Welcome to the North American Subaru Impreza Owners Club Friday June 23, 2017
Old 02-24-2013, 06:41 PM   #26
cjaghblb
Member#: 175868
Great thread, I intend to start my own thread having been at this track day thing for about a year but I need 3 good posts first! Here's #1.
cjaghblb is offline   Reply With Quote
Old 02-24-2013, 06:52 PM   #27
cjaghblb
Member#: 175868
BTW, I spent some time researching the brakes situation after getting quotes for an expensive DBA 2 piece rotor braking setup to justify the expense. I came to the conclusion that it wasn't warranted for my experience level and commitment to the sport. I did upgrade the following however, stepped up to stainless lines at each corner, Motul RFB 600 fuild, and Hawk HT-10 pads at all 4 corners. I did this after my 3rd event and am still going strong with this. I intend to step up to Hawk DTC-60 pads up front once the HT-10s are done to see if it improves me track experience (meaning times!). Post #2!
Old 02-24-2013, 07:07 PM   #28
cjaghblb
Member#: 175868
To submit an answer your question about tranny/diff oil. I run Motul Gear 300 75w90 in the trans and Motul Gear FF Competition 75w145 in the diff. I did this completely on the recommendation of an experience builder/racer so understand that I have no genuine experience on what would be better or worse. I intend to change once a year when I average about 2500 miles on the car between 12 or so events and travel to/from. Please provide your 2 cents if you have something better than this for a relatively stock drivetrained STi. Post #3....I am golden!
Old 02-25-2013, 09:06 AM   #29
mjfubar101
Member#: 132061
2006 STI
I use the Motul fluid in the diff and trans as well although for some reason your weights seem different than what I am using cjaghblb.
mjfubar101 is offline   Reply With Quote
Old 02-25-2013, 10:35 AM   #30
cjaghblb
Member#: 175868
Yeah, I got the two oils transposed, I will edit and correct it.
Old 02-25-2013, 04:04 PM   #31
yoshi0423
Member#: 249954
2005 STI
I've read that you should run the OEM Subaru LSD fluid in the rear diff due to design... 07+ you can run regular oil?
yoshi0423 is offline   Reply With Quote
Old 02-26-2013, 06:46 PM   #32
SubieEngineer
Member#: 208152
2004 350Zed Base
Sold: 07 STI LTD #576
Correct, you must run a LSD fluid (that has the friction-enhancing additives) in the 04-06 STI rear diff, and can run regular 75w90 transmission fluid in the 07+ STI rear diff. Reason: 07+ is torsen, and doesn't use clutch packs.
I can't speak for the 04-06, but my 07 transmission much prefers Subaru Extra-S compared to the Motul that I ran in it for a year. The rear diff didn't seem to care what it received.
SubieEngineer is offline   Reply With Quote
Old 02-27-2013, 09:44 AM   #33
cjaghblb
Member#: 175868
Can you expand on the comment about Extra-S? What feedback did the transmission give you that leads you to the conclusion that its a preferred oil. I am imagining that your shifts were more consistent/smoother with a reduction in difficulty completing the shift? Anything else?
Old 02-27-2013, 02:29 PM   #34
Griever423
Member#: 118749
2013 BRZ
Nothing wrong with running Motul synthetic in the rear diff. I did it on my STi and it didn't hurt it at all.
Griever423 is offline   Reply With Quote
Old 02-27-2013, 09:25 PM   #35
SubieEngineer
Member#: 208152
2004 350Zed Base
It seemed fine on the Motul at first, but the transmission gradually became more and more noisy. Additionally, when it was cold out (< 20*), it was much harder to get into 1, and from 1-2/2-1. Those particular shifts were much easier with Extra-S, and the transmission was quieter to boot.
Old 03-05-2013, 01:50 PM   #36
chrisbolton
Member#: 216597
+1 for looking into a miata for track days. Not to be discouraging from using your STI for track days. In fact owning a car with the potential the STI has seems silly not to use it for some type of motorsport. I'm just coming from a low budget mindset, and they definitely seem like the cheaper alternative to learning how to drive compared to building a DD for the track too. Just my 02, thinking out loud and more for my application I guess. Great advice guys, thanks. And OP your STI looks great, I wish I could build one!
chrisbolton is offline   Reply With Quote
Old 03-12-2013, 11:58 AM   #37
quattrocup
Member#: 332767
2013 Impreza Sport
Dark Grey
spend more on the most important upgrade, the driver. too many people jump immediately into getting the car faster before knowing how to actually drive it faster.
that being said, i'll throw my hat in for the star specs. i also run ate super blue without issues.
quattrocup is offline   Reply With Quote
Old 03-12-2013, 05:26 PM   #38
Ken Cravillion
Member#: 123985
2002 GMC Yukon
'10 Forester XT DGM
I remember my first track day. I had a Stage 3 Forester (VF39, etc...) with a Wilwood BBK. I ran their "street/track" pad. Little did I realize how much Road America feasted on brakes... Those pads lasted 3 1/2 20 minute sessions before they were ground to the metal backing plates. It was not fun driving 1.5 hours home downshifting and using the parking brake to stop. Do yourself a favor and get track pads. Put them in the night before and bed them in on the way there. That's worked for me doing track days since then.
Ken Cravillion is offline   Reply With Quote
Brand New To The Forum Need Some Help!!!! unreal2979 Newbies & FAQs 2 06-21-2007 02:18 AM
New to AWD and need some suspension advice ap0kalypse Brakes, Steering & Suspension 13 01-12-2005 05:13 PM
New to SoCal -- Need Some Help capt.sensible Southern California Impreza Club Forum -- SCIC 7 10-18-2003 05:36 PM
New to Boston - Need some help wooster New England Impreza Club Forum -- NESIC 4 08-03-2003 06:28 PM
I new to the Subarus..need some help MyLegacyHits152.5db' Legacy Forum 22 05-13-2003 07:05 PM
