Welcome to the North American Subaru Impreza Owners Club Monday June 26, 2017
Old 12-23-2012, 08:45 PM   #526
subySerb
Member#: 155411
Looks I have a head gasket leak. I'm at 75000 miles. Changed the coolant at 50k, didn't use the conditioner.
subySerb is offline   Reply With Quote
Old 12-23-2012, 09:25 PM   #527
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
That's not really bad. When it starts running down the subframe then that's bad
J.Gibbs is offline   Reply With Quote
Old 12-24-2012, 02:13 AM   #528
subbykc
Member#: 264573
2002 Legacy L
light silvergreen
Default Not my first rodeo BUT!!
Ok So I have a 2002 2.5 legacy L wagon and I am at 174K. I use to have a 96 legacy and it was in worst condition that my 02' and lasted 2 yrs of driving hard driving. I dont drive this on hard and when i got it in May of this year i took it to this Allpro Subaru for a survey. Everything look great except they mentioned the headgaskets wasnt bad but need to be replace in future. i held off knowing that i would want to change timing belt. Now my 02' is leaking coolant and the HG is the problem. I took it back in to be looked at and its gunna cost 2,200 to fix. I want to know what is the best steps to take here. I've read up on most of this stuff when i had my 96' just wasnt going to waste time in that car. this one i want to save. and keep for long. Im aware of the conditioning and multi-HG. I did not know and still not sure is the multi-HG a better solution. I don't think i got a quote for the multi-HG and i don't think i wanna pay labor for somehting i could probably do myself. Is the conditioning and HG replacement something you recommend doing myself. and multi-HG what do you think. I have two buddies with 2.5 one with 04 and other 01'rs im asking them now and probably work with them on mine. My friend matt is familiar with the 2.5 blocks.
Thank you in advance, well appreciated
subbykc is offline   Reply With Quote
Old 12-24-2012, 02:33 PM   #529
subySerb
Member#: 155411
There is oil on the subframe.
I went to the dealership to get an oil change (it's too cold to do it myself). Dealer is saying both of my head gaskets are leaking. He quoted me ~$1500 for parts and labor for gaskets and timing belt.
Update. I called SOA today asking if they can help with the cost of repairs, they said they'll contact the dealer and will let me know.
Old 12-28-2012, 02:22 PM   #530
scampbell2x
Member#: 231782
2001 2.5RS
schmilver
I recently did head gaskets on my 01 rs, i used 04 sti head gaskets and threw in a set of Delta 2000 cams while it was apart. She was leaking pretty bad. those of you getting quoted upwards of $1500, if you have a good manual and a little mechanic experience it really isn't that hard to do yourself.
scampbell2x is offline   Reply With Quote
Old 01-06-2013, 07:35 PM   #531
subbykc
Member#: 264573
2002 Legacy L
light silvergreen
As far as the technical details. like what pound pressure when loosening belts and tightening the bolts no head when installing. I wan to use aftermarket head gaskets like i mentioned above. I just figure the pound pressure and sequence would be different than using stock head-gaskets or other model HG. Any information in this ?
Thank you!
Old 02-17-2013, 06:08 PM   #532
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Looks like I need to start reading this thread
67,000 miles
daigledangle8 is offline   Reply With Quote
Old 02-17-2013, 08:40 PM   #533
Fusionf21
Member#: 335102
2008 wrx premium
grey
Anyone that had confirmed head gasket failures experience their overflow, overfilling and pouring out on the ground? I cant seem to figure out my problem. new thermostat didnt seem to help me, unless im air locked.
Fusionf21 is offline   Reply With Quote
Old 02-17-2013, 08:52 PM   #534
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Yup. Its the blown head gasket forming air pockets in the cooling system and they work their way up. Pushes the coolant out of the top of the radiator into the overflow tank. Run it for a while and its gonna fill up the overflow tank and leak out
Old 02-17-2013, 09:14 PM   #535
Fusionf21
Member#: 335102
2008 wrx premium
grey
**** well i guess im screwed. Is there a good "how to" on fixing this? Im fairly good with mechanics.
Old 02-17-2013, 09:16 PM   #536
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Yea. Just search on here. Also some good ones on RS25 and subaruforester.org. i believe even the outback site had a good how to for head gaskets
Old 02-17-2013, 09:18 PM   #537
Fusionf21
Member#: 335102
2008 wrx premium
grey
thanks man
Old 02-22-2013, 12:51 PM   #538
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
The turbo cooling systems are a little different to "burp" than the NA's. Check the "turbo engine" section to see the proper way to do it.
Old 02-24-2013, 01:35 PM   #539
mayurolla
Member#: 308427
I'm having this issue on my car as well. I have about 60k miles on my 08. Seems like a small oil drip leak and causing it to burn up on the exhaust. Is there anyway to temporarily seal this? Any subie guys in the chicago area that can replace the head gasket on the cheap?
mayurolla is offline   Reply With Quote
Old 02-24-2013, 02:15 PM   #540
subySerb
Member#: 155411
If you have an extended warranty, it should be covered.
Old 02-24-2013, 04:01 PM   #541
mayurolla
Member#: 308427
I don't have an extended warranty. The vehicle was previously in a collision.
Old 03-07-2013, 04:36 PM   #542
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
So, what did they do for you?
surowrxa is offline   Reply With Quote
Old 03-07-2013, 07:43 PM   #543
subySerb
Member#: 155411
Dealer quoted me ~$1500, SOA offered to pay $500 of that even though I was 5000 miles out the extended warranty.
Old 03-08-2013, 10:14 PM   #544
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
If you admitted to not using the conditioner this isn't too shabby. $1500 is a "low" dealer price, most on here are quoted 2K or more.
But for me to be ok with replacing HGs @ 75K SOA better fork more out for me...I have bought 4 new Subarus. The next sale would absolutely depend on it.
Old 06-15-2013, 12:59 PM   #545
subbykc
Member#: 264573
2002 Legacy L
light silvergreen
Default Aftermarket Multi-Layer Head-gasket
just got my 02 legacy back from the shop. She has aftermarket head-gaskets Multi-Layer gaskets with new timing belt, manifold gaskets machined heads, plugs the whole shebang! An running better than ever
Old 06-15-2013, 01:19 PM   #546
Turnyface
Member#: 330036
2014 WRX Hatch
My '09 2.5i had a head gasket leak at 28,000 miles. They replaced it under warranty and used a wrx gasket for the replacement. Sad.
Turnyface is offline   Reply With Quote
Old 06-17-2013, 11:28 PM   #547
Charlton
Member#: 43038
2002 Forester S
Replaced head gaskets on 02 Forester 152K miles with STI head gaskets. Replaced both heads.
Charlton is offline   Reply With Quote
Old 06-19-2013, 12:37 PM   #548
scoobytek0027
Member#: 357495
Just about every engine other than the 2.5s leak as a tech at a dealer I've seen 10 sti's to even some 11-12 foresters w. minor seepage.
scoobytek0027 is offline   Reply With Quote
Old 06-19-2013, 12:44 PM   #549
subySerb
Member#: 155411
11-12 Foresters have the new FB engine, are you saying that they have bad head gaskets as well?
Old 06-19-2013, 01:18 PM   #550
Somerset Subaru
Member#: 186498
For those looking for new OEM parts to do this job we have a kit for this. It is just for the head gasket job. No timing belt. You need to ask your dealer what is included. Out kit is $380.00 at our RETAIL price. For forum members I know I can get that much lower.
-Adam
Somerset Subaru is offline   Reply With Quote
WRX/STi axle back exhaust bolt on to NA 2.5? Kid Icarus Normally Aspirated Powertrain 10 09-04-2011 01:43 PM
Which head gasket will be most reliable for 2.5 / 2.2 hybrid? JoshP Normally Aspirated Powertrain 8 06-02-2006 03:27 PM
APEXi S-AFC on a NA 2.5 AngryBlueRS New England Impreza Club Forum -- NESIC 15 05-21-2004 10:07 AM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Warranty Issues & SOA Problems 20 12-12-2001 05:04 PM
Oxygen Sensor problems on 2000 Impreza 2.5 RS knoffer Normally Aspirated Powertrain 11 12-03-2001 01:42 AM
