Welcome to the North American Subaru Impreza Owners Club Sunday August 20, 2017
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 05-08-2013, 11:00 PM   #3251
SRP02WRX
Member#: 292138
2005 STi
What are the fuzes labeled as. The only ones that say fans are black an I don't know how to tell if those are bad or not
SRP02WRX is offline   Reply With Quote
Old 05-08-2013, 11:52 PM   #3252
wayward167
Member#: 253998
13 BRZ
Do you have a volt meter? Check for resistance.. If it's not crazy low/ zero then it's blown.
Fuses are cheap you could always just replace and check the connections as well.
wayward167 is offline   Reply With Quote
Old 05-09-2013, 05:58 AM   #3253
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
this is your fuse box, i think, for the most part...
http://www.subaruforester.org/vbulle...se-box-lhd.jpg
Shows the location of the fan relays and fusing. this diagram should also be inside the lid of your box.
neko is online now   Reply With Quote
Old 05-09-2013, 08:43 AM   #3254
RedCelicaTRD
Member#: 212731
The fans still turn on so it is not a fuse problem. If the fuses were bad the fans wouldn't ever turn on. If the fans are turning on to late, I would suspect an air bubble in the system, or somehow the signal to the ecu is getting affected.
RedCelicaTRD is offline   Reply With Quote
Old 05-10-2013, 12:59 AM   #3255
skyline2240
Member#: 257636
05 STi
Started to run the wires for my pass heated seat tonight. Getting the wires through the rubber covering between the door and car was a PITA.
skyline2240 is offline   Reply With Quote
Old 05-10-2013, 10:40 AM   #3256
neko
Member#: 46500
Now with 200% more
I concur, perhaps a bad rad cap...
Old 05-11-2013, 12:04 AM   #3257
neko
Member#: 46500
Now with 200% more
I heard this rumor that someone saw a couple EvoX's hanging out at a cell phone repair place today...
Old 05-11-2013, 12:15 PM   #3258
skyline2240
Member#: 257636
05 STi
You would be correct sir
Old 05-11-2013, 12:50 PM   #3259
mert34
Member#: 183598
2015 WRX
one of them was not me lol
mert34 is offline   Reply With Quote
Old 05-11-2013, 01:02 PM   #3260
skyline2240
Member#: 257636
05 STi
Well it was ur car
Old 05-11-2013, 08:19 PM   #3261
neko
Member#: 46500
Now with 200% more
Originally Posted by skyline2240 View Post
Well it was ur car
Hmm. I wondered about that... didn't hear about a white STi there.
Old 05-11-2013, 08:28 PM   #3262
skyline2240
Member#: 257636
05 STi
It's currently not mobile
Old 05-12-2013, 11:44 PM   #3263
SRP02WRX
Member#: 292138
2005 STi
Does anyone know how to recharge a sprinkler system? I need mine turned on an I have no idea how it all works...
Old 05-13-2013, 12:08 AM   #3264
neko
Member#: 46500
Now with 200% more
Are we setting it up for R134?
Lawn air-conditioning sweet...
You do mean just open the water again? You should have a main shut off valve setup/backflow-preventer somewhere. Either its shut off there, or at a main shut off up-line from there. Mine for instance is next to my main water inlet into the house right after it hits the pressure tank. Turn that on & there would be pressure into my main valve body & line for all the zone valves.
I'm sure someone else on here in the poky area has an in-ground setup. Wayne?
Old 05-13-2013, 02:36 AM   #3265
mert34
Member#: 183598
2015 WRX
Like he said look for a valve off the main line inside that's closed. Mines right off where it enters the house before my water softener and such.
Old 05-13-2013, 11:38 AM   #3266
wayward167
Member#: 253998
13 BRZ
If you have open drain valves you'll notice when you open the main inlet to the sprinkler system ( mine is next to the house main by my furnace)
So open the main and if you have already open drains close those. Done. You'll get air through em as it fills up. Keep an eye on it for the first day or two to check for leaks since it froze early last year.
Old 05-13-2013, 12:26 PM   #3267
mert34
Member#: 183598
2015 WRX
Yeah, had to replace the valves outside the house this year even though i had them blown out last year.
Old 05-13-2013, 01:04 PM   #3268
neko
Member#: 46500
Now with 200% more
Plastic zone valves or the main backflow? Above ground (backflow anyway)?
Was a fairly mild winter, surprised to hear of damage. I just blow it out, leave zone valves open partially at least, drain it in the basement, that covers it.
Old 05-13-2013, 03:34 PM   #3269
mert34
Member#: 183598
2015 WRX
it was above ground lol
Old 05-13-2013, 07:37 PM   #3270
SRP02WRX
Member#: 292138
2005 STi
Yeah I have no idea what I'm looking for or how to turn it all on...
Old 05-13-2013, 08:43 PM   #3271
SRP02WRX
Member#: 292138
2005 STi
Ok I got the water going but I don't know how the get all of the sprinklers to turn on. Only a few in my back yard do and they don't spray very far...
Old 05-13-2013, 09:48 PM   #3272
mert34
Member#: 183598
2015 WRX
Interesting. Have you found a underground box yet with the zone valves? I would check them over. Is one valve works and another does not swap plugs to see if its the power to it or valve.
Old 05-13-2013, 10:28 PM   #3273
neko
Member#: 46500
Now with 200% more
Yup, a full system should have:
- Main line in>backflow preventer>Main line around the yard.
- valves tee'd off of the main line to the line for each zone. (usually in sub-ground boxes)
- electronic control box to control all the valves so you can set time/duration/etc for each zone.
Each valve should be able to be manually opened, so once you get main pressure on, you can test all of them one way or another, even if your electronics aren't hooked up or working right.
Each head will probably also be adjustable in one way or another for (some of these) volume/spray pattern/distance/angle/etc.
Once ya get familiar with your layout, and get all the heads adjusted accurately, they're super nice to have. They're also fairly easy to install/repair/expand without much hassle or needing $$$ tools or anything. Automated drip setups for flowerbeds/greenhouses are a cinch. I wouldn't have a nice lawn without it (not that I do...)
Old 05-13-2013, 11:08 PM   #3274
skyline2240
Member#: 257636
05 STi
Anybody know torque specs for 05 brembos? Neko chime in.
Old 05-13-2013, 11:56 PM   #3275
neko
Member#: 46500
Now with 200% more
Can 'o worms boy...
So, to be clear, are you asking about the caliper>hub mounting bolts? (technically, thru-hub-into-caliper moutning bolts) I.E. you pulled your calipers off to change rotors?
Well, here's the dispute. FSM calls for 114lb/ft. Lots of people use that. Lots of people strip out or break bolts. People have called Brembo on this, and they seem to say 80lb/ft. If so, that's a decent difference. People have been using the 80 spec for some time with no issues.
Eastern Idaho owners(or any ID really) Check-In!!! Local Get-togethers?? neko North West Impreza Club Forum -- NWIC 386 05-12-2010 06:01 PM
Tuners in Northern Wyoming/Eastern Idaho? bryancregger Rocky Mountains Impreza Club Forum -- RMIC 3 01-06-2010 11:05 AM
NWIC - Official "I saw it on Craigslist" Thread Dena North West Impreza Club Forum -- NWIC 4 11-02-2008 10:19 PM
