Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 01-30-2013, 04:17 PM   #376
gregonfire
Member#: 181047
2015 CWP WRX
2015 SWP Forester XT
Originally Posted by SWP n Gold View Post
What is your setup?
TP stage 3.. So turbo back, tmic, cai, ebcs.
gregonfire is offline   Reply With Quote
Old 01-30-2013, 04:23 PM   #377
SWP n Gold
Member#: 110783
2010 WRX
I would absolutely do the injectors and maybe look into a fuel pump. The EWG is up to you; if you already have it, you might as well install it and get everything tuned together. Short of E85/meth, your stock turbo would pretty much be maxed out at that point.
SWP n Gold is offline   Reply With Quote
Old 01-31-2013, 07:55 AM   #378
QwaktastiK
Member#: 219100
2014 STI hatchback
I agree. Get a fuel pump, one step colder plugs, and throw everything on and get tuned.
I'm not into EWG setups, but if you already have it, might as well.
You planning to upgrade the turbo eventually?
QwaktastiK is offline   Reply With Quote
Old 01-31-2013, 12:45 PM   #379
gregonfire
Member#: 181047
2015 CWP WRX
I have a fp already (65c) and one step colder plugs. I am not planning on upgrading the turbo. Why aren't you a fan of ewg's?
Old 01-31-2013, 01:08 PM   #380
QwaktastiK
Member#: 219100
2014 STI hatchback
Just preference really. I want my car to be 100% emissions friendly.
IWG & Catted. If I was building a track car or something that wasn't going to be daily driven, I'd might go catless and EWG. And I think I'd still reserve it for a larger turbo where I could stay out of boost more easily.
My specific demands for my car:
Catted Downpipe -> emissions friendly
IWG -> emissions friendly
TMIC -> so I can run a short ram intake since Philly gets its fair share of rain
UEL Headers -> to retain the boxer rumble
And if I ever do a larger turbo, it will definitely be a stock location turbo and still fall within the demands I just listed.
So you got a good fp and plugs. Get on that and post up your results! Sounds like a really solid setup similar to my future goals.
You could always PnP your stock VF52 down the road if you're looking for a little bit extra but not looking to blow your motor.
Old 01-31-2013, 01:14 PM   #381
gregonfire
Member#: 181047
2015 CWP WRX
Hmm never thought of it from an emissions standpoint. Usually people don't want it because of the sound. After talking to my tuner (Agile Auto in MD), he recommends a 14lb spring, so it shouldn't open until around 15psi. Which is only when going WOT. He also said I should see around 330whp and 360wtq with this setup at 21psi on their Dynapack dyno, while holding 2 more psi to redline than with the iwg. I'm not sure if Dynapacks read high, low, or "accurate".
Old 01-31-2013, 02:08 PM   #382
QwaktastiK
Member#: 219100
2014 STI hatchback
NJ state inspection/emissions might be different from PA. Catless & EWG wouldn't pass the visual inspection process.
And to stay on topic:
image by QwaktastiK, on Flickr
Old 01-31-2013, 02:15 PM   #383
twiztidWRX
Member#: 286910
2015 Limited WRX
Crystal Black Silica
^That is perfect. Rack/Fairing/Fogs/Front Lip. I love everything about that picture.
twiztidWRX is offline   Reply With Quote
Old 01-31-2013, 02:41 PM   #384
QwaktastiK
Member#: 219100
2014 STI hatchback
Thanks man. Going to be adding a WRX grille badge once I get it painted.
Old 01-31-2013, 02:46 PM   #385
tehknikhal
Member#: 227548
2009 09 WRX Sedan
Obsidian Black Pearl
Edited.... Edited edited.
tehknikhal is offline   Reply With Quote
Old 01-31-2013, 02:47 PM   #386
twiztidWRX
Member#: 286910
2015 Limited WRX
I'm a girl, but you're welcome all the same
I know in general a lot of people hate IG pics but this is one of my more recent...
Old 01-31-2013, 02:52 PM   #387
StormTroop
Member#: 327319
2009 SWP WRX
Stage 2
I want fog lights
StormTroop is offline   Reply With Quote
Old 01-31-2013, 03:03 PM   #388
Trustkevin13
Member#: 259184
2008 Subaru WRX
please do! i wanna see how the sport grille looks with one. that and its hard finding one that does not cost 35 new. bloody expensive.
Trustkevin13 is offline   Reply With Quote
Old 01-31-2013, 03:08 PM   #389
QwaktastiK
Member#: 219100
2014 STI hatchback
Hmm...how awkward for me. That possibility definitely crossed my mind. 50/50 shot. I'll lose every time. Lol.
Could've been worse. Could've called you "brah." My apologies.
Good to see somebody else running the sport grille.
Old 01-31-2013, 03:45 PM   #390
SWP n Gold
Member#: 110783
2010 WRX
I definitely prefer the sport grille. Mine's black which makes for a nice contrast with the white car:
Old 01-31-2013, 03:50 PM   #391
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Well here is a fresh whore out of my build:
As most of you know this is my 2009 WRX, it makes 508whp and was fully built by MPS in Marysville, Washington.
This car has seen many many hours of work to get it to this point. I couldn't of done it without the support of my brother and the RSOC crew.
Here's the mod list:
2009 WRX Premium
Engine
MPS 2.5 Long Rod Shortblock 8500rpm
New EJ257 Semi Closed Deck Case
STi Crankshaft
ACL Race Bearings
MPS Saenz Super Strong +2mm Rods
Custom JE Pistons ceramic coated crowns / skirts
Full Blueprint and balancing
MPS Modified oil pump
MPS Stage 3 B25 Heads
+1 mm Ferrera Valves
High Performance Springs
Ti Retainers
Shimless Buckets
New Valve Seals
Full port and polish
Kelford R-199-B Cams
Turbo / Accesories
Cobb Accessport
Perrin GTX3576R .82 Turbo kit (reversed intake mainfold)
Tial 42mm External Wastegate
Perrin FMIC
Perrin downpipe
Invidia N1 exhaust with Ti tip
Agency Power UEL headers
ID 1000cc Injectors
ACT Street Clutch
ACT Lightweight flywheel
TGV deletes
Stock oil pan with Covert p/u
Walbro 255lph fuel pump
ARP headstud / rod bolts
Grimmspeed 8mm phenolic spacer
Forge Race series BOV
New timing kit
Cosworth belt guide
Mishimoto rad hoses
Perrin Oil Cap
Perrin Alternator Cover
AEM 900cc Water Meth with failsafe
Brakes / Suspension
Wilwood 4 piston BBK
Competition Cermaic Pads
DBA Slotted 2 piece rotors
Goodridge SS brake lines
BC RAM Inverted Coilovers
Perrin SS with bushings
Wheels / Tires
Rota Torque R (safety orange)
Federal SS 595 235/40/18
Audio / Visual
Pioneer AVHP4200DVD
JLG6600 amplifier
JLC3 components F
JLC3 coaxial R
JLW3 HO Sub and Enclosure (subaru red)
STI V-spec Lip
OEM Sport Grille
Tint
Cobb Knob
binjoau is offline   Reply With Quote
Old 01-31-2013, 03:53 PM   #392
mmfullen
Member#: 236685
2006 Legacy GT
Any more pics of the reversed intake manifold setup?
mmfullen is offline   Reply With Quote
Old 01-31-2013, 04:08 PM   #393
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Old 01-31-2013, 04:37 PM   #394
thenick
Member#: 199580
i been hatin'
Hellas since 2012
Sport grill = looks like a Mazda
So happy I got rid of mine for an OEM one
thenick is offline   Reply With Quote
Old 01-31-2013, 04:38 PM   #395
mmfullen
Member#: 236685
2006 Legacy GT
Wow...that's a whole new way. Pretty sure nobody else has done that. Bravo sir...bravo.
(might have to copy you once i build my motor. lol)
Old 01-31-2013, 04:40 PM   #396
thenick
Member#: 199580
i been hatin'
Hellas since 2012
What kind of grill is that on the red hatch and where did you get the s205 badge?
Old 01-31-2013, 04:40 PM   #397
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
That entire build list and thats what you come back with lol?
Im not a huge fan but stock is gross
Old 01-31-2013, 04:43 PM   #398
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
The S205 badge was custom made but I am having new ones now that the MPS build is completed.
Old 01-31-2013, 04:46 PM   #399
Stretch18
Member#: 239822
2010 WRX
pandiculation
Also, your green battery is the suck...
J/k, I love your car.
Stretch18 is offline   Reply With Quote
Old 01-31-2013, 04:48 PM   #400
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
hahaha! These are old pics! I have a black one now
