Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 01-21-2013, 12:40 PM   #8751
premier00000
Member#: 251060
2008 Impreza Outback
Originally Posted by 09subi2.5i View Post
Think I might hVe them make some sort of removable test pipe incase I ever have to swap back to stock (come inspection time).
Just get a heat shield that's the same shape as the ones that are on catalytic converters, and weld it to a straight pipe. no one would be the wiser. It worked for me.
Old 01-21-2013, 01:42 PM   #8752
aceofskies05
Member#: 326539
2008 Impreza 2.5
newport blue
Originally Posted by fancyfootwork15 View Post
I had some ghetto HID kit in my car for not even 1 week. Same car as you, the glare was terrible.
Looked cool sure, but it ended up bugging me not being able to see properly.
DDM Tuning bulbs with slim ballast, if your curious. Took a month to ship tho.
aceofskies05 is offline   Reply With Quote
Old 01-21-2013, 02:14 PM   #8753
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
I had xenon supply, essentially the exact same thing. It wasn't the quality, it was the glare of putting HIDs in halogens. It just doesn't work.
Old 01-21-2013, 03:53 PM   #8754
09subi2.5i
Member#: 331636
09 impreza
paprika
Thanks premier. Or gut the cat right?
09subi2.5i is offline   Reply With Quote
Old 01-21-2013, 05:39 PM   #8755
premier00000
Member#: 251060
That would take too long and isnt reversible if you need to. It's much easier to weld or even use hose clamps to attach a heat shield to a straight pipe. Also so you don't throw a code get some spark plug antifoulers and drill out one to accept an o2 sensor screw both together and then into the o2 bung and you'll be good to go.
Old 01-21-2013, 05:56 PM   #8756
DownhillSubie
Member#: 342985
Any of you guy's use Prestone coolant? 50/50 mix?
DownhillSubie is offline   Reply With Quote
Old 01-21-2013, 06:21 PM   #8757
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
I had the xenon supply, garbage. Now I have ddm tuning, much better quality and reliability. Xenon supply ones wouldn't always fire and ballast were massive.
Six star OEM 50/50. I was told its the best because the subaru cooling system is temperamental.
Old 01-21-2013, 06:31 PM   #8758
trishHUYNH
Member#: 248840
2011 Impreza
Anyone here have the rear lip for the hatch? If so, pictures would be great!
trishHUYNH is offline   Reply With Quote
Old 01-21-2013, 08:00 PM   #8759
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Aredilla is offline   Reply With Quote
Old 01-21-2013, 08:14 PM   #8760
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by Digital Dillon View Post
As long as you're not in California you should be okay
It's all legal untill a cop/emission test finds out
Old 01-21-2013, 09:35 PM   #8761
Sellars21
Member#: 304055
Originally Posted by Aredilla
Sweet vid, e-braking with the subaru awd will frag the center dif tho.....
Old 01-21-2013, 09:43 PM   #8762
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by Aredilla View Post
Check my video out
Think I found Ken block!
Old 01-22-2013, 02:50 AM   #8763
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
oh really? I was not aware of that. Does it take a while for it to go out?
Old 01-22-2013, 08:57 AM   #8764
Sellars21
Member#: 304055
Probably not right away, but I have read about people cranking the ebrake and massive clunks coming from the bowls of the tranny.
Just google " subaru awd ebrake" I found the most helpful ones that relate to the 2.5i's were the post by older manual trans foresters and wrx's. I don't think the 6 speeds STI's have to worry so much about this.
But if something did go wrong you'll be looking at dropping the tranny and cracking it open, replacing the center diff in the middle of the tranny and hoping your gears are still alright. It's a massive job that's pretty easy to avoid. Same concept as to never tow a subaru awd on just two wheels.
Old 01-22-2013, 11:06 AM   #8765
Aredilla
Member#: 292162
2010 impreza 2.5i
paprika
Ok I see. Hey thank you for bringing that to my attention. I actually don't want to drift anymore haha. Ill just spectate the other subies.
Old 01-22-2013, 11:40 AM   #8766
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah pulling the handbrake on a 2.5i is very very bad for the diffs. And you do not need the handbrake to drift in the snow.
BWX is offline   Reply With Quote
Old 01-22-2013, 12:26 PM   #8767
premier00000
Member#: 251060
This. And it's called the parking brake for a reason.
Old 01-22-2013, 12:41 PM   #8768
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
If there is an automatic de-coupling of the center diff when the handbrake is pulled as in WRC cars and some road cars, it is fine to do it.. but if there is no sensor, and you pull the handbrake, just think of what that does to your expensive differentials.. Not good things for sure.
Old 01-22-2013, 01:04 PM   #8769
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
04/05 STI does that. Just floor it to get in to a drift instead of ripping the brake
Old 01-23-2013, 09:52 AM   #8770
DownhillSubie
Member#: 342985
Agenda for today, track down and fix small coolant leak that appears to be just to the left of the drivers foglight area... if standing in front of the front bumper looking in the engine bay.
2008 WRX sedan black carpet, ordered.
Old 01-23-2013, 12:27 PM   #8771
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Had to take this amp out for the second time to send it back to MTX for repair. First time it stopped shutting itself off automatically with the car via the remote turn on lead from the head unit.. or the auto-turn-on function. It worked fine otherwise. They replaced the board inside because they are discontinued.
Got it back and a couple weeks later, then one day last week- it smelled like my car was on fire all of the sudden driving down the road at 60 mph.. So I pulled over and after checking for fires, unhooked the fuse by the battery. It still was functioning fine, but smelled like something was burning inside. Not cool.
It sounds great otherwise.. and has a ton of power, but I would not recommend it to a friend!
Old 01-23-2013, 01:50 PM   #8772
d.o.b 2.5i
Member#: 268284
2008 2.5i impreza
spark silver
Anyone have raceland coilovers? Thinking of buying them for a suspension upgrade. Good idea or bad idea? Suggestions and advice would be greatly appreciated. Thanks.
d.o.b 2.5i is offline   Reply With Quote
Old 01-23-2013, 02:02 PM   #8773
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
The people who have them will say they're awesome. But they're a cheap coilover. They're not that great.
It all depends on what you want out of your suspension.
Old 01-23-2013, 02:45 PM   #8774
d.o.b 2.5i
Member#: 268284
2008 2.5i impreza
spark silver
^^^I just want better suspension, drop in ride height. Ive heard good n bad things... I would like to know if the quality is good and if they hold up well.
Old 01-23-2013, 02:51 PM   #8775
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
I'd go Koni inserts with RCE springs vs raceland. More bang for the buck and also if ur gunna get coilovers mind as well do it right so you don't piss ur money away. I'd hate to see u spend more for no reason.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 10 08-22-2017 01:30 AM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
