Welcome to the North American Subaru Impreza Owners Club Monday May 29, 2017
Old 03-20-2013, 02:47 PM   #576
Hazmat Junkie
Member#: 350645
2002 WRX Wagon
Got temp tags and registered it!
Hazmat Junkie is offline   Reply With Quote
Old 03-24-2013, 03:09 PM   #577
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
just paid for my i88 and 14 pin harnesses
RooTBeeRthe1st is offline   Reply With Quote
Old 03-27-2013, 12:42 PM   #578
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Almost cut my finger off cleaning the windage tray in my parts cleaner. Like seriously, subaru stuffs razor blades in there engines so you don't tamper with them!!!
Sneeky Pete is offline   Reply With Quote
Old 03-27-2013, 07:41 PM   #579
wrx-auto-x
Member#: 140197
2000 RSTi
Blue Ridge Pearl
I bought a new clutch and Perrin front shift bushings
wrx-auto-x is offline   Reply With Quote
Old 03-27-2013, 10:59 PM   #580
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
got this for it.
Old 03-28-2013, 04:53 PM   #581
kiyo1990
Member#: 337674
1997 Legacy GT
Red
Originally Posted by RooTBeeRthe1st View Post
got this for it.
Well that looks very nice! How much did that run you if I may ask?
As well, here is what I did to mine...
kiyo1990 is offline   Reply With Quote
Old 03-28-2013, 05:25 PM   #582
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
i didnt much care for the looks of the early legacys, but yours looks good!
i picked it up wholesale $472
Old 03-28-2013, 06:36 PM   #583
kiyo1990
Member#: 337674
1997 Legacy GT
Red
I wasnt a huge fan of them either, but starting to like them a little more. As well, thanks! That isnt a bad price at all, i bet it looks good
Old 03-28-2013, 07:38 PM   #584
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
nah, they are going for $650+tax retail, so think i did alright lol
it does, i need to take my car in to the dealer for some warranty work before i install it though.
my rear defroster barely works, and when i turn it on while listening to the radio, i get a lot of static...think i need a new window
Old 04-05-2013, 02:22 AM   #585
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
Old 05-02-2013, 02:13 AM   #586
Thomistopheles
Member#: 320513
1997 Outback
4T6, red/gray
Most recent things I've done:
Pulled the black vinyl wrap off the hood, polished it, and threw a coat of Wolfgang Deep Gloss Paint Sealant 3.0 on.
Installed a UEL header (borla rep) and let my Legacy sing the song of its people for my buddy's neighbors... open header.
Tomorrow it's rear brakes and more exhaust work... it's all stock behind the UEL header right now. I should be lowering my outback this month, and I might put on my GT side skirts as well.
Thomistopheles is offline   Reply With Quote
Old 05-21-2013, 09:23 AM   #587
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
A few weeks ago I used it as a pack mule. First 10 bags of mulch, a few bags of seed and fertilizer (no actual pic of the loaded car):
Then the next weekend was a bunch of garden edging bricks:
I've certainly had more stuff (by volume) in the car, but these were pretty heavy loads. I was just about tucking tire in the rear, despite Tarmac2s with high spring rates.
Project this weekend has been to replace the valve cover gaskets, something I should have done a long time ago. What a frickin' mess. Here are before and after shots of the passenger side; the driver side looked just as bad. It's hard to see due to the poor lighting, but note the black (caked with oil and dirt) cross-member in the before picture compared to the clean cross-member in the after picture.
I basically got that job done last night (still need to reinstall the air intake, washer fluid reservoir, and battery), then decided to continue the cleaning by pulling the PS pump, which has also been leaking for a while. My initial inspection didn't reveal where it's actually leaking from, but there's PS fluid all over the top of the block. I'll be re-attacking that this evening after work.
Old 05-26-2013, 10:36 PM   #588
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Finished up all of the valve cover gasket work by replacing the negative battery cable and putting a new terminal on the positive battery cable.
Also replaced both front axles, as the low mileage OEM WRX axles I installed last year were spewing grease from the CV boots. Rather than fight with the mess of replacing the CV boots and installing new bands, I just got a pair of Subaru reman axles from Annapolis Subaru.
Old 05-27-2013, 12:39 AM   #589
Tahenry88
Member#: 347171
2005 Subaru LGT
I blew my motor up today. Oil feed line blew off the turbo and sent the oil squirting out the motor like a ketchup bottle.
Tahenry88 is offline   Reply With Quote
Old 05-27-2013, 12:54 PM   #590
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
^Yikes! not what i like to hear about anybody
Old 05-28-2013, 06:01 PM   #591
Hondaslayer
Professor PuddinPop
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Bought it Friday (95 LSi)
Saturday I replaced the left front wheel bearing and axle and the heater control panel (was missing most buttons)
Monday I removed all the interior for cleaning, dropped the headliner and repaired the sunroof. Apparently if there is a water leak the fix is to fill the track with silicone rather than reinstall the drivers front drain tube that fell off
Now I just need to tackle the usual 2.2 oil leaks / timing belt.
So far I'm into the car for $800 and it looks mint on the outside.
Old 05-28-2013, 07:53 PM   #592
Thomistopheles
Member#: 320513
1997 Outback
4T6, red/gray
New fuel filler neck installed, lowered using 03 WRX struts all around with wrx front springs and Outback rears.
Old 05-28-2013, 08:09 PM   #593
Hondaslayer
Professor PuddinPop
Member#: 4562
1995 Legacy LSi
Nice,
Got any side shots? I was thinking about going with WRX wagon suspension all round, probably with STi pinks and maybe Outback swaybars.
Old 05-28-2013, 11:41 PM   #594
RooTBeeRthe1st
Member#: 303525
'05 LGT Ltd 5EAT
Atlantic Blue Pearl
ordered some noise makers for it
Old 05-29-2013, 09:41 AM   #595
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Looks like that combo gives about a perfect stance.
Old 05-29-2013, 09:50 AM   #596
soloz2
Member#: 260128
2014 WRX 5 Door
Ice Silver Metalic
prepping my 98 OBW to sell. Great car, but the '14 FXT is fantastic.
soloz2 is offline   Reply With Quote
Old 05-29-2013, 02:38 PM   #597
Thomistopheles
Member#: 320513
1997 Outback
4T6, red/gray
Originally Posted by Hondaslayer View Post
Nice,
It's raked a bit, and I'd like to eliminate the gap. Definitely feels a bit better now that it's lowered a little, though.
Old 05-29-2013, 05:55 PM   #598
98legwag
Member#: 160325
09 Legacy 3.0R
Nice,
Here is my car. Its a 98 L with wrx wagon gr2s and wrx wagon oem springs. Also has Outback swaybars and metal endlinks. Handles well.
98legwag is offline   Reply With Quote
Old 05-29-2013, 07:43 PM   #599
Hondaslayer
Professor PuddinPop
Member#: 4562
1995 Legacy LSi
Perfect,
That gives me a good idea of what to expect. I want it about an inch or so lower than that, so STi pinks will be perfect.
My last Legacy wagon ended up on 08 Forester suspension with King springs and a body lift on 28in Grabbers
Old 05-30-2013, 02:28 AM   #600
Thomistopheles
Member#: 320513
1997 Outback
4T6, red/gray
That's the beauty of the Legacy, they can go up or down and look great either way.
I would have run WRX wagon struts, but my sedan stuff was pretty much free. Got a free TV, then traded that TV for suspension bits. Sedan struts make you lose a bit of negative camber. With my eibach camber bolts in the rear maxed out, I could only get -0.8. Another inch or inch and a half drop would put the height right where I want it.
98legwag, what end links do you have? I'm thinking upgrading my Outback's end links will be my next suspension mod.
So what mods have you done to your baja? 2003Baja Baja Forum 22 07-16-2004 03:31 PM
What mods have you done to your WRX? Diesel7 Canada Region Forum 3 11-02-2002 12:16 AM
What have you done to your RS lately? CosmoTheCat North West Impreza Club Forum -- NWIC 8 03-27-2001 10:55 PM
What have you done to your impreza? Hades69 General Forum Archive 2 02-17-2001 07:39 PM
