Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 10-23-2010, 03:20 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default IT RUNS!!! - My 500whp build - Element motor and Moore Performance Twin Scroll Kit!
Update, June 14th, 2014
My final graph and the official close of my project:
Note: The red lines are my car on April 17th, 2014 and the dashed lines are another customer's 2010 Stage 2+ WRX for a comparison.
It's official, my 500whp build project came to a successful conclusion on June 13th, 2014 after 3 years, 7 months, 22 days! This was obviously WAY longer than the original six months that I predicted in late 2010 but better late than never I guess. If you're wondering, it only took three motors (the original Element motor plus one that was rebuilt twice), three tuners, three different types of injectors, a few EMS platforms and many TENS of thousands of dollars but its finally done!
The car made 510wtq/508whp which are fantastic numbers for an EFR 7064 with a 1.05 hot side. However, the real story is not in the peak numbers, its in the spool characteristics and SUPER fat power band. The car is at or above 300wtq for nearly 5000 RPM and over 400wtq for nearly 3000 RPM which makes it feel pretty amazing. I cant thank Moore Performance, Element Tuning, Budds Auto Parts, Innovative Tuning and so many others enough for helping me over the past few years!
Here is my final mod list (Updated Today, June 14th 2014):
STI Power Mod List:
Engine:
Element Tuning Pro Comp motor w/8500RPM Redline
Manley 9.8:1 compression pistons
Element Tuning rods
ACL bearings
Cosworth 280 Cams
Element "Big Valve" Heads
Element competition valve springs
+1mm stainless intake valves
+1mm inconel exhaust valves
Mild head work (5 angle valve job, bowl blend, etc)
Cosworth billet aluminum timing belt guide
Element modified STi 12mm oil pump
Killer B Motorsport oil pickup
Killer B Motorsport oil pan
Performance Parts:
Stock ECU with Access Port v2 (Tuned by Innovative Tuning in Buffalo, NY)
Borgwarner EFR 7064 twin scroll turbo
APS DR725 FMIC
Moore Performance DR725 adapter pipes
Moore Performance twin scroll header
Moore Performance T4 twin scroll up-pipe/adapter (JDM TS to T4)
Dual TiAL MV-S 38mm Wastegates
Moore Performance down pipe
Moore Performance mid pipe
Cobb Tuning muffler
Injector Dynamics ID1300 injectors (1300cc)
Aeromotive A1000 fuel pressure regulator
Aeromotive A1000 fuel pump
Aeromotive fuel pump controller
Custom home-made electronics to provide a boost referenced input for the A1000 controller
JEGS fuel distribution block
JEGS 100 micron fuel filter
-10 PTFE fuel line between the A1000 and the distribution block
-6 PTFE fuel return line
2.2L in trunk surge tank
Walbro 255lph fuel pump (feeding the surge tank)
25 Row Setrab oil cooler w/-10 AN Lines
200F Mocal sandwich adapter
TGV deletes
GrimmSpeed phenolic Spacers
Element Tuning competition breather can
Mishimoto racing radiator
Exedy twin disk racing clutch (dual six pucks)
Suspension/misc stuff:
STI Suspension Mods:
245/17 Starspecs on stock 8" BBS rims
Ohlins Flag Coilovers with 10k front springs and 8k rear springs (corner balanced)
Ohlins Front Camber Plates
Ohlins pillow ball rear top Hats
STI Pink Pillow Ball Trailing Links
Whiteline ALK
Whiteline Bump Steer/Rollcenter Kit
Whiteline Subframe Lock Bolts
Cobb F&R Sway Bars
Cobb Endlinks
Cobb Adjustable Rear Swaybar Mount
Kartboy Rear Subframe Outrigger Bushings
TurnIn-Concepts Rear Diff Mount Bushings
Custom fender braces
STI Front Strut Tower Brace
STI Rear Strut Tower Brace
STI Group-N Motor Mounts
STI Group-N Transmission Mount
STI Group-N Pitch Stop Mount
For historical purposes, here are a number of my old updates and issues listed from earliest to most recent:
Dec 26th, 2011:
I know this thread has been around for a very long time but allow me to give a few cliff notes to those who haven't been reading it for the past year. I suggest you start by reading my original post below and the coming back to this point right here to get filled in on the 12 months that followed my original post.
To begin with, the experimental Evo style turbo kit didn't work well so that was totally abandoned in late May of 2011 and replaced with an amazing twin-scroll rotated kit from Moore Performance. There were a number of issues with the car and the new turbo that resulted in two failed tune attempts in June and July of 2011. With almost the entire season over I went back to element one last tune attempt in late August of 2011 and the block cracked on the fourth pull on the dyno. The damage from the crack was catastrophic resulting in the total destruction of the long block, turbo and nearly everything close by in the engine bay. The destruction can be seen on page 18 starting at post 880. My best guess was that the block was compromised from the very beginning and just waiting to fail. Needless to say, 2011 was a pretty bad year for me and my project.
After a ton of soul searching and lots of advice from many people (most notably my wife) I decided to keep my STI and give the project another chance. With a ton of help from Buddsautoparts.com I sent Element a full complement of engine parts for them to turn into a new Pro Comp motor. Phil didn't provide the parts that exploded on the first motor but he did give me pretty good break on the second one. After what seemed like forever, I took delivery of my second new motor on Dec 22nd and work started on Christmas Eve of 2011. The rebuild story begins at post 1086 on page 22. I plan on making a few very minor changes to my setup which are mostly bug fixes and the rest will simply be bolting the car back together just as it was.
April 2nd, 2012:
The car finally runs again! I put a new Element motor in and the start-up was at post 1279 / page 26.
August 2nd, 2012:
The car seemed to run fine through April of 2012 but as the break-in process neared the 500 mile mark I noticed the car was starting to have issues. The idle was really rough and the car was smoking pretty bad so it was really obvious that things were not right. I pulled all four plugs out to find that the two from the drivers side were totally blacked out while the two on the passenger side looked lean. [Check this post for info on the issue: Post 1419] Fearing the worst and with stress and anger taking its toll I parked the car in the garage for about two months and didn't even look at it. Thankfully, a few of my local friends gave me a hand in mid July which motivated me enough to fix the car. The problem ended up being something so simple that I intentionally overlooked it.
Unbelievably, I had two bad fuel injectors on the same side of the motor! The injectors on Cyl 2 and 4 were leaking while the injectors on 1 and 3 were working perfectly. Even though the very first thing that I suspected when I saw the badly fouled plugs were bad injectors, I didn't go through the steps to troubleshoot them. I found it very hard to accept that two injectors were bad at the same time let alone two on the same side so I chased my tail for weeks before letting the car sit for months. I was running down theories regarding fuel line issues (uneven pressure), AVCS problems and wiring which obviously made no difference.
As a final "Hail Mary pass" I swaped fuel injectors, change the engine wiring harness and re-routed my fuel lines. [Info here on the change in direction: Post 1731] Obviously the injectors were the only thing that ended up having any effect but that had to be proven for be to believe it. Once I had all the parts swapped I was stuck with the dilemma of trying to get the tune adjusted on my Hydra. There was no possibility of getting the car down to Element Tuning for Phil to tune on short notice. In addition, I was honestly very reluctant to spend the $1500 or so needed to trailer the car to Washington DC after having so many issues the year before. I didn't doubt Element, I doubted the car and I just couldn't do it.
I made the decision to swap the factory ECU back in so that I could have a local tuner take a shot at it while it was at my house. This process was some what of a pain in the butt because it required tons of work to get the related pieces of the car back to stock. Sensors, wires, meth parts, etc all had to come out for the factory ECU to go in. Fortunately, this all worked out pretty well as I was able to resolve the issues in my own garage without spending thousands of dollars. [Car is confirmed to work again: Post 1821]
Feb 17th, 2013:
Since I just cant get enough abuse, I have decided to play the game a little longer. Just after the August 2nd post above I was informed (by Phil from Element Tuning) that my engine block was likely to fail at high power levels due to a quality control issue related to Subaru's post-2011-Japan-Tsunami engine supply chain. Apparently the older blocks could hold power up into the 500whp range without an issue and the new blocks were cracking in the upper 300whp range. This was clearly not the issue with my motor that cracked and blew up in August 2011 as that block was much older.
Since I had just gotten over the ridiculous double fuel injector failure issues I posted about on Aug 2nd, 2012 only to find out that my block was possibly a time bomb I was pretty pissed. I decided to press on at wastegate boost pressure and finish out the year on low power. The car ran ok (lets say 75%) on the AccessPort until it started to get cold outside. Once the daily temp hit 50F things took a major turn for the worse and the car became un-drivable. This was obviously some kind of temp compensation issue and we were never really able to work it out.
The move back to the factory ECU wasn't something that I was extremely excited about to begin with. I did it in an attempt to figure out my fueling issues locally and I felt that anything else was a bonus. Had a not briefly moved to the factory ECU / AP I would most likely have parted the car out and moved on to something else. Since I was able to accomplish my goal of sorting out the mechanical pieces of the car in my own garage and finish out the year (even if it was only on low power), I feel that I made the right decision.
Since the car wasn't drivable as it was I made the pretty easy decision to move back to the Hydra (assuming that I kept on with this madness). However, I was faced with a much harder decision related to the motor. As I mentioned, Phil was convinced that it was only a matter of time until my block cracked again. Since I had no working ECU, a nearly impossible setup to tune and a time bomb motor, my old Cobb stage 2 setup form 2006 was looking pretty good. But as I said, I apparently enjoy the abuse so I decided to go "all in" just one more time.
In the November of 2012 I sent my Hydra 2.6 to Hydra USA and got it upgrade to a Hydra 2.7 with Flex Fuel support. Immediately after getting the Hydra back, I loaded my car on my trailer and took it down so that Phil could do a low boost road tune. No joke, 30 minutes into the tuning session with Phil and the car was running better than it had in two years! The sluggishness, slow boost response, roughness and drivability issues were GONE. Needles to say, I was extremely happy. The hardest thing at this point was coming to terms with the fact that I had a car that was running perfectly for the first time since October of 2010 and it needed totally torn apart to fix the block defect.
After getting the car home I pulled the motor out got it ready to take down to Element so that they could apply their "closed deck block reinforcement" plus re-blueprint the motor just to be sure that everything was 100%. The motor will arrive at Element on Feb 19th, 2013 and when it will be ready to pick up is anyone's guess. With a little luck it will be done before the end of march and the car will be back together by mid April 2013. I really hope this is it because I don't think I have another round of suffering left in me.
Nov 3rd, 2013:
I have had a pretty frustrating experience with the Hydra 2.7 and I am getting lots of advice to pull it and go back to the stock ECU/AP again. For whatever reason, the car likes to suddenly run at dramatically different AFRs randomly. Phil thinks the issue is related to the fuel system or possibly electrical but I am not sure thats the case.
March 29th, 2014:
I have my mind made up, I am moving back to the factory ECU AND STAYING THERE. I have really enjoyed working with Phil over the years but the frustration with the Hydra has hit a point where I cant continue. With the car already setup to run either the factory ECU or the Hydra, this shouldn't take much effort. At Moore Performance's advice, I am going to take the car to Innovative tuning in Buffalo, NY. The owner, Mike has a great reputation and I am really looking forward to the simplicity that running the factory ECU will bring. After all, I am at a point where it couldn't go any worse that what I currently have.
April 17th, 2014
Check out post 2890! I got the car tuned at Innovative and it produced a really amazing graph! The power is great and the spool-up is "super hero" like but unfortunately, it is however a modded Subaru so its still got issues as seen in post 2903. Hopefully I will get the remaining problems taken care of soon.
June 13th, 2014:
At the advice of both Moore Performance and Innovative tuning, I replaced the front O2 sensor and alternator. I also added a bunch of grounding wires and switched to much smaller ID1300 injectors. The results are PERFECT! (see post 2938) I couldn't be happier with the car right now and I am really glad that I stuck in there for the long haul.
P.S. If you're thinking of spending $100k on a car, it shouldn't be a Subaru!!!!!!!!!
dexterous is offline   Reply With Quote
Old 10-23-2010, 03:21 PM   #2
dexterous
Member#: 23553
2014 WRX - Daily
This is the original beginning of this thread:
I finally took the plunge and purchased a built motor for my 2005 STI! I will be updating this thread as time goes on so check back for more info and picts.
In April 2010 my car made an amazing 461whp and 473wtq on the AMS dyno thanks to Phil from Element tuning. The setup included my stock long block, a APS DR725 FMIC, a GT-Spec EWG kit, a Dom3 XTR turbo, a Hydra and a Hydramist meth kit with a 50/50 mix among many additional supporting mods. Obviously a stock motor would never last making numbers like that so I knew that I would need to address the situation this winter. Thankfully my stock motor hung in there and lasted through the entire season.
My plan for the new motor setup was honestly not too crazy but you know how that always goes. I wanted to get a fully built bottom end capable of handling lots of power coupled with head/cam upgrades so the motor could breath. I also wanted to be able to spin the motor higher than the stock redline just to have a bit more room in the rev-range when needed. After careful consideration I decided to go with one of Element Tunings built motors because they have a long history in the Subaru community, they have a very successful racing program to serve as an R&D platform and very importantly, they are within a reasonable driving distance form my house.
Over the past several months I have literally spent hours on the phone with Phil discussing my goals, motor plans, needed supporting mods, etc. I ended up with an Element Pro Comp motor which is an exact clone of the motor that Phil uses in the Element Tuning time attack race car. The primary features of my new motor include custom Manley forged pistons, Element rods, Element competition valve springs, cosworth cam shafts, +1mm stainless intake valves, +1mm inconel exhaust valves and some head work (5 angle valve job and bowl blend). Phil says this motor can withstand 800 crank HP and an 8500RPM redline but my philosophy is to not run this thing to 10/10ths of its capacity for reliability sake. Even though I have no plans to test its true power potential or its max RPM its nice to know its there if I ever need it.
I also started out not wanting to change anything but the motor and the needed fuel system upgrades until I had a talk with Ryan Moore from Moore Performance. Ryan showed me their line of twin scroll turbo kits which utilize turbos originally meant to fit the stock location on an Evo 9. The availability of reasonably priced twin scroll turbos with massive power output potential was just too tempting to pass up. In a matter of days I should be taking delivery of one of Ryan's full kits including a modified twin scroll Evo 9 framed FP Red featuring a 65lb wheel and a 10.5cm hot side. Phil from Element feels that my combo of turbo and motor on 93 pump and 50/50 meth should put the car in range of 550whp. Nobody has ever run this turbo on a Subaru let alone an Element motor so only time will tell.
During my conversations with Phil from Element he repeatedly stressed how important adequate fuel supply was going to be for my new setup. Based on my turbo size and platform (2005 STI with side feed OE injectors) Phil suggested that I look at Ultimate Racings 1260cc top feed conversion kit for the 04-06 STI. The UR kit features a special injector setup that allows a larger injector to be placed directly into a normal side feed TGV riser. The kit also features URs custom fuel rail made specially for the injector so the fitment should be pretty good. I have paired the UR hardware with a Aeromotive A1000 fuel pump, a Aeromotive fuel pump controller, a Aeromotive FPR and a 2.2L trunk mounted surge tank. I have decided to run a -10 stainless line from the A1000 fuel pump to a distribution block under the hood. The distribution block will then fan out to -6 lines feeding each fuel rail in parallel. Phil says that I can easily keep my stock fuel return line on this setup as he has done that many times before.
The first step was pulling out my stock motor. Here's a funny pict of my daughter Abby and I standing in the engine bay.
Old 10-23-2010, 03:42 PM   #3
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
give that kid a wrench and put her to work!
slowmike is offline   Reply With Quote
Old 10-24-2010, 01:55 AM   #4
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Sweet. You seem to know what you're doing. Gonna be an awesome build! Looking forward to seeing some numbers.
Old 10-24-2010, 02:00 AM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Oh and the slip joints on that header... don't know if that's a good idea?
Old 10-24-2010, 02:12 AM   #6
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
sounds like a beast! good luk!
hustleshark206 is offline   Reply With Quote
Old 10-24-2010, 07:53 AM   #7
dexterous
Member#: 23553
2014 WRX - Daily
Well, all I know is that in addition to being designed by Moore performance, the headers are built by a US company (100% made in the USA) that has a lot of experience. I think the slip fit based design came from them not Moore but I don't know for sure. It's also worth mentioning that my old Borla header did not have slip fits and it cracked a few times. On the other hand, my GT-Spec header had slip fits identical to the Moore header and it held up very very well.
Old 10-24-2010, 08:00 AM   #8
dexterous
Member#: 23553
2014 WRX - Daily
Thanks, I will need that luck. I have been modding Subarus for about ten years and this is going to be my final project so I really hope it works out. I have a pretty good idea what I am getting my self into so that helps a lot.
Old 10-24-2010, 08:01 AM   #9
dexterous
Member#: 23553
2014 WRX - Daily
Soon man!
Old 10-24-2010, 11:12 AM   #10
MartinSTi05
Member#: 145145
2006 wrx STi
The Moore kit looks interesting. But I do not understand why you would choose to slave yourself to Mitsu framed turbos? You have many more options if you go with a T4 flanged kit.
MartinSTi05 is offline   Reply With Quote
Old 10-24-2010, 11:34 AM   #11
dexterous
Member#: 23553
2014 WRX - Daily
After evaluating my project a bit, I have come to the conclusion that the most likely area for me to experience an issue is in my fuel system. While I have years of Subaru wrenching experience, I have very minimal experience with advanced fuel systems. I am pretty concerned that making a rookie mistake with gasoline and super expensive components could go horribly wrong very quickly. As a result, I have read just about every thread on NASIOC related to advanced fuel systems similar to what I plan to install. I have also spent a good deal of time on the phone with my tuner Phil from Element as well as the Aeromotive pre-sales and technical support hot-line. On a quick side note, both Element Tuning and Aeromotive provide excellent technical support and have done a great job providing me with all the info that I have needed to make informed decisions for my car.
The result of about a month of research and several revisions is as follows. If you are experienced in this matter I would appreciate it if you could provide me with any guidance that you feel would be useful. In addition to a critique of my design/plans, I would love to hear about any issues you ran into, including, what didn't work and general advice you could offer. Thanks.
Old 10-24-2010, 11:40 AM   #12
dexterous
Member#: 23553
2014 WRX - Daily
I don't view my self any more of a "slave" as I would with any other any other platform but I understand your concern.
Here are a few reasons:
-Cost (attractive)
-The kit provides direct compatibility with my existing hardware (APS, etc)
-The turbo selection is excellent (Twin scroll black, red, white, etc).
Old 10-24-2010, 12:37 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Looks like you've got a good build going on here! If there's anythign we can do to help out please don't hesitate to ask.
Old 10-24-2010, 01:42 PM   #14
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
im very curious about this header, downpipe, turbo combo as it adds another option to the list.
subscribed.... this looks to be a very well sorted build....
timeXlost is offline   Reply With Quote
Old 10-24-2010, 02:26 PM   #15
MartinSTi05
Member#: 145145
2006 wrx STi
Any plans for fuel filters?
Old 10-24-2010, 04:08 PM   #16
dexterous
Member#: 23553
2014 WRX - Daily
Well, that's a great question and the answer is no. However, this is something that I would really like to discuss. Based on a month of research, the only thing that adding additional filters seem to truly help with is burning up A1000 pumps.
The way I see it, the car is an 05 so the fuel pump has a filter sock on it from the factory. Obviously I am going to introduce a significant amount of new and dirty fuel system hardware between the surge tank and the new rails. Its my plan to carefully wash and purge all of out the dirt, dust, etc from this stuff before I install anything. If anything, an aftermarket the fuel filter should go right before the fuel rails (like a factory 04 setup) to catch all this stuff. To me it seems like putting a filter directly after the A1000 kind of causes it to miss the boat.
Obviously my opinion was formed solely by research and talking to various people about the situation. For example, Phil from Element never puts additional filters in the setups that they do unless requested by the customer. I would love to hear what you can add to this.
Old 10-24-2010, 04:17 PM   #17
dexterous
Member#: 23553
2014 WRX - Daily
You must have radar or something because I am actually installing the new pickup and pan right now! Thanks for stopping by because I do have a few quick questions:
Whats the new suggested oil fill capacity with the pan installed and where will this show up on the dip stick?
My car is a 2005 STi but the actual block that I had built was sourced from another car (possibly a different year or even another vehicle like a Forrester and all I know is that its a 702 casting. I purchased the pickup kit for a 2005 STi back before I knew that I was going this route and I it just occurred to me that there's a possibility that something may not fit. What can you tell me about my situation?
Finally, several people have suggested that I use this product for attaching the new pan. Is this the right route?
Old 10-24-2010, 04:50 PM   #18
MartinSTi05
Member#: 145145
2006 wrx STi
On my A1000 I installed a -10 Aeromotive 100 Micron SS element ball valve filter to spare the pump and a 10 micron filter post pump. You are probably right about the in tank sock, however I went with a fuel cell, which removed that as an option.
Prior to starting your system a good purge will take care of any dust, line lube etc. Start by taking the two 5/16" soft lines off the inlet side of your fuel lines and let the system run about 1 gallon into a bucket. After that take the return line off the surge tank, reconnect the rails and let the system pump another gallon of fuel out the return line and into a bucket. Then take the two gallon bucket of gas and dump it in the lawn of a neighbor you dislike. This should ensure a clean fuel system prior to startup.
Old 10-24-2010, 05:09 PM   #19
dexterous
Member#: 23553
2014 WRX - Daily
...You are probably right about the in tank sock, however I went with a fuel cell...
That makes perfect sense. If I went that route I would be doing the exact same thing.
Prior to starting your system a good purge will take care of any dust, line lube etc. Start by taking the two 5/16" soft lines off the inlet side of your fuel lines and let the system run about 1 gallon into a bucket. After that take the return line off the surge tank, reconnect the rails and let the system pump another gallon of fuel out the return line and into a bucket...
This sounds like an excellent idea. I think I am still going to try to clean everything out prior to installing but I am going to do this too.
Old 10-24-2010, 05:32 PM   #20
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I really want to see what a suby can do with the EVO TS turbo
When r you getting tune?
Old 10-24-2010, 05:44 PM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
lol. I don't know about radar, but I do like to follow our products when they pop up in threads and journals. So here I am
There have been a few revisions of oil pans since the first release, but you can expect to be at least 1 quart (5.3 total) over where you were with the stock pan.
As long as it's an EJ series motor you're all set. Both pickup and pan will work just fine. When you purchase a pan or pickup from our website you have to choose what year/model, but that is only for historical data for us. The parts are universal across all models (Forester, Legacy, Outback or anything else that uses EJ series motors).
I use Permatex red when doing pan install/pickup installs, but there are several other types know to work just as well; ThreeBond (Subaru's brand), HondaBond (Honda's brand that's exactly the same as ThreeBond), FujiBond, and probably a couple others I'm not remembering right now. IMO what's going to give you a leak free reliable seal is cleaning the block and pan flange REALLY well and letting the gasket set overnight before putting in oil or heat cycling.
Another install tip I've learned, if you're doing his install with the motor in the car, is to put the liquid gasket on the block. It's much less of a mess than when you put it on the pan.
Old 10-24-2010, 06:28 PM   #22
dexterous
Member#: 23553
2014 WRX - Daily
Thankfully I have the motor on a stand upside down so I dont have to do it in the car. I have the block and the pan flange cleaned pretty well. I gently scraped the block with a razor blade and then cleaned both sides with alcohol. I will hit everything with alcohol one more time before I actually put the pan in place to be totally sure.
How important is torquing the pan bolts? I dont have a wrench that goes below 5ft/lbs.
Old 10-24-2010, 06:30 PM   #23
dexterous
Member#: 23553
2014 WRX - Daily
Its going to be a while, I just picked up the motor this week and I am still waiting on most of the fuel system and the turbo kit.
Old 10-24-2010, 07:03 PM   #24
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
-Cost (attractive)
Cost?!? isnt this kit like 2.5k not even including a turbo??
You can easily get other kits to fit with no mods or very little
turbo slection is even better with a t3 or t4 framed turbo
I 100% would love to see evo8/9 turbos on subarus but not at that price tag. Im every excited to see your results regardless tho
Goodluck
Old 10-24-2010, 07:54 PM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Lucky you, it's much easier that way! Sometimes I'll use a fine scotchbrite pan to remove ALL old gasket, and cleaning with alcohol is good too.
The biggest mistake people make when installing the pan (more so on the OEM pan) is overtightening the bolts. With our pan you're fine with 5ft/lbs, that's what we recommend. On an OEM pan once you exceed 5ft/lbs the area between each bolt actually begins to lift, potentially leading to a leak. What's important to remember is that the pan bolts don't do much more than hold the pan in place until the gasket/adheasive cures. Once the gasket cures the pan isn't going anywhere.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
