04-10-2013, 05:57 PM | #10076 |
Member#: 288190
Vehicle:2009 Impreza 2.5i Spark Silver |
Thanks guys! Wheels are 18×9.5+34 wrapped in 225/40's. Fitment in the front is really tight with the dampening almost at full stiff. Fenders rolled all around. Gna go lower in the rear once I put the RCA's on. Would post more pics but dont know how to use photobucket on my phone lol
04-10-2013, 07:40 PM | #10077 |
Member#: 229726
Tri-State
Vehicle:'09 2.Slow OBP |
Yup. So the headunit went out while playing a CD just now. Probably just means the HU is on its way out, right?
04-10-2013, 08:07 PM | #10078 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
threw on my stock wrx wheels on my obs. holy **** they look sexy.
04-10-2013, 10:27 PM | #10079 |
Member#: 326539
MWSOC
Vehicle:2008 Impreza 2.5 newport blue |
How hard is it to change out the speakers on the door? On my last car I had to ghetto right spaces so the window could roll down, I amped the speakers so I didnt use the stock speaker wire connector things. Can you swap speakers with out rewiring?
04-10-2013, 10:32 PM | #10080 |
Member#: 262503
MWSOC
Vehicle:2008 Impreza 2.5i |
Lol yes. Pull off the door panel, get some wire adapters (or solder to existing wiring), and get some speaker spacers..done.
04-11-2013, 03:18 PM | #10081 |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
I just changed my front speakers a couple days ago.. it is pretty simple. It was a little more difficult with the extra step of templating to install some dynamat type stuff, but it is pretty straightforward.
Be very careful prying off the armrest where the buttons are. The middle tab always wants to break off. If you get lucky and do not break off the plastic tab the first time, put a little white lithium grease on the metal clip attached to the plastic tab so that subsequent removals are easier. It actually works fine without that tab though.. |
04-11-2013, 05:17 PM | #10082 |
Member#: 336415
Vehicle:2011 Impreza limited Black |
My rims came in today
04-11-2013, 06:15 PM | #10083 |
Member#: 262503
MWSOC
04-11-2013, 06:32 PM | #10084 |
Member#: 262503
MWSOC
Here's my latest addition..
Tuned to the stage 1 - 87 octane map with stock intake. Power is now immediate and smooth. Starts to really pull at 4k. I'm also noticing an increase in gas mileage. I will be tuning to 91 octane after this tank. I know the AP dyno isn't 100% accurate but I thought it would be fun to do a few pulls in 3rd gear. My starting RPM was 2,000 and ending at 5,000. Results are definitely taken with a grain of salt, but they aren't too far off from other dynos done. The engine is now more 'alive' feeling. When you hit 3k it doesn't feel like it has to shift or that you are hurting it. This> http://www.rs25.com/forums/f5/t71821...ned-today.html This> http://www.efilogics.com/dyno/graph....rgb1=000000255 Here's my AP results. All of my test runs were all in the same ballpark within 5hp/tq of eachother. |
04-11-2013, 06:51 PM | #10085 |
Member#: 283606
Tri-State
Vehicle:2008 Impreza 2.5i Silver |
Fancyfootwork15 glad your happy with it
04-11-2013, 06:53 PM | #10086 |
Member#: 326539
MWSOC
04-11-2013, 08:20 PM | #10087 | |
Member#: 304055
Vehicle:2008 2.5i Rallisport UEL Headers Magnaflow CBE |
04-11-2013, 09:12 PM | #10088 |
Member#: 283606
Tri-State
04-11-2013, 09:42 PM | #10089 |
Member#: 336415
04-11-2013, 10:15 PM | #10090 | |
Member#: 304055
04-11-2013, 11:05 PM | #10091 |
Member#: 352610
04-11-2013, 11:46 PM | #10092 |
Member#: 249696
South East
Vehicle:2010 Outback Sport Black |
04-11-2013, 11:57 PM | #10093 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
TeeHee...
04-12-2013, 01:18 AM | #10094 |
Member#: 21542
BAIC
Vehicle:2011 Impreza 2.5i Dark Gray Metallic |
04-12-2013, 01:41 AM | #10095 |
Member#: 309331
04-12-2013, 07:13 AM | #10096 |
Member#: 229726
Tri-State
04-12-2013, 09:16 AM | #10097 | |
Member#: 146287
BAIC
Hey... This is only my... 6th?...
Yeah, 6th, set of wheels. 17x9+45 Quote:
If it's not working (broken) it's on its way out, yes. |
04-12-2013, 10:08 AM | #10098 |
Member#: 197937
E. Canada
Vehicle:2016 Golf R Under the radar silver |
04-12-2013, 10:16 AM | #10099 |
Member#: 229726
Tri-State
This was the original issue:
"Weirdest thing just began happening a couple of weeks ago. I'll be driving normally either to work or where ever and the speakers will randomly just shut off. A faint *THUD* noise comes from the speakers and the sound is cut off. Radio is still on and my i-pod player is still on. The only way to reset it is to turn the car off, and then back on. It'll happen every ~5 times I go somewhere and it's beginning to get incredibly frustrating. Anyone have any idea what it could be? Edit: I don't listen to music at a high level." And now the speakers shut off playing either CD or AM/FM. The HU stays on though... |
04-12-2013, 12:36 PM | #10100 |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
Similar Threads | ||||
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
