Welcome to the North American Subaru Impreza Owners Club Saturday October 21, 2017
Old 01-25-2013, 08:22 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Lets talk bead rollers - tools to make humps on pipes
I found two types so far:
Vibrant piece goes for ! $280
and
Harbor freight piece goes for about $180
Not sure the HF unit can be used at all to roll beads on a IC pipe or anything else. The vibrant unit is pretty expensive for a tool that would be only used a couple times.
Are there other options out there to roll a decent bead? Yeah you could weld extra material onto the pipe, but that looks sloppy.
Bad Noodle is offline   Reply With Quote
Old 01-25-2013, 08:43 PM   #2
bmw325ix
Member#: 204652
I use the the vibrant, love the thing,
bmw325ix is offline   Reply With Quote
Old 01-26-2013, 03:00 PM   #3
Mr. Wagon
Member#: 244383
The vibrant has no throat depth so your highly limited in other uses after you roll your tube. The HF has what loos to be at least a foot of throat and a handful of dies. As long as you can get HF die inside your tube its a better buy. Although lower quality, it will do what you want and you'll have a tool that can be used for other projects.
Mr. Wagon is offline   Reply With Quote
Old 01-26-2013, 05:18 PM   #4
da_kernel
Member#: 325324
2010 STI Wagon
I use my welder to weld a bead around. Just never broke down to buy a bead roller.
da_kernel is offline   Reply With Quote
Old 02-11-2013, 04:40 PM   #5
Mechie3
Member#: 120152
I made one from a $15 harbor freight tubing cutter.
If I were to do it again, I'd leave more clearance between the arbor and the holder and I'd mount the arbor in a bearing so it can spin. As is, I put grease on the pipe I'm beading, which works, but isn't ideal.
Old 02-11-2013, 06:56 PM   #6
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ I like... any instructions on what is needed to make one?
Old 02-11-2013, 10:18 PM   #7
Mechie3
Member#: 120152
Cut a groove in one of the wheels, take out the cutting blade, make a holder for an arbor, make an arbor.
Old 02-12-2013, 02:11 PM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I like the idea but don't have access to machines to make this stuff. The hardest part is finding a grooved wheel and notched rod like you have. I was hoping you got those parts off another HF purchase.
Old 02-12-2013, 02:23 PM   #9
omiotek
Member#: 272090
We use one similar to the vibrant piece. Works awesome.
omiotek is offline   Reply With Quote
Old 02-12-2013, 02:33 PM   #10
alx8283
Member#: 225024
2002 wrx
If you're just doing a few ends...vice grips, a sturdy washer and a muffler clamp. Cheap but time consuming.
Edit. I found a link: http://www.d-series.org/forums/diy-f...ad-roller.html
alx8283 is offline   Reply With Quote
Old 02-12-2013, 05:30 PM   #11
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
Works even better if you weld the washer to the vice grips.
DeleriousZ is offline   Reply With Quote
Old 02-12-2013, 07:30 PM   #12
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I've seen those vice grip ones. Wonder if they work on SS ic piping. Aluminum, sure, but ss would make your hands hurt if it didn't break the tool
Old 02-13-2013, 03:41 AM   #13
alx8283
Member#: 225024
2002 wrx
^Al, oh yeah, all day. SS, it would have to be super light and even then it'd be a bear.
