07-10-2012, 01:13 PM | #1 |
Member#: 285495
Vehicle:2004 WRX WRB |
Car won't start when hot
Hey guys, I have a 94 Impreza L with a V2 STI swap. I recently got it off another member and about a month ago it started giving me an issue where the car will start and run perfectly fine, and then if I turn the car off and try to start it 10 minutes later it wont start, but if I wait about an hour it'll start up no problem. Any ideas?
07-10-2012, 01:32 PM | #2 | |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
-Rob |
07-10-2012, 01:45 PM | #3 |
Member#: 285495
Thanks man, I'll check it out
07-11-2012, 02:22 PM | #4 | |
Member#: 257043
VIC
Vehicle:1993 JDM WRX Wagon Black |
07-11-2012, 06:40 PM | #5 |
Member#: 285495
It will turn over, but it won't actually start. Was that your issue as well?
09-09-2012, 02:33 PM | #6 |
Member#: 99205
Vehicle:2005 Impreza WRX Blue |
My car is having the same problem I have a 2005 wrx with a 2.5 big valve head long
block from element tuning with hydra em Phil cant figure out whats wrong I am thinking about taking the car to someone else I am located in MD. I need this problem fixed I have too much money invested in my car for this problem. Phil once thought it was the engine not seeing enough fuel so he maxed out the signal going to the injectors. Cole |
09-09-2012, 06:09 PM | #7 |
Member#: 88618
SCIC
Oh oh oh. Coolant temperature sensor malfunction can cause hot start problems.
09-09-2012, 10:06 PM | #8 |
Member#: 99205
That's possible do I have to buy that sensor at subaru?
09-09-2012, 10:33 PM | #9 |
Member#: 123362
Vehicle:'97 E36 M3 351W FTW |
09-10-2012, 12:39 AM | #10 |
Member#: 284101
Vehicle:2004 STI world rally blue |
I have a similar issue with my built 2.0l. Cold starts are fine. Once I shut the car off (getting gas or something) and start it back up, it'll want to die out but if I give it just a bit of gas, it's fine and idles perfectly normal.
09-10-2012, 05:57 PM | #11 |
Member#: 99205
I am going to try to check the coolant sensor with a muti-meter and check the Ohms Does anyone know what the sensor should read normally?
09-10-2012, 06:01 PM | #12 |
Member#: 206851
Vehicle:56 Belair Pro Street |
my 94 RA engine I just bought would almost not start once up to temp. The ect/iacv/crank/cam sensors were all clean or brand new.
Then of course it spun a bearing after 80miles so I have no idea what it was.. After doing some digging into the ecu rom, I think it is our ****ty fuel enrichment/cranking fuel/temp based enrichment that does this. If I have some spare time I will try to test a rom once I have a G powered car. |
09-12-2012, 11:32 PM | #13 |
Member#: 44472
Vehicle:Ver2 Legacy StiRA 88 RX, 87 RX, 07 FXT |
I had this problem for a long time. it was the cam sensor. It takes only 1 minute to change.
06-27-2017, 07:42 PM | #14 |
Member#: 470031
etidatreyu...did it work? was it the cts or the fuel pump?
07-05-2017, 12:02 PM | #15 |
Member#: 469350
Well, maybe Crank or Cam position sensors failed due to heat? i can't think of any other solution I even asked a mate from DSRLeasing who is an mechanic.
