Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 07-30-2013, 11:47 AM   #126
jesup16
Member#: 306393
2017 GTI DSG
'99 Corvette FRC
Nope, no specific goals really. It's not meant to be a track car. Just a weekend/street fun car. Something that can run at least 10's (but it won't be spending its life on the track). I guess my one goal is that it will be faster than my 2011 WRX was. Eventually.
There's nothing wrong with that. That was my previous build, just a fun and fast weekend toy. It did low 12's and that was enough for me. Then I got hooked on the track experience.
Keep up the great work and all the awesome pics. Who knows, I may reference this one day for a future build...
jesup16 is offline   Reply With Quote
Old 07-30-2013, 11:54 AM   #127
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The 2011 should have done 10's in full street trim. It was fun but I wouldn't mind if this one was a little faster. The lower weight should help. Especially if I lose some of the unnecessary things (since it's not a daily driver).
Old 07-30-2013, 12:30 PM   #128
worldrallyblue03
Member#: 354228
2003 WRB WRX
Really nice build you have going on here and great photos to match! I'll be keeping a eye on this one. I installed the Perrin cat-back early this summer and love it a lot, good choice.
worldrallyblue03 is offline   Reply With Quote
Old 07-30-2013, 01:17 PM   #129
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Round 1 of Mods (Bolt On's) - Part 1:
Last week I started getting my first round of parts in. I believe I started work on the 19th or 20th. The plan was to swap the springs/struts (they were making noises) with some STI take off's that I bought, remove the front subframe (very rusted, want to save weight), and the install uppipe/downpipe for a basic "Stage 2" setup. I hadn't found a turbo, fuel pump or fuel injectors for cheap so I figured a TD04 pump gas setup would be fine for now. My brother was installed a DCCD controller into his 6 speed swapped Bugeye so we both worked at the same time, and he helped me out when needed. His finished up after a few nights, but he still stopped over most other nights to give me a hand finishing up my stuff.
I started by removing the stock TMIC and Y-Pipe. Then I removed the stock downpipe. It came off quite easily except for one stud that unthreaded from the turbo (instead of the nut coming off). I didn't see any major damage to the threads so I think it might still be OK once I put a new stud in. This car never had any performance mods, but it did have the timing belt and heads replaced last spring so the motor has been out recently (which should help with bolts being broken loose). I also removed the stock exhaust. The muffler was already cut off, and when I took the cat back off it broke in half because it was so rusted. The downpipe to catback bolts were frozen together and so rusted that a wrench wouldn't even grab them. I ended up having to just cut them in order to separate those two parts.
I got the car up in the air and the thing I was going to do was the front subframe. Unfortunately it was so rusted that I could only get about half the bolts loose. I broke one and rounded one. Several just wouldn't budge. I decided to move onto the struts. I only got 2 of 8 strut bolts loose. The impact gun wouldn't even move them. That's about all the further I got the first day. I then bought a bigger breaker bar and some short, 6-side, impact strength 1/2" drive sockets to go with it. Using the bar and sometimes even a longer bar for more leverage I managed to get all of the strut bolts broken loose. I also got all the brake line mounting bolts and clips loose as well. I replaced one of the struts at this time, but then went back to working on other things.
At this point I removed the stock headers and uppipe. This all went fairly smoothly. Sometime around this time I was able to pick up a VF39 locally so I pulled the TD04 off and put the VF39 on. No real issues with this. The inlet actually went of surprisingly well. That one one of the hardest parts of the stock location turbo swap I did on my 2011 WRX. Now that the turbo was in place I put the GrimmSpeed uppipe on and loosely bolted it up. Then I put the exhaust manifold assembly on. I loosely installed all bolts. Then as I was tightening one of the nuts onto the stud on the driver's side head the stud spun and stripped out the head!
It appears the stud was only threaded in a few threads and I didn't notice. It looked like there was probably enough threads deeper in so I put the stud back in and tightened the nut down. Then I went to the passenger's side and one of the studs did the same thing! This one pulled out nearly all the threads so there was no way to use it in that condition. So I pulled off the headers and uppipe. Then I bought an M10-1.25 Helicoil kit the next day. To give myself more space I finished removing the front subframe. I got a few more of the bolts out but I ended up breaking the welded nuts off inside the frame. I had to cut one and then I just bent the subframe until it broke off the remaining ones. I drilled out both of the holes in the head with the proper 13/32" drill bit and then tapped the holes as deep as I could. Due to the taper on the end of the tap they bottom out before there are threads all the way into the hole. Because of this I had to cut a couple coils off the threaded insert for it to be able to sit slightly below the surface.
Doing this repair under the car was difficult and not ideal. My studs did not end up perfectly straight but they were good enough that the stock headers slipped on without any issue! I put the uppipe back on again, and then the headers. All nuts torqued to spec and didn't spin! I actually used a torque wrench this time, and came to the realization that I probably waaay over torque a lot of bolts. Probably 2x what they need to be... Then I finally put the GrimmSpeed downpipe on. I also put on the midpipe section of the Perrin exhaust. It is missing the v-band clamp so the muffler portion couldn't be installed. The clamp is on order. This basically how far the car was as of Friday night (approx 1 week after I started). It was probably a good 2-4 hours most nights last week. The little hiccups really added to the time. Thanks to my brother for the help swapping parts. Here are some photos and then onto Part 2!
Old 07-30-2013, 01:17 PM   #130
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Round 1 of Mods (Bolt On's) - Part 2:
Throughout that week of work I managed to accumulate some more parts so these had to go on as well. I also had found my stock 2011 WRX injectors so I stopped over at NF and Nuke modded them for me. It only took him a few minutes. Brian from NF took them to get cleaned and flow tested. On Saturday Brian from NF came over with the injectors and to lend a hand with the rest of the install, and my brother stopped over again too. The first thing that had to get done was finishing the suspension swap. Brian worked on this. First he had to pull the backseat. When he did this he found a mouse nest on top of the strut mounts! And when he was pulling it out he found a mouse! Gross. Glad that's gone.
While Brian was doing that my brother was assembling the Y-pipe and TMIC parts. I was working on getting the green brackets off to install the injectors. Since all the bolts were broken loose on the struts it didn't take Brian long to get them all swapped over. Then he finished up the injector install. All of the injectors flowed right around 1000cc. There was a little variation but not enough that it should matter. These should be plenty for the VF39 on E85, and even something like a 20G if I decide to go that route. After re-seating the injectors a couple times they were all installed and sealing properly. I installed the GrimmSpeed MBC while the TMIC was still off. It is a simple install and I mounted it to an existing bracket (I had to drill out the hole slightly).
Then we moved onto the TMIC. With the GrimmSpeed pipe kit you do have to cut quite a bit off of the 90 deg silicone coupler, but once we did that it was a good fit. The BPV return hose was very difficult to get on because of the tight space to work with when installing a larger TMIC. We also installed the GrimmSpeed splitter and the OEM Forester XT scoop from zbailey129 (Thanks!!!!). The scoop doesn't quite match my paint, but it's close enough for me. The OEM scoop required nuts (instead of the bolts the eBay one used), so I had to go get those the next day. I also removed the wing (holes are just covered with tape right now).
Sunday I got the bolts I needed to finish putting on the scoop. I bolted that up. Then I also went at removing the fuel pump. Unfortunately I had already put the back seat in, so I had to pull that back out because there just wasn't enough room without doing that. The housing was really rusty and dirty and a snapped one stud while removing the nuts, but the rest were fine. On Monday the new fuel pump hanger with Walbro 255 arrived. It is a newer model hanger that includes the small "surge basket" around the pump inlet. This should help slightly on long turns or hard acceleration with low fuel. The hanger itself was in much better shape then my stock one. I dropped it in and bolted it down. Everything seemed fine. I couldn't start the car due to the new injectors.
Later on last night I picked up Nuke so he could flash the car. He did that but then it wouldn't start! The battery was very low. The interior lights worked, but it just wouldn't even try starting. We jump started it with the Forester, but then once I went to drive off it died again and wouldn't start. So I swapped in the battery from the Forester. Then the Bugeye fired right up. We drove to the shop and then had to burp the coolant (from swapping the turbo) and fix a couple small boost leaks. Nuke did a quick pump gas tune and we got up to around 18psi. It is a lot more lively than it was before! The VF39 spools a bit later than on the 2.5L but the top end feels good and holds on to 7k pretty well. I will enjoy it at this power for a few days and then switch over to E85 once my tank is empty.
Thanks to Brian from NF and my brother for help with the install! Thanks to Nuke for the tune!
Old 07-30-2013, 01:20 PM   #131
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Current Mod List:
Engine:
  • Stock 2.0L with 185k Miles
Intake/Exhaust/Fuel:
  • GrimmSpeed CrossPipe
  • GrimmSpeed Uppipe
  • GrimmSpeed Downpipe
  • Perrin CatBack Exhaust
  • IHI VF39 (STI) Turbo
  • GrimmSpeed Gaskets
  • GrimmSpeed TMIC w/Gold Tape
  • GrimmSpeed TMIC Splitter
  • GrimmSpeed Y-Pipe Kit
  • GrimmSpeed MBC
  • 04 STI Fuel Pump Hanger
  • Walbro 255 Fuel Pump
  • Modded 2011 WRX Injectors (1000cc)
Drivetrain/Transmission
  • Stock
Suspension/Wheels:
  • 04 STI Struts
  • 04 STI Springs
Interior/Electronics:
  • Alpine Single DIN HU
Exterior:
  • Removed Rear Wing
Old 07-30-2013, 03:08 PM   #132
2011mwgwrx
Member#: 300784
2011 WRX Limited
Awesome update! Glad its back up and running! I'm getting my e85 tune this week as well, but have a full tank of 93 I need to burn first.
2011mwgwrx is offline   Reply With Quote
Old 07-30-2013, 03:43 PM   #133
mbrodie1995
Member#: 363791
nice car mine looks just like it
mbrodie1995 is offline   Reply With Quote
Old 07-30-2013, 03:45 PM   #134
Studmike02
Member#: 220095
Rear wing removal for the sleeper look? You going to get a RS hood soon? Haha.
Studmike02 is offline   Reply With Quote
Old 07-30-2013, 03:51 PM   #135
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think I only have about a 1/4 tank left but I'm not sure how long it will take me to get through it since I don't daily drive the car.
Thanks. I was amazed when I saw the 1995 in your username. I might be getting old...
Yep, rear wing is gone, but I have nothing to fill the holes right now. No RS hood since they are steel and the WRX hoods of this era are aluminum. Probably either a scoop delete or a CF hood once I got FMIC.
Old 07-30-2013, 07:32 PM   #136
paulpat
Member#: 237145
02 WRX
12 FXT
I have been off nasioc for some time to miss this! nice bugeye!
For the trunk, ebay some electrical tape and tape both sides to prevent most water from getting in. It held me for a year. I'm still waiting to paint mine. I'm not sure about your color, I had an easy time with white.
What happened to the old car? It was my basis for telling my friend to get the newer STI hatch and not making a WRX to STI swap.
-paul
paulpat is offline   Reply With Quote
Old 07-30-2013, 09:42 PM   #137
blk05wrx
Member#: 180559
2016 WRX STi Limited
Subscribed! I enjoyed your old build, but I'm more excited to see what you can do with a 2.0 for selfish reasons.
You've now done more mods in a week than I've done over the last 8 years.
Is the tune good enough for a dyno graph? It would be interesting to see the td04 and vf39 comparison.
blk05wrx is offline   Reply With Quote
Old 07-31-2013, 09:34 AM   #138
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-paul
I just have painter's tape on there now. Electrical tape would probably be better, but I don't really want to ruin the paint if I don't have to. I was thinking of getting some color matched vinyl to stick on the holes.
Thanks! This is probably about as far as it will go with the 2.0L. Right now I am tuned on pump gas, but it will be switched to E85 soon. The next phase of the build will be switching to a 2.5L.
I will try to get a Virtual Dyno plot to compare the TD04 to the VF39. I agree that it would be interesting to see on paper. The VF39 spools totally different on the 2.0L vs the 2.5L. Hopefully I can do one on pump gas before I switch to E.
Old 07-31-2013, 06:47 PM   #139
SubieLuvin
Member#: 248202
2013 WRX Sedan
I was hoping you would pick up one of these. Can't wait to see what you turn this into
You can find vinyl stickers on the cheap around to fill the holes. Finding a wingless deck lid for these is not easy these days.
If you take a look at my threads I've started I have my build thread from my old bugeye that will give you an idea of what a plot looks like with bolt ons and E. edit actually mine was a vf22 so it spools a good bit slower.
SubieLuvin is offline   Reply With Quote
Old 08-02-2013, 09:42 AM   #140
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'm still on the lookout for a wingless trunk, but I haven't found any yet. I will probably do vinyl if I don't figure anything else out soon. The tape I have on now doesn't look very good!
Old 08-02-2013, 09:43 AM   #141
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here is an updated Virtual Dyno plot:
This a very conservative, 18psi, pump gas tune. It was just enough to get me driving so I could burn up the rest of the pump gas in the tank and switch to E85. 50-100mph time and Virtual Dyno power numbers both show a nice improvement over the stock TD04 setup. The car is much more fun to drive now!
50-100mph is 9.7 seconds
262WHP on Virtual Dyno (Dynojet)
Engine:
  • GrimmSpeed Uppipe
  • GrimmSpeed MBC
  • 05 STI Fuel Pump Hanger
Old 08-02-2013, 09:58 AM   #142
Bnuts01
Member#: 293328
Push in plastic rivet with a foam or rtv washer should plug the decklid for the time being.
Bnuts01 is offline   Reply With Quote
Old 08-02-2013, 11:01 AM   #143
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I could do that too, but it probably wouldn't look any better than vinyl (or worse). And there is one spot that has a fairly large area of surface rust so a plug wouldn't cover it all. The tape seems to be doing the job so far.
Old 08-02-2013, 11:05 AM   #144
erik11876
Member#: 275888
2011 WRX Limited
Engine:
[*]Stock 2.0L with 185k Miles
[*]GrimmSpeed CrossPipe[*]GrimmSpeed Uppipe[*]GrimmSpeed Downpipe[*]Perrin CatBack Exhaust[*]IHI VF39 (STI) Turbo[*]GrimmSpeed Gaskets[*]GrimmSpeed TMIC w/Gold Tape[*]GrimmSpeed TMIC Splitter[*]GrimmSpeed Y-Pipe Kit[*]GrimmSpeed MBC[*]05 STI Fuel Pump Hanger[*]Walbro 255 Fuel Pump[*]Modded 2011 WRX Injectors (1000cc)
Vast improvement already. What was your stage 2 50-100 in your GR?
erik11876 is offline   Reply With Quote
Old 08-02-2013, 11:09 AM   #145
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Unfortunately I didn't do a 50-100 in my 2011 WRX until I was already on E85. At that point it did 7.5 sec. It will be interesting to see what this car will do with the 2.0L, VF39, and E85. I think it should still be a little slower than the 2011 was with similar mods (due to the 2.0L vs. 2.5L) but the weight difference may help to make up some of that.
Old 08-02-2013, 11:16 AM   #146
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Nice! Love me some extra powar!
96accord is offline   Reply With Quote
Old 08-02-2013, 04:03 PM   #147
RedlineFl
Member#: 99842
well not to shabby for a weeks work. Can't wait to see what it does on E!
RedlineFl is offline   Reply With Quote
Old 08-02-2013, 05:30 PM   #148
|Rev|
Member#: 100651
2010 STI
I like what you have done so far. That car is exactly what my first Subaru was. Good luck! I would say keep it clean but you will have no issues there.
|Rev| is offline   Reply With Quote
Old 08-03-2013, 04:41 PM   #149
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
External Changes:
  • 2012 Forester 17" Wheels
  • OEM Hood Scoop
  • Removed Rear Wing
  • 04 STI Springs and Struts
Old 08-03-2013, 04:43 PM   #150
renosubie
Member#: 218671
09 WRX
Looks good! So much progress already too
renosubie is offline   Reply With Quote
