Welcome to the North American Subaru Impreza Owners Club Thursday January 24, 2019
Old 01-16-2011, 08:52 AM   #1
jh.
Member#: 263340
2011 4DR STI
Default DIY - Boost gauge in 11' STI
I didn't know if there was one, so I just made one....
DIY - Installing a boost gauge into a 11' STI
1. Started off with the wiring from the gauge. Decided to do it right and keep it clean.
So I used fuse taps and heat shrink.
After 3 more, the black wire is GROUND.....
2. Next is to take off the intercooler.
- 2 bolts on either end the intercooler
- 2 breather hoses on the left side
- 1 breather hose on the right
- 2 bolts for the BPV
- 2 hose clamps (throttle body and turbo)
3. Time to run the wires through the fire wall. I first started with the correct way, through the gromet, but had
a hard time. So I went through the heater core hose gromet. Make a slit or a hole and push it through. It will come out
just to the right of the gas pedal.
Excuse the ugly looking slit, but I pushed in the little flap when I was finished. It looks better and protects the
wire from the sharp edges.
The final product of the solenoid and wiring all wired up and tied in nicely.
4. Next is to reinstall the intercooler. Then install the "T" tap for the vacuum source. Creativity comes in now...
5. Now route your vacuum line from the solenoid to your "T". As you can see I followed the brake booster vacuum line.
6. Next we fiddle with the wires and which fuses to use...
Constant 12v - Fuse # 3
Switched 12v - Fuse # 24
Illumination/Dimmer - Fuse # 16
Ground is ground...I used the bolt holding the dash to the firewall on the left side of the dash. Easier than the one
tucked behind the fuse panel.
7. Now mount your gauge where ever you like. I mounted mine on the left side of the cluster.
I routed the electricals through the steering column. I hid the peak/warning button in the fuse panel cover.
Now plug everything in and tie all your wires up nicely.
Wahhhhllllaaaa and your done.
Night shot...Ill get a day one tomorrow!
jh. is offline   Reply With Quote
Old 01-16-2011, 09:14 AM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Any chance you can get a video of the startup sequence, both straight to on, and one where you stop at ACC until it does a sweep? Good write up, BTW.
Old 01-16-2011, 09:17 AM   #3
jh.
Member#: 263340
2011 4DR STI
Sure ill try it out tmr. So on the second vid, you want me to turn to ACC and wait for the sweep to stop. Then start the car and see if it does the sweep again?
Old 01-16-2011, 11:33 AM   #4
waramp
Member#: 251366
STI IAG Built Block
Lexus LFA Pearl White
Nice j!
When you coming out to a meet
waramp is offline   Reply With Quote
Old 01-16-2011, 03:27 PM   #5
jh.
Member#: 263340
2011 4DR STI
Originally Posted by waramp View Post
Nice j!
Ill try to make it out whenever there is one.
Old 01-16-2011, 05:55 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, exactly! Thanks!
Old 01-16-2011, 10:57 PM   #7
cabikejumper
Member#: 226604
2000 Mustang GT
Very nice
cabikejumper is offline   Reply With Quote
Old 01-16-2011, 11:04 PM   #8
jh.
Member#: 263340
2011 4DR STI
Alright videos are done. What can I use to upload them? Something free without registering...all that bs
Old 01-17-2011, 08:37 AM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Just get a Photobucket account. Then you can actually go back and find your stuff later, and it won't just disappear someday. Free and easy to register.
Old 01-17-2011, 11:35 AM   #10
jh.
Member#: 263340
2011 4DR STI
Damnit! im too lazy to register haha, I guess I have to. BTW it does not sweep again nor reset. Everything works the way it should.
Old 01-17-2011, 11:45 AM   #11
Sp2Pilot
Member#: 267212
2015 FXT
Was removing the intercooler absolutely necessary? Or did it just make it a little easier to get to the firewall grommet?
Sp2Pilot is offline   Reply With Quote
Old 01-17-2011, 07:29 PM   #12
waramp
Member#: 251366
STI IAG Built Block
Where's the cheapest place to get those fuse taps?
Old 01-17-2011, 07:38 PM   #13
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
awesome diy!!
nighthawk06si is offline   Reply With Quote
Old 01-17-2011, 09:22 PM   #14
jh.
Member#: 263340
2011 4DR STI
Yes it is absolutely necessary to remove the intercooler. It is very easy to remove. I had a very very hard time going through the factory gromet hole. So I went through the heater core gromet. Im a mechanic so I know where to go through.
Cheapest would probably be somewhere online...like those uber cheap electronic parts websites.
I got mine at lordco (work discount). Canadian tire has them too, but they charge an arm and a leg
Originally Posted by nighthawk06si View Post
awesome diy!!
Thanks! Videos will be up!
Old 01-17-2011, 09:47 PM   #15
jh.
Member#: 263340
2011 4DR STI
http://s1135.photobucket.com/albums/m628/jordanhsieh/?action=view&current=1.mp4
http://s1135.photobucket.com/albums/m628/jordanhsieh/?action=view&current=2.mp4
Old 01-17-2011, 10:17 PM   #16
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Hope you don't mind the thread jack, but it depends on what grommet you go through as to whether or not you have to remove the intercooler. I ran mine through a grommet in the fender and I found it to be very easy. Photos and description can be found here (not my post):
http://forums.nasioc.com/forums/show...07&postcount=6
You don't have to remove anything in the engine bay or cabin. But you do have to open up the fender liner. I jacked up my car and took off the tire to give myself more room. Once I had it open it was probably the easiest routing of wire through a firewall that I've ever done.
Thanks for the video! My car definitely doesn't function like yours when I stop at the ACC position, it fully turns off and back on once I turn the car on. On the plus side, when I stop at the ACC position the Defi sweeps at nearly the exact same time as the OEM gauges.
Can you confirm this is how you wired yours?
My power wires are set up the exact same as yours, but my Illumination wire is going to fuse #14. The dimmer function seems to work fine, so I don't think that's the issue. What do you think my problem could be? Is the WRX wired differently than the STI (I don't think this is the case)? Or maybe the Defi always does that (I don't think this is the case either)?
Illumination/Dimmer - Fuse # 14
Old 01-17-2011, 10:24 PM   #17
jh.
Member#: 263340
2011 4DR STI
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 24 - AUDIO UNIT
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
Are the WRX's fuses the same?
Also can you tell me how many wires you need to connect from your defi harness?
On my STRI harness I have 4 wires to connect.
Old 01-17-2011, 11:16 PM   #18
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, those fuses are all correct. I moved my Illumination wire to Fuse #16 and it still does the same thing. My gauge is wired up just like yours.
My car does only have 3 wires + ground. Does yours have an additional wire? What is it for, and what is it connected to?
Old 01-18-2011, 01:54 AM   #19
jh.
Member#: 263340
2011 4DR STI
Nope I also have 3 wires + ground.
Constant 12v
Switched 12v
Illumination
Ground
Are you running the BF series or the one where you need the brains too?
Can you shoot a video?
Old 01-18-2011, 08:18 AM   #20
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I have the red racer. No control unit needed. Just plug into the back of the gauge.
I will try to shoot a video tonight. What I am seeing is exactly how people described the double sweep on the older cars when they wired Defi gauges into the ACC line instead of the IGN line.
Old 01-18-2011, 11:21 AM   #21
foolycooly
Member#: 260545
2011 WRX Limited 4dr
anyone have any experience installing the SPT boost gauge? I wasn't able to get it on my '11 wrx due to backorder, but am interested in purchasing it and getting it installed through the dealer. Any idea how much labor would run me?
Thanks.
foolycooly is offline   Reply With Quote
Old 01-18-2011, 07:31 PM   #22
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I found this link, and it looks like it is describing the solution to my exact problem:
http://legacygt.com/forums/showthrea...86#post3172286
It says to use Fuse #26 for the IGN activated signal.
So, this is how I had it wired up before:
The boost gauge would sweep when I turned the key to the 2 position (the OEM gauges don't sweep until the 3 position), and then again when I turned the car on.
Then based on the post from LegacyGT, I changed the orange wire to the IGN fuse:
Switched 12v - Fuse # 26 - IG2
Now the boost gauge does the sweep right along with the OEM gauges with the key at position 3.
BUT the gauge still turns off and sweeps again once I turn the car on!
So the new fuse definitely changed something (the gauge turns on at a different key position now), but it still doesn't function how I think it should. I think I'm about to give up. It doesn't affect how the gauge actually functions, it's just the startup sequence.
Old 01-18-2011, 08:49 PM   #23
jh.
Member#: 263340
2011 4DR STI
I think its a gauge problem. Is it actually losing power and resetting or just double sweeping?
Old 01-18-2011, 08:50 PM   #24
jh.
Member#: 263340
2011 4DR STI
Thanks.
There was a recall? or a problem with the factory boost gauges. FYI it only reads up to 20psi, so if you plan on boosting more Id get another gauge.
Old 01-18-2011, 09:37 PM   #25
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It restarts once you crank the engine. I made a video, and I'm uploading it now.
First part of the video I stop at position 3. OEM gauges and boost gauge all do the sweep. Then I crank the engine and the boost gauge restarts and sweeps again.
Second part I immediately start the engine. Boost gauge only sweeps once, but it is not in sync with the rest of the gauges.
diy boost gauge install Nuveosif Newbies & FAQs 15 07-21-2017 03:03 PM
DIY Boost Gauge for ~$15 dave_mtu Interior & Exterior Modification 57 02-23-2009 07:01 PM
DIY boost gauge help (mechanical) tekgnosis Interior & Exterior Modification 25 01-25-2007 10:32 AM
FS:IL: Lamco OEM boost gauge in pod from 05 STi AmSFighter Private 'For Sale' Classifieds 20 09-06-2005 11:42 PM
boost gauge in STI? zmw Texas Impreza Club Forum -- TXIC 7 12-27-2004 01:16 PM
