Welcome to the North American Subaru Impreza Owners Club Thursday April 26, 2018
Old 08-12-2013, 11:34 AM   #1401
HawkI06
Member#: 362011
2006 Wrx sti
Would the same 2g of a base color and 2g off the actually color be good for koi orange, or navy blue or would I need more
HawkI06 is offline   Reply With Quote
Old 08-12-2013, 11:36 AM   #1402
cheeseyfella
Member#: 286941
I would say so, koi orange and the dark colors have good coverage, so you are really only needing to get a solid base of dip down and then build up the layers.
cheeseyfella is offline   Reply With Quote
Old 08-12-2013, 02:52 PM   #1403
Brock Samson
Member#: 207553
17 Offroad Minivan
Originally Posted by cheeseyfella View Post
4g is a good amount, you don't need 3 green though if you wanna save a little bit of money you can go with 2 green and 2 base. I always recommend gun metal grey as a base instead of any other color as it has very little effect on the top color. But the lime green is supposed to have great coverage so the base color won't matter, just don't use white as a base as the coverage is not great.
If you were buying from me i would recommend 2g grey and 2g lime green to you as a cost saver.
Yeah since my last post I had viewed the lime green on youtube from DYC and the white as well. I think 2 & 2 or 2 & 3 should work well with the grey and green, respectively.
Thanks for the info!
Brock Samson is offline   Reply With Quote
Old 08-12-2013, 05:12 PM   #1404
cheeseyfella
Member#: 286941
depending on what you are dipping 4g will be plenty. my 06 needed just over 3.5g
Old 08-12-2013, 07:16 PM   #1405
johnblahuta88
Member#: 221614
So I dont know how many people out there have a 04-07 sti but the bbs wheels are a little bit of a pain to pull the plastic bag out of the rims with the rims still on the car because od the giant brembo brakes. I found the easiest way to get around this was to put the bags on through the outside the once your done just reach around and pull the bags out. I turned my front wheels all the way and it was easier to pull them out. I only am saying this becuase the first time I pulled the bag out it ripped up some of the rim based on the spokes being so close. Hope this helps.
johnblahuta88 is offline   Reply With Quote
Old 08-12-2013, 09:21 PM   #1406
jasons73
Member#: 347544
2009 WRX
Decided to do my wheels over the weekend. I went with the vintage gold. I put on about 5 coats to each wheel.
jasons73 is offline   Reply With Quote
Old 08-12-2013, 09:31 PM   #1407
dsn112
Member#: 332561
2015 GTI Autobahn
Anyone compare the new anthracite color to the oem 11-13 color?
Old 08-12-2013, 11:09 PM   #1408
aznboi0204
Member#: 266514
2011 OBP STi Sedan
aznboi0204 is offline   Reply With Quote
Old 08-13-2013, 01:37 AM   #1409
tenaciousZ
Member#: 342279
2012 Impreza Sport
Looks niiice! Did u do a base coat of any kind or just straight to dippin em vintage gold?
tenaciousZ is offline   Reply With Quote
Old 08-13-2013, 05:31 AM   #1410
jasons73
Member#: 347544
2009 WRX
Thanks. I dipped right over the rim. No base coat. I think if I did a base coat the gold would have been much brighter. But I like the way it looks as they are.
Old 08-13-2013, 07:09 AM   #1411
cheeseyfella
Member#: 286941
The gold looks good.
The new True metallic's don't need a base, and the coverage is really good so the base color doesn't have an effect on the top coats.
Old 08-13-2013, 10:37 AM   #1412
enmvaldez
Member#: 315326
2011 Impreza wrx
obp
Originally Posted by aznboi0204 View Post
[IMG][/IMG]
Is that pearlizer how many coats?
enmvaldez is offline   Reply With Quote
Old 08-13-2013, 02:07 PM   #1413
11wrx_dude
Member#: 311747
2011 wrx
white
did nothing come up with the clay bar?
Nope not at all. And I've come to the verdict that its not going to come off. Currently getting paint job estimates ..
11wrx_dude is offline   Reply With Quote
Old 08-13-2013, 02:56 PM   #1414
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Have you tried any kind of compounds? Try a fine finish compound.
flippymcbean is offline   Reply With Quote
Old 08-13-2013, 03:31 PM   #1415
cheeseyfella
Member#: 286941
It has to be sitting on top of the clear coat so it must removable. Do u have any pics?
Old 08-13-2013, 03:33 PM   #1416
Flawlers
Member#: 340608
2004 STI
Platinum Silver
Original
White with audi mask
Lime green with pearlizer ( decided why not for ****s and gigs )
Flawlers is offline   Reply With Quote
Old 08-13-2013, 03:43 PM   #1417
aznboi0204
Member#: 266514
2011 OBP STi Sedan
Yeah. I used 2 matte white coats then two more coats of white mixed with pearlizer.
Old 08-13-2013, 03:57 PM   #1418
11wrx_dude
Member#: 311747
2011 wrx
white
Yes I've tried rubbing compound, buffing, even some finishing sanding on a small spot. It's almost as if it has soaked in to the clear coat.
Old 08-13-2013, 04:08 PM   #1419
11wrx_dude
Member#: 311747
2011 wrx
white
You cant tell in the pictures, but Other then the spots where it's clearly noticeable, the whole car has a slight red tint to it. Just talked to DYC and they told me to try goof off. So ill be giving that a shot later today.
Old 08-13-2013, 04:13 PM   #1420
jzehren11
Member#: 357281
2004 WRX Wagon
damn thats ****ty! hopefully it works!
jzehren11 is offline   Reply With Quote
Old 08-13-2013, 04:29 PM   #1421
cheeseyfella
Member#: 286941
I was going to say goof off, and also try
no idea how but these are amazing
Make sure they are soaking wet, have a bucket of water with you, otherwise they break apart.
Tip for people cleaning dipped cars, wheels etc, these are great for stubborn stains too and safe on dip
Old 08-13-2013, 04:31 PM   #1422
HawkI06
Member#: 362011
2006 Wrx sti
Yeah those mister clean major erasers are awesome. Use then at work to get stains out of tables
Old 08-13-2013, 04:33 PM   #1423
jzehren11
Member#: 357281
2004 WRX Wagon
I would not use a magic eraser on paint... those are like really fine sandpaper... and will **** the **** out of his clear coat
Old 08-13-2013, 04:33 PM   #1424
cheeseyfella
Member#: 286941
just used to get bird crap stains and dead bugs off my wifes car, the power washer and soap and sponge did nothing, the eraser pads removed everything with a simple wipe. Love them!!!
Old 08-13-2013, 04:34 PM   #1425
cheeseyfella
Member#: 286941
did nothing to my wifes car (undipped car) they have to be soaking wet though. it is just a sponge, feels like a sponge not sure how it would damage the clear.
