Welcome to the North American Subaru Impreza Owners Club Sunday October 22, 2017
Old 06-24-2012, 11:52 PM   #1
ezil71
Member#: 207118
2003 Wrx Wagon
Default Question on 4/2 pot and H6 upgrade
I'm thinking about upgrading to the 4/2 pots from the 06-07 wrx on my bugeye, but I already have upgraded to the H6 rotors in the rear, and new slotted rotors in the front.
I know I need the bracket from Kartboy for the rear, but will those 4/2 pots fit on my rear H6 sized rotor?
As far as I've seen, no issues for the front rotor or bracket correct?
Anything else I'd need?
ezil71 is offline   Reply With Quote
Old 06-25-2012, 01:02 AM   #2
jamal
Member#: 71875
Nope. The H6 rotor is solid and 10mm thick, the 2-pot rotor is vented and 18mm thick.
The 4-pots only on the front would still be a good upgrade though and you keep your existing rotors. Also the stock don't clear them.
jamal is offline   Reply With Quote
Old 06-25-2012, 06:33 AM   #3
there really is no advantage to going to the 2 pot rears....it wont improve your braking and will just cost you $$$
Old 06-25-2012, 07:26 AM   #4
ezil71
Member#: 207118
2003 Wrx Wagon
but..... but.... it would 'look' like I stop faster!
So is the 2 pot rotor the same size, just thicker, or is it actually larger too?
I know the stock 16's won't fit, not a problem though I have P7's
How is the overall balance with the 4 pot front and H6 rears?
I know on the stock calipers, the H6 bring the balance a touch to the rear brakes.
Old 06-25-2012, 07:50 AM   #5
the balance will be the same as teh diameter is the same
the 2 pot rears are heavier
Old 06-25-2012, 11:51 PM   #6
ezil71
Member#: 207118
2003 Wrx Wagon
How about the LGT upgrade? Is that a better option?
Does the LGT front upgrade require a new rotor, or does it use the same as the WRX?
Between the LGT fronts or the 4 pot fronts with H6 rears, which is a better option?
Old 06-26-2012, 01:34 AM   #7
d000000000d....all ya need is what ya got plus good pads--the stoptech street performance pads are great....good fluid...ate type 200 is great....a mc brace, and ss lines and done
stop putzin around looking for the pot of gold......its a fools errand
Old 06-26-2012, 01:36 AM   #8
jamal
Member#: 71875
You are asking questions that are answered in a post I spent a lot of time on. It can be found in the brake sticky.
Old 06-26-2012, 04:35 AM   #9
ezil71
Member#: 207118
2003 Wrx Wagon
Thanks Uncle Scotty - I've got those already. Just looking to improve, sounds like it isn't worth it.
I agree, the stoptech streets are the best pad I've tried. A bit dusty, but well worth it.
Old 06-26-2012, 07:43 AM   #10
ezil71
Member#: 207118
2003 Wrx Wagon
Jamal - can you point me to the post? I've looked through the stickies. Perhaps I just missed it.
Looks like the 4/2's aren't as good as my 03 stockers? That I would not have guessed.
Why is that?
The main question I didn't see was the LGT vs my 03 fronts vs the 4 pots?
How would your order the performance of those front brakes from best to worst?
Old 06-26-2012, 08:20 AM   #11
REX8
Member#: 24038
Why is that?
You need to define "performance".
Braking power?
LGT>03>4-pots
Heat capacity
LGT>>03>4-pots (just really a tie with the last two)
Pedal feel (BIG for the street)
4-pots>03/LGT
Ease of pad changes?
4-pots>03/LGT
Again, it all depends what you're looking for.
REX8 is offline   Reply With Quote
Old 06-26-2012, 09:03 AM   #12
ezil71
Member#: 207118
2003 Wrx Wagon
Thanks - that is a great post!
Old 06-26-2012, 11:36 AM   #13
Web Foot STi
Member#: 39086
2004 STi
Do you plan to go play at PIR?
Web Foot STi is offline   Reply With Quote
Old 06-26-2012, 11:45 AM   #14
ezil71
Member#: 207118
2003 Wrx Wagon
I've never tracked the car. I don't see myself doing it often, but at some point I'd love to try it out.
Old 06-26-2012, 11:50 AM   #15
Web Foot STi
Member#: 39086
2004 STi
^ I wouldn't worry about heat capacity, or ease of changing pads then.
Old 06-27-2012, 02:04 AM   #16
ezil71
Member#: 207118
2003 Wrx Wagon
Cool - so the only reason to upgrade to 4 pots is feel for the most part.
And the H6 in the rear is basically the same as the 2 pots already.
If I decided to upgrade the 4 pots, has anyone just used the remanufactured 06 calipers from Autozone?
Seems fairly reasonable for the price vs what I see on the boards for a rebuilt set. Throw on some G2 paint and stickers and it would be like new!
Old 06-27-2012, 02:19 AM   #17
Eww Evo
Member#: 299687
IG iam_mala_
GTA AWD Limited
This.
Eww Evo is offline   Reply With Quote
Old 06-27-2012, 11:48 AM   #18
Mach V Matt
Member#: 248892
2006 WRX Wagon
Actually, the 2 pot rears use a bigger rotor, the same as the 05-09 LGT.
Mach V Matt is offline   Reply With Quote
Old 06-27-2012, 02:24 PM   #19
jamal
Member#: 71875
Diameter is the same, brake torque is the same. Only difference is the venting, and heat capacity isn't really a concern here.
Old 12-03-2012, 01:41 PM   #20
NordiX
Member#: 33439
WR Pearl Blue
I'm reviving this 6-month old thread because I am struggling with the discussion I read here. Every answer given by Scotty and the others points to the idea that the stock 03 calipers + H6 upgrade + quality rotors + SS lines + mc brace + good pads + good fluid = optimal braking performance for the bugeye, and that swapping in 4/2 pots is a waste of time and $.
But I have ALL of those upgrades and the braking performance of my 03 SUCKS!! I can't even lock up the brakes when I take the car to a safe place and test the limits! I will admit that I have found that my Hawk HPS pads will grab a little better after I get a some heat in them... but as the weather gets colder here in SLC I don't tend to get the brakes very hot during normal street driving. I have no confidence that if I got caught in a surprise emergency braking situation that my current set up would stop me as quickly as one should expect from a well-balanced performance vehicle. It's my #1 gripe with this car that I otherwise completely love to drive.
So I am reopening the question: Is it really not worth the $$ to upgrade 4/2 pot calipers, and/or mc? How can it make sense that I wouldn't get more squeezing power from 2x the pistons?
NordiX is offline   Reply With Quote
Old 12-03-2012, 02:08 PM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
If you're a disciple of "Uncle Scotty" then I'm surprised you've missed his frequent rants about how crappy the HPS pads are. The subject comes up almost as frequently as his rants about the Hankook V12 not being a max performance tire. Try some better pads.
Old 12-03-2012, 02:11 PM   #22
sc00by4life
Member#: 97135
are you sure your bleed is good? thats the first thing I would check.
Old 12-03-2012, 02:42 PM   #23
NordiX
Member#: 33439
WR Pearl Blue
Well, as you can see by the number of posts I've made on NASIOC since 2003 I can't really claim to be a disciple of anyone. But whenever I've searched around for technical advice Scotty does seem to be one of the forum gurus that tends to have solid knowledge of all things Suby... and I did notice Scotty's reference to the StopTech pads above. So I will take that into account that perhaps my current pads are not doing me any favors.
But I have a hard time believing that all I need to do is swap to StopTechs and my 2/1 pots are going to suddenly become amazing... so I feel that the 4/2 pot question is still open for more discussion.
I am sure that the system is air free. There is no spongy feel to my brakes at all. The pedal is quite firm... just not a lot of bite when I push hard.
Old 12-03-2012, 02:47 PM   #24
ezil71
Member#: 207118
2003 Wrx Wagon
Funny that you brought this thread back up I was just thinking about replacing my front brakes with the 4 pots
does anyone know if the remanufactured calipers from autozone for the 06 WRX are any good?
there seems to be 2 different kinds anybody try this approach?
Old 12-03-2012, 06:58 PM   #25
aaaaawwww..sweeeetuuuummmmsss
more lovins for uncle
how do i change brakepads on 4/2 pot brakes from 06? jojotherider Brakes, Steering & Suspension 6 02-03-2012 02:02 PM
WTB : OR: 04' STi steering rack, 06-07 4/2 pots, and ETC!!! Cash ready st165turbos Private 'Wanted' Classifieds 1 03-11-2011 10:04 AM
4/2 pot upgrade on 2000 Legacy Cervantes Legacy Forum 4 02-05-2011 07:55 PM
FS or TRADE: rear STi Brembo's w/ DBA rotors and upgraded pads for stock WRX 4/2 pots thebusiness999 Suspension/Brakes/Handling 7 01-22-2007 06:28 PM
Question on STI 2.5 and WRX Heads wRxbeater11 Subaru Conversions 4 10-04-2004 11:31 PM
