02-22-2013, 09:34 PM | #5751 | ||
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
I'll mess with the tables some. It's not terrible, just needs some tweaking and it's a little different from the EJ205 ROM. Quote:
I think I have a good idea when it will spool, though... Here we are compared to a ~2 year old boost plot: http://i.imgur.com/A2YvJi7.gif If I'd have tried to select a turbo that would be closer to this boost curve, I surely would have failed. Happenstance is an interesting thing. I might gain a smidge with higher AVCS advance. This wasn't even enough load to push it to 40*.
02-22-2013, 10:14 PM | #5752 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
02-27-2013, 05:29 PM | #5753 |
Member#: 166324
NESIC
Is there anyone on these boards running an S204 engine?
02-27-2013, 10:39 PM | #5754 |
Member#: 224785
MWSOC
Vehicle:2005 wrx-jdm207 i went black... |
so hows the progress Concillian? im interested to see the power around 18-20psi. its spooling as quick as the 18G which prob put you around 340whp on the ej205? if you hit around 360whp at 20psi im going to break the bank and buy one myself sooner than i thought!
02-28-2013, 08:58 AM | #5755 |
Member#: 342863
Tri-State
Vehicle:2002 WRX PSM |
Alright so my wrx block's life is almost up and looking to swap it soon. Can someone point me in the right direction on which motor is best for a daily driver and i can hold some power. Thankyou
02-28-2013, 09:04 AM | #5756 |
Member#: 241491
Vehicle:2005 wrx v7 ej207- stimikey tuned |
Best for daily would be any kind of Honda. Holding power buy a supra... ;P
02-28-2013, 09:22 AM | #5757 |
Member#: 342863
Tri-State
02-28-2013, 09:36 AM | #5758 |
Member#: 241491
Lol... Your welcome!
Really depends on what your goals are for the car... Mine is daily driven and its basically just bolt on mods tuned by STI Mikey and I love it. Running a v7. I don't plan on getting rid of the vf turbo but I beat the **** out of my car and have not had any problems since I swapped which was over a year ago. |
02-28-2013, 10:06 AM | #5759 |
Member#: 306719
MWSOC
Vehicle:2003 Sti Wagon @jn_garage |
So this spring I plan on doing a 207 swap on a 2002 Wrx.
I had a few questions or maybe just ideas gloating around. If I have the motor pulled would it be wise just to do the following 12mm Sti oil pump Killer B oil pickup Sti oil pan Other than that it looks as simple as a motor swap with some pinning on the jdm Ecu. |
02-28-2013, 11:05 AM | #5760 | |
Member#: 197062
02-28-2013, 11:08 AM | #5761 | |
Member#: 57287
MWSOC
Vehicle:2002 Bugeye STi MY07 WRB FXT |
02-28-2013, 12:27 PM | #5762 | |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
02-28-2013, 02:29 PM | #5763 | |
Member#: 4414
13-14 psi is not slipping. I'm targeting 14 psi, but don't have quite enough max WGDC to keep that up at high RPM on my current ROM. ~280 TQ / 300 HP airboy with 13.2 psi at 300 HP area. For reference, the 18G at 20-22 psi was 300 TQ / 310 HP on the EJ205 using the same road, software, and weight / tire / gear settings. Lower than what I expected for the 18g for sure. My EJ205 never put out top numbers, was around 280 Tq / 265 HP on the TD04 / E85 @ 20ish psi. Right now at 13-14 psi on E85, my EJ207 is above my old EJ205 91 octane / TD04 @ 20psi line at every RPM. and it's only lower than the 18G line where the 18G was running 6-8 pounds more boost. I'm hitting 280 g/s and getting a little close to the 300 g/s limit, so next I'll tackle converting my current map to Carberry to get away from that flow limit. On the 18g I did a MAf re-scale to give me room, but I might hit the MAFv limit on this turbo, and I want to learn Carberry anyway, so I'll be doing that. It may take some time before you see a 16-20 psi plot as a result of learning SD tuning. Also, I didn't measure how quick it comes into boost at speed on the 18g, but if I cruise on the freeway in 3rd, it's like 4800RPM. It goes from vac to 14psi in about 500 ms with the EFR. It sure feels quicker to get back in boost than the 18G did, but I have no real data supporting that. 20+psi isn't going to happen until I decide to replace my clutch. I may be able to slowly taper it up to 20psi at 7000 to see what kind of peak power that would result in though. It was slipping from the high rate of change in torque at boost onset when I had spikes up to 20psi because of my inexperience tuning the 3-port. It may be able to hold smoother torque changes at high RPM... we'll see. It sure seems like 360 airboy at 20psi is within the range of possibility based on ~300 HP at under 14psi. Last edited by Concillian; 02-28-2013 at 03:55 PM. |
02-28-2013, 03:03 PM | #5764 |
Member#: 21339
HIIC
Vehicle:2002 LHD STI V7 6MT 12.9@103MPH EJ205 4EAT |
What is this sticker? It's kinda beat up in this shot though
02-28-2013, 03:28 PM | #5765 |
Member#: 3536
SCIC
Vehicle:2017 SWP BRZ PP, FXT 2002/2003 AW/PSM WRX |
02-28-2013, 03:42 PM | #5766 |
Member#: 21339
HIIC
02-28-2013, 03:56 PM | #5767 |
Member#: 221364
MAIC
Vehicle:2002 Wrx EJ207 Ver 8 Wrb Dccd jdm 6 speed now! |
02-28-2013, 04:38 PM | #5768 |
Member#: 175334
TXIC
Vehicle:2003 Impreza WRX JDM v8 EJ207 WRB |
Are there any USDM model year stock exhaust manifolds that are NOT compatible with the v8+ oil pan? I really miss the sound of UEL headers... and have been thinking about going back to that setup. But iirc... I can't keep a twin-scroll setup, if I go that route
02-28-2013, 05:15 PM | #5769 | |
Member#: 4414
The twinscroll AVCS passenger side oiling pipe was also incompatible with my EFR turbo kit. Luckily I had a USDM AVCS oiling pipe on hand. I don't know if this oil line interferes with a typical Subaru single scroll turbo, but replacing this was no small task, as the oil line goes UNDER the coolant crossover pipe, so required removal of the intake manifold and the coolant crossover needed to be pulled up like 1/2 - 3/4". If you used a braided teflon type of oil line, you could route differently and just cut out the twinscroll hard wall oiling line. Any hard line oiling line from the AVCS oiling line to the turbo is likely going to be in the wrong place, so you'll need to run an -4AN line at least part of the oiling line, but most aftermarket turbos require this anyway. The oil pan on the v8 is the same as the 04-05 USDM STi oil pan, near as I could tell. I had the 06+ oil pan on my EJ205. Last edited by Concillian; 02-28-2013 at 05:39 PM. |
02-28-2013, 05:20 PM | #5770 |
Member#: 856
International
Vehicle:2123 JDM STi Black |
The turbo oil feed line is a known weak point in the design. I had one fail on me. They crack at the the point just under the link joint between the rail and the turbo feed line.
I now run a -4 braided line on that side of the engine. |
02-28-2013, 05:45 PM | #5771 |
Member#: 107170
Vehicle:2002 ver 7 EJ207 WRX WRB |
02-28-2013, 05:47 PM | #5772 |
Member#: 856
International
indeed, the sticker is fitted there when new.
02-28-2013, 06:07 PM | #5773 |
Member#: 21339
HIIC
I thought I read it somewhere that's what it was but couldn't remember. Lol.
I believe it's that time so I'm going to change it for good measure. Should've done it a while ago but the leak down test before the swap was perfect and the mileage want that bad. I got the time and materials so I changed it. LOL |
02-28-2013, 06:16 PM | #5774 | |
Member#: 134272
HIIC
Vehicle:2007 Sti, UGM Rotated EFR 6758 |
02-28-2013, 06:25 PM | #5775 |
Member#: 21339
HIIC
Similar Threads | ||||
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
