Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 10-09-2013, 07:09 PM   #101
AWD Freak
Member#: 262593
Originally Posted by candyredfish View Post
Hoffman i need your expertiseeee, running lean at WOT! haha
Sounds like we still need a fix it meet.
AWD Freak is offline   Reply With Quote
Old 10-09-2013, 07:12 PM   #102
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
I just have no clue what it might be anymore... Cobb ots shoots for 10.8 at WOT im running high 11's low 12's
candyredfish is offline   Reply With Quote
Old 10-09-2013, 07:19 PM   #103
AWD Freak
Member#: 262593
I was just looking online and it said pull the sensor, clean it out with compressed air and recalibrate. Is it hard to pull out?
Old 10-09-2013, 07:20 PM   #104
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
Already cleaned the MAF
Old 10-09-2013, 07:28 PM   #105
AWD Freak
Member#: 262593
Ok. This will probably need hoff to chime in.
Old 10-09-2013, 07:31 PM   #106
hoffmanEstates
Member#: 122043
04 wagonier
psm
Have this issue before you repaired hoses?
hoffmanEstates is offline   Reply With Quote
Old 10-09-2013, 07:32 PM   #107
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
Seemed to have been running lean ever since I installed my wideband, so it was probably running this way even beforehand
Old 10-09-2013, 07:41 PM   #108
hoffmanEstates
Member#: 122043
04 wagonier
psm
You have an intake system? What are you at idling?
Turbo intake torn? Any.loose clamps or rotten hoses. Hoses/lines popped off?
Old 10-09-2013, 07:44 PM   #109
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
Stock intake system minus the snorkle, idle is around low 15's (jumps around a bit) and turbo intake is a perrin silicon intake and seems like hoses connecting are fine but thats all just a guess (the hoses connecting part)
Old 10-09-2013, 07:55 PM   #110
hoffmanEstates
Member#: 122043
04 wagonier
psm
OK. I am running same afr's as you are. I run at 15.1-15.2 which is little lean and.wot is 10-12
Old 10-09-2013, 07:56 PM   #111
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
12 is okay even for a cobb ots map?
Old 10-09-2013, 07:57 PM   #112
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
When target afr is around 10.8 i guess
Old 10-09-2013, 08:03 PM   #113
hoffmanEstates
Member#: 122043
04 wagonier
psm
that's the thing I know 0 about.Cobb I am open sourced. But regular maintenance is key o2 sensors.are cheap spark plugs done when? Fuel.filter?
Old 10-09-2013, 08:06 PM   #114
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
Fuel filter and plugs have around 1k on them... haha
Old 10-09-2013, 08:48 PM   #115
hoffmanEstates
Member#: 122043
04 wagonier
psm
I would say nothing's wrong then, honestly I have no idea. Call up Cobb and ask but I'm guessing 10.8 is target your 11-12 not that horribly lean. I run leaner as that's how tuner tuned me. I had leaks and such and he tuned that. So that now the problems are fixed I'm running better. Just double check the connections if your horribly lean 15.5+ should be acceptable. Remember every car runs different. Ill bring my obd scanner and I believe it has o2 out put maybe we could scan and see if anything sticks out.
Old 10-09-2013, 08:50 PM   #116
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
Works for me! Appreciate the help! Ps: anyone still want to meet? steak and shake or something?
Old 10-09-2013, 08:51 PM   #117
hoffmanEstates
Member#: 122043
04 wagonier
psm
Steak and shake Friday?
Old 10-09-2013, 08:53 PM   #118
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
I dont think friday will work for me :/ i was thinking like.... 7:30 tonight or so hahaha
Old 10-09-2013, 08:54 PM   #119
hoffmanEstates
Member#: 122043
04 wagonier
psm
You hitting target boost or w.e Cobb says you should be hitting. Boost/vac gauge reading -20"
Old 10-09-2013, 08:55 PM   #120
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
target 16, im hitting atleast 15 maybe a lil more
Old 10-09-2013, 08:57 PM   #121
hoffmanEstates
Member#: 122043
04 wagonier
psm
I know your relying on Cobb afr. But thought about a stand alone gauge? Like aem,defi,innovative
Old 10-09-2013, 08:57 PM   #122
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
I am running an AEM haha
Old 10-09-2013, 10:14 PM   #123
AWD Freak
Member#: 262593
So steak and shake Friday? Or other place
Old 10-09-2013, 10:52 PM   #124
hoffmanEstates
Member#: 122043
04 wagonier
psm
Location of sensor how far down stream
Old 10-09-2013, 10:56 PM   #125
candyredfish
Member#: 323959
02 WRX
Sedona Red Pearl
12 inches or so behind the turbo
