Welcome to the North American Subaru Impreza Owners Club Thursday May 25, 2017
Old 09-19-2010, 09:27 PM   #1
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
Dorothy from OZ, the XT
Default Lean Cylinder?
Sorry for the double post, but I think this is better suited here. I'm trying to figure out if this is what caused my piston to melt like butter. Here's the thread about it. I'm at a loss at the moment http://forums.nasioc.com/forums/show....php?t=2057556
340Duster is offline   Reply With Quote
Old 09-22-2010, 05:54 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by 340Duster View Post
I read mostly about cracked ringlands on the pistons, or spun bearings. It looks more like a lean condition on the cyl. Trying to figure out exactly what caused the erosion of the piston/ it melting to the bore. Sorry the second pic is from my phone.
bump for him, I just want to know what you guys think happened
Old 09-22-2010, 06:23 PM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
You got hella lean at the wrong time probably in boost. If you have an EGT gauge I'm sure you would have seen a big rise in temp before failure. Motoryder may have a thread somewhere about his melted piston adventure.
Old 10-01-2010, 09:40 AM   #4
yaya20
Member#: 130354
2011 535xi
Any more input? I had a very similar failure recently. My pics are in the linked thread in the OP.
I wasn't able to find much detail about Motoryder's melted piston.
yaya20 is offline   Reply With Quote
Old 10-01-2010, 09:53 AM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
It could possibly be a cracked ringland that started the mess. The cracked ringland will cause scuffing, later enough scuffing for blowby, then oil, misfires, pre-det, then major piston failure and melting.
You'd have to take the piston out, make sure the rings don't turn so you know where the gap ends are, then inspect the piston to narrow in possible causes.
Old 10-01-2010, 10:45 AM   #6
yaya20
Member#: 130354
2011 535xi
Yeah, the rings won't move since they are destroyed right by were the hole melted through. Not sure I could even tell if there was a local crack in the area now...
Old 10-01-2010, 11:45 AM   #7
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
That's exactly how mine looks. I still haven't been able to get in touch with my tuner to get the files from my tune emailed to me. And haven't sent my injectors off as I have been toying with going with a 68HTA.
If there was a cracked ringland it would have to be small. As in now gone in the torched section of the piston. It is hard to tell as the rings are now fused to the piston. Could just det cause the erosion/ melting? I ask because I imagine it as a force acting on the piston in a way that would "break" the piston not melt it like ours.
yaya20, what kind of pistons were you running?
Old 10-01-2010, 12:10 PM   #8
yaya20
Member#: 130354
2011 535xi
Wiseco
Old 10-01-2010, 12:12 PM   #9
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
^^^ With that being said, I find the ringland thing highly unlikely. With my stock cast one sure, but not with a forged piston like that. They both did however, melt about the same way. This is great
Old 10-01-2010, 12:13 PM   #10
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
He's my neighbor and its possible he didn't post the failure here. You need to be very hot to melt a piston like that, way beyond normal combustion temps. About the only thing I can think of that would allow that would be an extremely lean condition. Those where his findings also.
Old 10-01-2010, 12:20 PM   #11
yaya20
Member#: 130354
2011 535xi
I'm basically trying to work with the shop that did my build and tune as my car had 750 miles on it since rebuilding the bottom end. The more detail I can get, the better discussion I can have with them about covering my motor. So far as I can tell, I did not have any part failures that caused the lean condition.
Old 10-01-2010, 12:24 PM   #12
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
Have you had the tune looked at closely or by another tuner for a second opinion?
Old 10-01-2010, 12:56 PM   #13
yaya20
Member#: 130354
2011 535xi
Tricky situation, but no. Not yet.
Old 10-01-2010, 02:31 PM   #14
Lucky Strike
Member#: 196786
That damage is in no way caused by a broken ring or ring land. Its lean
Lucky Strike is offline   Reply With Quote
Old 10-01-2010, 10:34 PM   #15
col5555
Member#: 142017
Faulty injector
fuel system problem
tune
check all three
col5555 is offline   Reply With Quote
Old 10-01-2010, 10:53 PM   #16
Nuke209
Member#: 108089
NF Performance
get the injectors checked out
what injectors?
Old 10-02-2010, 10:49 AM   #17
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
This looks definitely lean and might be caused by pre ignition due to being overly lean. There are no DET marks on the piston crowns. Pre ignition is the worst that can happen. Temperatures and cylinder pressures can go skyhigh in the blink of an eye. Many times it cannot be heard in the DET cans and no knock shows up. Even AFR may not show excessively lean as most people measure average AFRs of all 4 cylinders.
Most likely faulty injector or perhaps a clogged one. Also check wiring to make sure injectors are ok and clean mating connectors, etc.
Good luck on the rebuild.
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 10-03-2010, 01:50 PM   #18
yaya20
Member#: 130354
2011 535xi
I was running DW850s, they have been inspected and given a clean bill of health
Old 10-03-2010, 05:35 PM   #19
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Detonation in that cylinder, look at all the pitting on the piston dome. probably cracked a ring land and it was burning oil. When you burn oil with your gas you end up with very little octane, which would cause the cylinder to start to run super hot and melt.
Check your knock correction range, if it was around the stock setting of 6100 and you were revving to say 6800-7k that's about 1k rpms of no knock control, so it would not pull any ignition, or show a knock count. Not to mention it would be in the range were the td04 is pushing some seriously hot air which would tend to detonate a lot.
What was your timing and wideband AFR.. Hopefully you had a wideband or were tuned with one at least.
Looks somewhat familiar... I'd start by getting your injectors checked out. Looks like cylinder 3???
Here is mine:
Lots of timing or very lean tune or both.. Look at your number 1 piston as well.. Corner nice and shinny. Your EGTs were probably pretty high when that melted. If it was a bad injector only 1 piston would look like it took some serious heat.
Old 10-04-2010, 04:17 PM   #20
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
bump for more answers?
berge56 is offline   Reply With Quote
Old 10-04-2010, 05:19 PM   #21
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
I think the answers are in the post above
Old 10-04-2010, 05:25 PM   #22
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
Like jkopinga said; pre-ignition. Melts holes in pistons really quick. Probably happened due to a lean condition and a lot of knock.
This is one of the better write-up on pre-ignition and detonation online:
http://www.streetrodstuff.com/Articl...ne/Detonation/
AQ Motorsports is offline   Reply With Quote
Old 10-04-2010, 06:29 PM   #23
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
While my piston wasn't on a boosted application it was melted from Detonation.
It was a 13.5 compression engine on 93 octane but I let a moron ride it and he just kept WFO till it melted
2002WRXSTi is offline   Reply With Quote
Old 10-05-2010, 06:19 AM   #24
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Have had one Spec C engine blow the 2nd time now :-( It's probably also caused due to pre ignition. Checked everything. Fuel pump, injectors, etc. etc.
Had the DET cans on and nothing to be heard until there was suddenly a big cloud of smoke and oil splashing everywhere in the engine bay :-(
**** happens!
Cheers,
Jasper.
Old 10-05-2010, 10:30 AM   #25
yaya20
Member#: 130354
2011 535xi
Good read, thanks for sharing that article.
**** happens!
Cheers,
Jasper.
Forgive my noobness, but if it were pre-ignition and not detonation, wouldn't the hole be in the center of the piston rather than at the bottom of the cylinder near the exhaust valves?
System too lean, Cylinder 4 misfire and knocking sound... KarmaWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-22-2007 07:47 AM
And the lean cylinder is ? yzblazr Newbies & FAQs 12 04-07-2006 09:53 AM
Any real truth that the 2.5 RS runs lean on 1 cylinder? cjfike Normally Aspirated Powertrain 0 04-29-2005 12:14 PM
the old lean cylinder White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 1 06-11-2004 02:38 AM
Which cylinder was running lean? IMPBOY Normally Aspirated Powertrain 2 11-18-2000 12:15 AM
