Welcome to the North American Subaru Impreza Owners Club Wednesday January 17, 2018
Old 11-20-2012, 12:23 PM   #1
KENLUDE97
Member#: 152010
2004 Forester XT 5sp
Red
Default Straight Swap? 98 Impreza 2.5 Motor Into A 98 Legacy 2.5?
From the little bit of digging that i have done i found that the engine code for the Impreza is ej25(1)? and the legacy is the EJ25d? will the wiring match up exactly ect ect?
Im not a new mechanic, im just looking to see if it will bolt straight in, will i have to swap harnesses, clutches for FW ect ect.
ken
KENLUDE97 is offline   Reply With Quote
Old 11-20-2012, 02:39 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Ken,
The '98 2.5RS should be an EJ25D (DOHC) as well, not an EJ251 (SOHC). The 2.5RS shifted to the SOHC engine in '99, while the Legacy and Outback switched over in '00.
If you're getting another EJ25D, the engines should be essentially identical. I put a '98 2.5RS engine in my 2.5GT back in '06 and there were a couple of differences on the intake manifold:
I just swapped my 2.5GT intake manifold onto the 2.5RS engine so I didn't have to worry about the differences. There shouldn't be any other changes - clutch and flywheel are the same, harness and all the sensors are the same, etc.
If you're looking at an EJ251, then it will not be a straight swap. The "easiest" way to use that engine in your '98 Legacy would be to put the EJ25D cylinder heads, intake manifold, sensors, etc onto the EJ251 short block.
Pat Olsen
Old 11-20-2012, 02:45 PM   #3
KENLUDE97
Member#: 152010
Red
ok im more sure about the years of the cars than im about the engine code of the engines.
I was told 98 Impreza 2.5 to 98 Legacy 2.5
Old 11-20-2012, 04:42 PM   #4
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
Hey Ken, if it is indeed a 98 Impreza 2.5rs engine then it will swap in without any issues. What type of problems are you having that you need to replace your current engine?
Originally Posted by Patrick Olsen View Post
Hey Pat, what is this? I don't have anything that resembles this in my 99
V8Slayer is offline   Reply With Quote
Old 11-20-2012, 07:13 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
charcoal canister. these were relocated to the rear of the car post 98.5
