Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 07-25-2013, 03:09 PM   #101
raanster
Member#: 351467
2002 Impreza WRX
Sedona Red Pearl
xluben.. What's your take on an aftermarket TGV, in particular MAW TGV risers? Curious if you plan to do the DIY TGV delete or opt for one of these, especially since there's now a group buy for it right now.
raanster is offline   Reply With Quote
Old 07-25-2013, 03:45 PM   #102
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I like them a lot from a heat standpoint. The cost isn't that bad either. As long as they don't cracked when being torqued down I would think they would do a good job. I may pick up a set eventually. My other build just had the TGV components removed and the holes welded and it worked just fine.
Old 07-25-2013, 10:14 PM   #103
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Default MAW TGV Deletes
Not to clog up his thread, but since you asked I recently installed a set of MAW TGVs in my bugeye. I was already removing the manifold to do the fuel line fix and some other things, so it was a no brainer. From a heat and weight standpoint, they seem to be the best option. And I also like the O-ring seals vs. the OEM type gaskets between the TGVs and the heads. One thing to note: You will have to enlarge the two center holes on each end of your manifold in order to make all the studs from the TGV fit. I hated to grind away on a brand new powdercoated manifold, but I used a rat-tail file and it turned out OK.
thrasher is offline   Reply With Quote
Old 07-25-2013, 10:54 PM   #104
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
Ben - I'm so psyched you are building a Bug Eye. My son and I picked up a blue one as a project for him to work on and drive in a couple years. This thread will be great motivation for our little project I expect. Ours is rust free (since it has lived most of its life in TX) but we need a driver fender and hood. We will be following this thread with great interest. BTW - ours has a VF43 (I think), STI TMI, DP and external WG. I need to do a virtual Dyno plot and see what it is making compared to your stock setup.
Scnsaracer is offline   Reply With Quote
Old 07-26-2013, 04:03 PM   #105
BbugWag
Member#: 205629
'04 v7 207 WRX
Dull version of JBP
This makes me miss my bug eye a bit. I wish you the best and can't wait to see how this turns out! I creeped on your last build so I know this should be good.
BbugWag is offline   Reply With Quote
Old 07-26-2013, 04:59 PM   #106
hliu320
Member#: 351187
2013 WRX 4dr
-____- u make me want to buy a bugeye. must. resist.,
hliu320 is offline   Reply With Quote
Old 07-26-2013, 10:07 PM   #107
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My brother and I built some wooden ramps the other night. Menards did the cuts. We just drilled some pilot holes and nailed them together. Each step is 1 foot. Works great!
Old 07-26-2013, 10:18 PM   #108
dsn112
Member#: 332561
2015 GTI Autobahn
There is a completely stock 02 bug eye wagon by me for sale. It has 60k original miles on it....... Really want it
dsn112 is online now   Reply With Quote
Old 07-27-2013, 01:13 AM   #109
raanster
Member#: 351467
2002 Impreza WRX
Sedona Red Pearl
Get it now!!
Old 07-27-2013, 12:07 PM   #110
dsn112
Member#: 332561
2015 GTI Autobahn
Get it now!!
It's 13k and I have only made a small dent in my 2013 loan or I would
Old 07-27-2013, 01:37 PM   #111
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, that's the problem. People want way too much for the clean ones. I picked this one up for less than a third of that. It has its issues but it runs and overall is in decent shape so I was pretty happy about it.
Old 07-28-2013, 01:02 PM   #112
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
More parts going on:
Old 07-28-2013, 01:08 PM   #113
dIrTy-StI
Member#: 322280
2002 Subaru WRX
What lip is on the yellow wagon? I really like it
dIrTy-StI is offline   Reply With Quote
Old 07-28-2013, 10:30 PM   #114
QwaktastiK
Member#: 219100
2014 STI hatchback
Subscribed. If I could do it all over again I'd get a bugeye wagon. Good luck. Looks like you've got a good start so far.
QwaktastiK is offline   Reply With Quote
Old 07-28-2013, 10:59 PM   #115
vteclol
Member#: 280855
Thank you for putting the bugeye scoop back on. There is nothing I hate more than an 04-05 scoop on a bugeye. Interested to see how this turns out.
Subscribed.
vteclol is offline   Reply With Quote
Old 07-28-2013, 11:48 PM   #116
kevosti
Member#: 269463
2012 WRX STi Sedan
Has this car been hacked on much or has it been maintained as a stock car for its 10 year life?
Looking forward to what you have in store for us xluben
kevosti is offline   Reply With Quote
Old 07-29-2013, 05:00 AM   #117
shunworm
Member#: 332783
2003 WRX
Excited for this. Subscribed.
shunworm is offline   Reply With Quote
Old 07-29-2013, 10:09 AM   #118
besthaticouldo
Member#: 279660
stealing this idea. i was thinking maybe putting a rubber pad on the bottom so they dont move when you try and pull onto them.
besthaticouldo is offline   Reply With Quote
Old 07-29-2013, 10:29 AM   #119
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I don't know but I might have to try and find a lip for mine. Need to hide the cracked bumper...
I like my current arrangement. I think I liked the 2011 WRX more, but this is far more practical. The Bugeye was on stands in my garage all last week. That just wouldn't have worked with the 2011 since it was a daily driver.
Subscribed.
The other scoop was just some cheap eBay thing. This one is OEM and looks nearly new. The only issue I found is that it's not quite the same silver color! Oh well, it isn't that noticeable.
The car appears to have been totally stock. He cut the muffler off (it may have rusted off) and put in a stereo. He had a subwoofer, but took it out before selling. At least I was left with a nice run of power wire for a hardwired fuel pump at some point.
The previous owner did replace the timing belt, water pump, and both heads in the spring. I guess one or both of the stock heads had a crack, so this motor has shiny new heads on it.
That would probably help. These are fairly heavy so they haven't really moved much, but I always used two 2x10's stacked up (not nailed) for my 2011 WRX to drive on (so that the jack would fit under). And occasionally they would shift a little as I drove onto them. Mostly the top board though. The one on the ground usually stays put. Rubber wouldn't hurt though.
Old 07-30-2013, 04:45 AM   #120
enjoilife1991
Member#: 322400
03 WRX 360whp
so excited!!!
enjoilife1991 is offline   Reply With Quote
Old 07-30-2013, 09:36 AM   #121
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
STI fuel pump hanger and Walbro 255 pump:
Old 07-30-2013, 10:49 AM   #122
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
V2 lip...DO IT
Jive Turkey is offline   Reply With Quote
Old 07-30-2013, 11:16 AM   #123
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That lip might be a bit too aggressive...
But it would hide the cracked bumper pretty well...
Old 07-30-2013, 11:18 AM   #124
jesup16
Member#: 306393
2017 GTI DSG
'99 Corvette FRC
I also followed your other build...sorry about the car. Things have a funny way of working out.
I think you've put yourself in a better situation with a DD and a project car. I was debating this path and was looking at 02/03 bugeye's. In the end I went with a e36 M3 for a project...as I wanted something that would be good for auto-x and track days (not that a bugeye wouldn't be, but n/a and rwd are typically better platforms for my goals).
I'll be paying attention as this was my other option that I didn't pursue. I know you're targeting 10 sec's...but are there any other goals?
jesup16 is offline   Reply With Quote
Old 07-30-2013, 11:30 AM   #125
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Nope, no specific goals really. It's not meant to be a track car. Just a weekend/street fun car. Something that can run at least 10's (but it won't be spending its life on the track). I guess my one goal is that it will be faster than my 2011 WRX was. Eventually.
