Welcome to the North American Subaru Impreza Owners Club Wednesday January 18, 2017
Old 09-04-2012, 11:09 PM   #326
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
Originally Posted by Bansheeboy11
It did on my car, stock ej20 with a catless exhaust. Vacuum/boost transitions and spool are improved a bit, as well as boost control at higher rpm.
I'll give it a try. Best thing about this mod is that its 100% reversible.
legacydreamz is offline   Reply With Quote
Old 09-04-2012, 11:10 PM   #327
Djimpreza02
Member#: 328135
2004 impreza WRX
So, I've only read up to page 11....
But is this a good mod or not? I heard the stock BOV should not be touched until your using over 22PSI of boost? Or else it will in-fact hurt performance.
Does this mod also cause any more of a blow off sound.
Djimpreza02 is offline   Reply With Quote
Old 09-05-2012, 07:56 PM   #328
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
It made my bpv more noisey and it holds boost alot better between shifts.
nate_fisher is offline   Reply With Quote
Old 09-06-2012, 03:31 PM   #329
d0ugch0i
Member#: 198861
2004 WRX
gnna try this out. hopefully i feel a gain
d0ugch0i is offline   Reply With Quote
Old 09-06-2012, 04:47 PM   #330
Djimpreza02
Member#: 328135
2004 impreza WRX
Has anyone seen the results on a tune or dyno? I think that is the major determination for doing this or not?
Old 10-15-2012, 04:14 AM   #331
d0ugch0i
Member#: 198861
2004 WRX
bringing this thread back to life. any more results anyone?
Old 10-15-2012, 03:54 PM   #332
tjdonovan
Member#: 334417
02 impreza wrx
black blue pearl
good idea wish i could do that to my parents but i'd need the money simple mods like this r what i like to see. got anymore simple cheap mods?
tjdonovan is offline   Reply With Quote
Old 10-16-2012, 12:12 AM   #333
scubywrx89
Member#: 325517
2002 wrx
blue
Just crush the bov it will work good
scubywrx89 is offline   Reply With Quote
Old 10-16-2012, 12:35 AM   #334
Bansheeboy11
Member#: 182415
1999 RS
My overboosting ended up being oily vacuum lines coming off the solenoid.
I got to really drive the car hard over the weekend with some buddies, did about 250 miles around the mountains over saturday night. Going from full brake to full throttle gets me nice, quick and steady spool, and a rock solid hold on the boost, quick vacuum/boost transitions seem to be a bit quicker/smoother as well. About 3 weeks ago we did this to another buddies car who also feels its improved driveability in the same ways i did, all in all this is a winner! I even bought some extra set screws incase my buddies want to do it haha
Bansheeboy11 is offline   Reply With Quote
Old 10-16-2012, 10:31 AM   #335
Harbs
Member#: 335235
05 Liberty GT
Originally Posted by Gil View Post
did this today on my 05 LGT.
i borrowed a 1/4-20 tap from a friend and then put one of these in there. 83 cents for a pack of 2 at home depot.
I've done this exactly.. with the +08 plastic valve and have seen no adverse effects. 3mm vent in the side. Can now run 19psi on this plastic version with stock VF38.
+1 for this mod.
Harbs is offline   Reply With Quote
Old 12-19-2012, 06:00 PM   #336
nate_fisher
Member#: 270482
2011 turbotek fxt
I am running this just like above on the plastic bpv but now am running a td06 20g at 22psi on e85. Do you think it will hold up or should i bite the bullet and buy a forge recirculating bpv? I think its still working fine and my tuner was impressed but just wondering how far you guys have pushed this mod befor the breaking point.
Old 12-19-2012, 06:19 PM   #337
SeeeeeYa
Member#: 129681
2017 FXT-T ES
SBM/SBL
Modded properly, the more boost the tighter the BPV will be held closed... as described.
In other words, you are fine.
SeeeeeYa is offline   Reply With Quote
Old 01-23-2013, 12:28 AM   #338
wrxgunr
Member#: 336361
2009 WRX 265
Excellent mod. Amazing bang for...well it didn't co$t me anything!
wrxgunr is offline   Reply With Quote
Old 01-31-2013, 08:21 PM   #339
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
For something as serious as drilling a goddamn hole in your BPV, you would think people would have some better photos.
I want to do this, since it's free, but I haven't gained the appropriate confidence here.
Where on the stock BPV do I drill a hole in it?
blehhh is offline   Reply With Quote
Old 01-31-2013, 08:40 PM   #340
bluemk3
Member#: 263694
Read the whole thread before your flip out.. They are on the second or third page
bluemk3 is offline   Reply With Quote
Old 01-31-2013, 08:46 PM   #341
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Those posts are from years ago, previous generation cars with metal BPVs.
Old 01-31-2013, 09:57 PM   #342
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
why not post a picture yourself?
Old 01-31-2013, 10:37 PM   #343
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Because I haven't done it?
Old 02-01-2013, 07:10 AM   #344
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i mean of your virgin oem plastic bpv, so that someone can point it out to you.
Old 02-28-2013, 12:13 AM   #345
norbs
Member#: 135787
Bumping this thread again. Anyone got a pic of the side vent hole they drilled on the newer plastic BPVs?
norbs is offline   Reply With Quote
Old 03-06-2013, 12:32 PM   #346
turkeylord
Member#: 89016
2005 Legacy GT Wagon
ABP
Just did this to mine last night - first drive definitely felt like it was easier to hold boost through shifts. Lovin it.
norbs - I drilled just high enough to be sure to clear the set screw.
turkeylord is offline   Reply With Quote
Old 03-06-2013, 04:16 PM   #347
KMA2
Member#: 254771
2011 WRX hatchback
silver - Stage 2
Also interest in this... thx.
[edit]
Found pics here: http://forums.nasioc.com/forums/show....php?t=2169450
So here are the pics needed:
Originally Posted by Seventh View Post
KMA2 is offline   Reply With Quote
Old 03-06-2013, 10:17 PM   #348
KMA2
Member#: 254771
2011 WRX hatchback
silver - Stage 2
Quick question: I've read through the thread, but I'm hoping someone can explain to me why the stock BPV valve isn't designed this way to begin with? Is it to avoid surge for the "normal" stock driver? Thanks in advance.
Old 03-07-2013, 06:44 AM   #349
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, the stock valve will open with less pressure differential.
why they didn't just use a weaker spring? who knows.
Old 03-07-2013, 02:33 PM   #350
Rescuer
Member#: 176692
thanks
Rescuer is offline   Reply With Quote
