Welcome to the North American Subaru Impreza Owners Club Monday January 22, 2018
Old 12-26-2012, 02:02 PM   #1
M45
Member#: 333446
2013 Impreza SL CVT
Default fumoto valve installed! pic
next oil change is going to be nice! what size ID hose do I need for this? I meant to bring it to HD before I put it on the car but I forgot.
M45 is offline   Reply With Quote
Old 12-26-2012, 02:05 PM   #2
M45
Member#: 333446
2013 Impreza SL CVT
is it 3/8" ID?
Old 12-26-2012, 03:47 PM   #3
Chris793
Member#: 336926
2013 Impreza Sport
Ice Silver
Just installed one of these myself last week and was wondering the same thing. This valve makes me a little nervous as to the quality of its seal, and whether or not it will allow all the oil to drain since it is slightly recessed in the pan.
Chris793 is offline   Reply With Quote
Old 12-27-2012, 09:44 PM   #4
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
There aren't that many threads inside the oil pan, all but maybe a few ounces should drain.
I think I bought 3/8" house for mine, might be 5/16" though, pretty sure it says on either the fumoto or quickvalve website
Old 12-27-2012, 09:52 PM   #5
motorace
Member#: 339003
On my truck ive had since 2004, just as an extra measure, which isnt nessesary, but did give me peace of mind, i attached a small pipe clamp so the lever would have no chance of turning
motorace is offline   Reply With Quote
Old 12-27-2012, 09:58 PM   #6
Candor
Member#: 219200
You have to lift the lever and then turn. I can't think of any situation where it would get knocked open.
I bought a hose, secured it to the nipple with a pipe clamp and feed it into the subframe. Never have to worry about where my hose is. Going on 3 years without an issue.
It actually does NOT sit much more in than the stock drain plug. I would wager pulling the valve after draining would just result in residual left over dripping out.
Candor is offline   Reply With Quote
Old 12-28-2012, 10:52 AM   #7
myrt1987
Member#: 323103
2018 WRX
Pure der
I bought 3/8" hose ID and works good, tight seal. $0.30/foot at lowes
Old 12-28-2012, 07:01 PM   #8
wrxmike
Member#: 13800
2013 Impreza Sport
Nice. Thinking of getting one myself. I've used this on all my cars and makes oil changes simple as pie. What's the one for the impreza...F-108?
wrxmike is offline   Reply With Quote
Old 12-28-2012, 07:03 PM   #9
vu_tang
Member#: 294693
Is a crush washer needed with this valve?
vu_tang is offline   Reply With Quote
Old 12-28-2012, 07:04 PM   #10
Candor
Member#: 219200
No it's discouraged. The fiber washer holds perfectly fine.
Old 12-28-2012, 07:18 PM   #11
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
Yep F-108 is the correct valve. the question for you is to "N" or not to "N" I went with the "N"
the OP as in the Picture went with the "N"
ZionZR2 is offline   Reply With Quote
Old 12-31-2012, 09:48 PM   #12
myrt1987
Member#: 323103
2018 WRX
Pure der
Just installed mine today. So excited to NOT make a mess next oil change.
Old 12-31-2012, 11:15 PM   #13
M45
Member#: 333446
2013 Impreza SL CVT
it really flies out eh?! I didn't get any on the floor but it got all over the parts of the car surrounding the drain. not much I could do about it.
Old 12-31-2012, 11:42 PM   #14
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
perfect reason for the valve
