Welcome to the North American Subaru Impreza Owners Club Friday May 26, 2017
Old 04-08-2012, 03:26 PM   #1
KGwrx
Member#: 268868
2007 STi GDB
Default Delete.
Solved.
KGwrx is offline   Reply With Quote
Old 04-08-2012, 03:34 PM   #2
subarupagan
Member#: 315716
2013 Wrx premium
Plasma blue pearl
hard ware stores sell a drilling tool to drill out that bolt bring a spare bolt to get another one and tada your done or just bring the whole thing to the hardware store and see if they can help you out right there
subarupagan is offline   Reply With Quote
Old 04-08-2012, 03:37 PM   #3
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Yes it will rattle. The Cobb heat shield only uses 3 bolts.
Get your stocker off and see if you can see it better. Try from under the car. You just need to get the threaded part out right? Kind of unclear on what broke. The small bolt holding the stock shield in, in the pita spot? Try some small vise grips to turn it out. Worst case, you have to drop the uppipe, but I'm pretty sure you won't need to.
If so, you should be able to get that out and use one of the other numerous stock bolts in that location.
WRXSD is offline   Reply With Quote
Old 04-08-2012, 03:37 PM   #4
KGwrx
Member#: 268868
2007 STi GDB
the thing is there is very minimal space to barely tighten up the screw. and i dont wanna disassemble my turbo and uppipe so im probably just going to cut up my heat shield some more
Old 04-08-2012, 03:41 PM   #5
KGwrx
Member#: 268868
2007 STi GDB
so i hope this clarifies a little the bolt head snapped off and the rest of the screw is still inside the very bottom location. as in the pia spot with is the upipe location. i think ill just cut up the stocker some more i have not other choice it seems
Old 04-08-2012, 03:50 PM   #6
KGwrx
Member#: 268868
2007 STi GDB
FIRST POST UPDATED AS WELL
Old 04-09-2012, 01:03 PM   #7
BobMac
Member#: 32082
Default I feel your pain.
I just finished installing a new downpipe and heat shield and ended up shearing at least half the bolts on the heat shield brackets including the bottom forward bolt the Cobb shield reuses. I ended up shifting the mounting location backward and catching the mounting hole just behind it. I've done 80 miles on it so far and no problems.
BobMac is offline   Reply With Quote
Old 04-09-2012, 02:10 PM   #8
KGwrx
Member#: 268868
2007 STi GDB
wow cool i know those dam rusty factory bolts. so to clarify all you did was pretty much bolt it down right behind where its intended? where the old stock location is right? i must try this thanks!
Old 04-09-2012, 02:24 PM   #9
BobMac
Member#: 32082
Yes. I just used the mounting bracket directly behind the mounting hole in the up-pipe (the one the directions recommend). No problems yet.
Camber Bolts, Turbo Heat Shield, 4 17" tires, Exhaust gaskets BSpeedRacerB Private 'Wanted' Classifieds 1 11-07-2008 06:05 PM
Need help with the correct heat shield for my TurboXS DP on a '06 wrx SubbieAndCoop Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-17-2007 02:38 PM
Help, Snapped bolt during steering rack bushings install njskatchmo Brakes, Steering & Suspension 4 11-20-2006 12:29 PM
Heat shield removal bobgrice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-29-2001 12:37 PM
Heat Shield Removal? JaMa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-30-2001 06:32 PM
