Welcome to the North American Subaru Impreza Owners Club Thursday March 23, 2017
Old 09-08-2013, 10:44 PM   #1726
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Timing chains done!
I think tomorrow I just might get the front cover on, but for now the engine is all wrapped up in plastic bags again.
Old 09-09-2013, 09:52 PM   #1727
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
If any of you EZ30D guys need a chassis side engine harness with ecu and tcu, send me a PM. No longer need mine since I decided it would be easier to swap a 5-mt into an Outback H6 rather than swapping a motor into an Impreza. That and I got the Outback for free!
slow03 is offline   Reply With Quote
Old 09-10-2013, 08:02 AM   #1728
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
800ft of Ultra Grey RTV and 59 bolts later...
I think tonight I'll continue working on painting various brackets and hard lines. You can just see in the 2nd picture the breather hard line that connects the heads across the back of the engine - I'm doing everything flat black like that. Nothing special, just Rustoleum "Painter's Touch Ultra Cover 2X" flat black - I have to say, I'm certainly no expert painter, but this Ultra Cover stuff lays on pretty nice. Tonight I want to do the fuel lines and the coolant crossovers.
My one aesthetic quandary at this point is that I had the accessory brackets powdercoated "aluminum" a while back. So, they're nice and shiny silver, while the block and heads are kind of grungy silver (despite efforts to clean them up, it's just too much work to get into all the nooks and crannies), and the intake manifold is yet another shade of aluminum. So, I'm not really sure what I want to do with those accessory brackets. I guess I should bolt them on just to see how they look.
Old 09-12-2013, 12:38 AM   #1729
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
In amongst painting various brackets and hard lines I took care of this:
Not that anyone will ever see it.
Old 09-12-2013, 12:42 AM   #1730
vicious_fishes
Member#: 158864
2003 SOHC destroker
mine just fired today
harness is just being stripped of all unnecessary bull**** now, dash will go back in on sunday.
headers are ordered, so install my brakes while they're on their way, once they arrive i bolt them up, fab up a 2.5 merge and weld it to the cat, & off to the engineer it goes!
Old 09-15-2013, 07:05 AM   #1731
vicious_fishes
Member#: 158864
2003 SOHC destroker
toasted my ECU for some reason lads. popped one of the transistors or something. tech tried soldering on one from my ej25 ecu but no luck. anyone got the link to all the various ecu part numbers? i've lost it and it's bookmarked on my other pc that has died.
Old 09-15-2013, 12:18 PM   #1732
RedMonkey999
Member#: 191476
2002 2.5RS
Were you swapping the EZ30D or R? I have an ECU from a RHD 6MT EZ30R that I'm leaning towards selling. The part number is 22611AK170 if you're interested.
RedMonkey999 is offline   Reply With Quote
Old 09-15-2013, 09:18 PM   #1733
vicious_fishes
Member#: 158864
2003 SOHC destroker
neg. EZ30D.
local wrecker doesn't have any EZ30D ones either. i can order one from ebay but, yeah. bit of a wait/no guarantees with that.
wonder if an ez30r ecu would work...
Old 09-15-2013, 09:21 PM   #1734
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
I have one available, if you want to PM me an offer.
Old 09-15-2013, 11:22 PM   #1735
vicious_fishes
Member#: 158864
2003 SOHC destroker
got one on the way from an interstate wreckers (being posted) so if it doesn't work, will do mate.
they're all $100-150 mark at wreckers/on ebay, for what it's worth.
Old 09-16-2013, 02:49 AM   #1736
RedMonkey999
Member#: 191476
2002 2.5RS
Glad you found one, I'm almost 100% certain the EZ30R ECU would've been worthless to you.
Old 09-16-2013, 05:35 AM   #1737
vicious_fishes
Member#: 158864
2003 SOHC destroker
mm there's two others on ebay but i'm buying the cheapest one first and then working my way up from there
wiring tech tells me it's fairly common for them for some reason to just be uncooperative with a transplant. we drove the car out of the shed, onto the street, started it up a couple times etc etc. and then it just randomly shet itself.
cracked it open to find a fried transistor. took it off, soldered one from the ej25 ecu on but no luck. unfortunately don't know what caused it either, so can't just put an X volt/amp fuse in as a safeguard. might get him to install one anyways. stick the multimeter on the input, find out the volts/amps/whatever and then put a corresponding fuse in.
Old 09-17-2013, 03:20 PM   #1738
ADAM (type r)
Member#: 280968
EG33 HELP !!!!!
Planning to build a 500bhp EG33 but need some good advice on stock cylinder heads and valve train.
Has anyone used the stock valve train and to what limits, like bhp levels and boost.
The plan I have is to forge the short motor port the standard heads and run 2 TD04 or TD05 turbo's, all advice welcome and sorry if this has already been covered but cant find any answers anywhere.
Thanks Adam
ADAM (type r) is offline   Reply With Quote
Old 09-17-2013, 09:21 PM   #1739
shark_22
Member#: 310794
2000 impreza EZ30R
Originally Posted by ADAM (type r) View Post
EG33 HELP !!!!!
Thanks Adam
go check on www.subaru-svx.net your gonna find what you want on this setup
shark_22 is offline   Reply With Quote
Old 09-18-2013, 06:55 PM   #1740
ADAM (type r)
Member#: 280968
Still lost and need info on cylinder head valve train !
Old 09-18-2013, 11:12 PM   #1741
vicious_fishes
Member#: 158864
2003 SOHC destroker
you can make 300kw @ the wheels without any mods, i know that much.
Old 09-19-2013, 10:40 AM   #1742
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
After getting the timing chains done and the covers on, I've been somewhat slacking. Had to order a number of parts (vacuum and coolant hoses, simple stuff like that), and sent my Fidanza flywheel to Fidanza to get a new ring gear installed (starter motor hasn't been engaging right, and has worn the existing ring gear unevenly). So, until I get that back - should be early next week - I can't put the engine in the car.
I suppose with that in mind I should be working on other aspects (like a fuel pump replacement, dash removal, etc), but like I said, I've been slacking.
Old 09-19-2013, 11:14 AM   #1743
ADAM (type r)
Member#: 280968
Thanks for the reply, how do you know this and if its true then it has answered my question I think as 300 KW = about 400 bhp at the wheels so not for off 500.bhp at the flywheel
Old 09-19-2013, 12:24 PM   #1744
vicious_fishes
Member#: 158864
2003 SOHC destroker
couple of other aussies have done h6 swaps and eventually boosted them. iirc perrin made about 400whp before they cracked theirs open too.
300 @ wheels is the equivalent of 200 @ the wheels with an ej remember. i.e 50kw/cylinder. quite a low figure really. hence the reliability being so much greater with these engines.
Old 09-19-2013, 01:19 PM   #1745
ADAM (type r)
Member#: 280968
But was that with stock valves - lifters - cams !
Old 09-21-2013, 02:10 AM   #1746
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'm fairly confident it was, yes.
basically anything bigger than a gt30 and you need to do engine mods.
on another note: anyone know if there are any differences on a JDM wiring diagram? i fried my ecu, plugged in a couple of aussie ones but they just won't quite play nice.
Old 09-21-2013, 04:15 PM   #1747
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
The Perrin car built by PDX was an EZ30R NOT and EG33. It put down 416whp on stock short block with drop in pistons and upgraded valve train. I think that was at 14lbs of boost off the GT30. It's all on Perrin's sight. I might just get bored and reread all that. OR I could continue reading wiring diagrams now that I've finally sorted out how to read them right. WAY easer than the other times I didn't take the time to decode.
Seraphinwolf is offline   Reply With Quote
Old 09-21-2013, 04:19 PM   #1748
Seraphinwolf
Member#: 150922
97 OBS EZ30R
As for power on the EG33. Stock EJ turbo rods, drop in pistons or over bore(remember these are EJ22's x 1.5), port the heads, go over ALL the oiling, and probably one of the biggest aids is converting the heads from hydronic to solid buckets. Keep an eye on the compression of the pistons you decide to get. Personally I'd run 9:1. In my EZ I'll run 8.5:1 till some point that I break something then drop the money on non-off the shelf 9:1.
Old 09-23-2013, 01:08 PM   #1749
vicious_fishes
Member#: 158864
2003 SOHC destroker
well my OBX headers are here. ecu's still roasted though. if tech can't fix it tomorrow it's going off to another pro to try & fix it. still haven't diagnosed the issue that roasted it though.
Old 09-27-2013, 08:00 AM   #1750
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Got my Fidanza flywheel back yesterday, so this weekend I should be able to get the engine in the car. I need to get it off the stand, install the rear main seal, then install the flywheel and clutch, and it'll be ready to go in.
Vag-Com cable resource thread cooleys04 Open Source Reflashes 280 11-13-2016 04:24 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
