Tire & Wheel Forum sponsored by The Tire Rack |
03-07-2012, 10:26 AM | #551 | |
Member#: 12029
MAIC
--Dan Mach V FastWRX.com
03-07-2012, 05:37 PM | #552 |
Member#: 282738
Vehicle:2011 WRX Plasma Blue Pearl |
I bought some gforce recently (gonna install them for summer) and was wondering if the oem lug nuts will fit or i should get some new?
Also if i get some new one, do you have any brand suggestion Thanks |
03-08-2012, 09:36 AM | #553 | |
Member#: 12029
MAIC
--Dan Mach V FastWRX.com |
03-08-2012, 12:34 PM | #554 |
Member#: 219100
Tri-State
Vehicle:2014 STI hatchback Satin White Pearl |
Sorry for posting in here.
Thanks for answering my question though. Last edited by QwaktastiK; 03-08-2012 at 06:11 PM. |
03-08-2012, 02:17 PM | #555 | ||
Member#: 12029
MAIC
--Dan Mach V |
03-08-2012, 03:28 PM | #556 | |
Member#: 300848
MWSOC
Vehicle:2012 WRX LR |
Thanks!!! you've been a great help |
03-08-2012, 04:12 PM | #557 |
Member#: 227637
SCIC
Vehicle:2014 Minivan Driver |
I'm hoping to do some track days soon and was wondering if 245/45/17 is too tall for track duty. I can get a killer deal on some lightly used Star Specs.
My car: 2011 WRX with stock 17x8 wheels. |
03-08-2012, 06:00 PM | #558 |
Member#: 235745
E. Canada
Vehicle:2011 WRX 5dr WRB |
That's basically the exact outer diameter of the tires that come on the STI. Your speedometer will be off by 1.4%. You should be fine.
03-09-2012, 01:41 AM | #559 |
Member#: 288037
NWIC
Vehicle:2015 LightingRed WRX 11' WRX sold**14' XV sold |
18x9.5 +38 Rpf1's 5x100 265/35-18 General Gmax AS-03 tires Lowered on BC BR coils Rear fenders rolled due to rubbing McGard Spline lugs with matching locking lugs Maxed front camber |
03-09-2012, 09:17 AM | #560 | |
Member#: 12029
MAIC
03-09-2012, 11:17 AM | #561 | |
Member#: 288037
NWIC
03-09-2012, 01:55 PM | #562 |
Member#: 308190
TXIC
Vehicle:2012 wrx hatch dgm,2010 swp legacy prem. |
Quick noob question,im trying to see if this would fit on my wrx. Is a 18x9 +45 with a 265/35/18 tire,is it gonna rub? Or im ok? As of right now is in stock suspension but im adding some epic springs to drop it a few.what do you think? Thanks again.
03-09-2012, 09:07 PM | #563 |
Member#: 198898
Tri-State
Vehicle:2012 wrx Silver |
I seen a lot of +35 offset but would a 17 x 9 255/40 with a +28 offset be a real issue on a sedan?
03-10-2012, 02:11 AM | #564 | |
Member#: 97135
NWIC
03-10-2012, 05:29 PM | #565 |
Member#: 292096
MWSOC
Vehicle:2011 WRX Sedan Dark Grey Sexiness! |
Hate to be asking but tire sizes confuse me for some reason. Got some 17x9 +40 wheels for my '11 sedan, and want the largest tire i can go to protect the wheel/not rub. Suggestions? Major wheel newb, its my first aftermarket set.
Edit: saw the posts above mine but thats a pretty large difference in offset so...i did read just sayin lol Edit #2: Im also on stock suspension with little to zero desire to drop the car, i like the monster truck/meaty look |
03-10-2012, 11:49 PM | #566 |
Member#: 12029
MAIC
03-11-2012, 11:33 AM | #567 |
Member#: 292096
MWSOC
Awesome, thanks Dan!
03-12-2012, 12:48 PM | #568 |
Member#: 278439
MAIC
Vehicle:2011 WRX 637HP/560TQ 00 2.5RS | 97 OBX |
So I believe I have decided that I'm going to go with the ROTA T2R 18x9.5" +38mm Wheel and a Hankook Ventus V12 265/35R18 but I had one final question if you could oblige. I know this is a wheel fitment thread but I figured this is applicable to two different forums. If I were to lower the car with RCE Blacks, which is about a .75" drop front and rear, and with the additional wheel and tire weight would it still be ok to run these springs on the stock struts with the new wheels? The car is a daily driver and most likely won't be tracked often just some spirited/daily driving.
03-12-2012, 02:31 PM | #569 | |
Member#: 97135
NWIC
Stiffer springs will put more strain on your struts, so plan to upgrade those at some point. Last edited by sc00by4life; 03-12-2012 at 04:40 PM. |
03-12-2012, 02:53 PM | #570 |
Member#: 284003
NESIC
Vehicle:2010 Alpine 135i |
Ordered a set of 275/35/18 MPSS for 18x9.5 ET45 wheels. Ill let you all know how fitting them goes but with my 265/35 DZ101s, they are actually a tad thin for the wheel and i have at least 10mm of inboard clearance as well as some outboard. Worst case is i throw a 3mm spacer in there and have to pull the fenders a touch.
03-12-2012, 05:29 PM | #571 |
Member#: 235745
E. Canada
I think I know the answer to this but I'd be interested in what Dan has to say about it. I would think at stock height it would likely rub with the 265/35's and with 255/35's would be pretty safe with a very slight chance of rubbing. Not sure how much difference the epic springs would make but again I would think the 265's would still probably rub without a slight rear roll.
03-12-2012, 07:25 PM | #572 |
Member#: 313352
BAIC
Vehicle:2012 WRX White |
Wrong thread, not a WRX
03-13-2012, 07:11 PM | #573 |
Member#: 284003
NESIC
Figured id give a quick update on 275 MPSS.
Got the tires mounted today and they fit with decent clearance on both the strut as well as rolled fenders all the way around. No rubbing on full lock and have yet to give it much in cornering. |
03-13-2012, 07:17 PM | #574 |
Member#: 274717
MAIC
Vehicle:2011 WRX TP Stg2+ |
just FYI someone on the forum has done a 19x8.5 with a 235/35/19 et42 that fits without any modifying.
03-13-2012, 09:39 PM | #575 | |
Member#: 278439
MAIC
Does anyone here have experience with scrub radius and "numbing" of the turn in on wheels that venture too far away from the stock offset. I ask this because I was speaking with Dan at Epic Suspension and he said that on wider wheels with lower offsets you need to be careful how far away you stray from the factory offset because of the scrub radius. I had never heard this term before so I hit up wikipedia and got the following:
Similar Threads | ||||
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
