07-11-2010, 09:49 PM | #48 | |
Member#: 145351
South East
Hopefully you didn’t mess up anything. … Anyway inspect the strut and then grab the actual insert from a top (with your spring removed) and pus down and twist , you should feel that strut will lock itself and then you should be able to remove/tight that nut. It’s hard to explain but that hole on the bottom is not round it has a flat section and same thing is on the strut insert little flat section |
07-12-2010, 01:00 PM | #49 | |
Member#: 234485
NESIC
07-12-2010, 02:27 PM | #50 |
Member#: 145351
South East
What did you use to tight that bottom nut? Just hand wrench or Air wrench you maybe fine. Can you take close up picture of your strut? I will also stop by tonight at the shop and look on my old 06 strut just for reference. If you can remove your insert and take close-up picture (bottom strut and threaded insert at the bottom)
Similar Threads | ||||
does 05 sti rear bumper and flares will fit 04 sti?? | davidsti1 | Interior & Exterior Modification | 2 | 08-11-2009 09:57 AM |
Rear diff/outrigger & shifter bushings installed | smurfwrx | Car Part Reviews | 7 | 08-05-2008 11:09 PM |
WTB or WTT: Mint STI rear seats, doorcards & PSM STI Trunk | Kromber2 | MAIC Private Classifieds | 3 | 05-07-2007 03:01 PM |
FS : JDM STi Recaro Seat, STi Rear Under Diffuser & JDM Acre Brake Pads!!! | outcast | SCIC Private Classifieds | 6 | 03-09-2007 01:46 PM |
FS:05 STI rear sway bar & bump for trunk! | 04blkbeauty | Tri-State Area Forum | 2 | 06-23-2005 12:05 AM |
