Welcome to the North American Subaru Impreza Owners Club Friday June 23, 2017
Old 10-21-2013, 08:37 PM   #2876
Alan777
Member#: 334223
2013 Impreza Sort
wow. H9 is definitely a reccomended mod for those running stock bulbs. A lot more light, even with my regular sylvania's I bought from autozone. Can't wait to throw in the 35w yellow fogs.
Alan777 is offline   Reply With Quote
Old 10-21-2013, 09:08 PM   #2877
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Yup, I agree that the H9 mod is definitely well worth it. I was also going to get yellow H11s for my fogs, but ended up going with yellow overlays. Not real impressed with the color of the light coming through the overlays so I may try yellow bulbs instead.
Old 10-21-2013, 09:10 PM   #2878
Alan777
Member#: 334223
2013 Impreza Sort
I just posted in the outback fog light upgrade thread. It *appears* that you can upgrade to the metal 55w outback fogs for around $100 + shipping. I may not even bother trying to get 35w bulbs for the stock fogs, and I may just upgrade instead to the outback setup.
Old 10-21-2013, 09:11 PM   #2879
jr0bb5
Member#: 315353
5MT OBP/DGM
Check the other thread.
Old 10-22-2013, 02:02 AM   #2880
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I don't have any issues with my Perrin antenna..? I don't really use the radio, but when I do, I have never had an issue..
Old 10-22-2013, 10:50 AM   #2881
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Are anyone else's brakes ****ing loud when they're very cold? First couple of stops after a night near freezing it sounds like I have no brake pads left.
goregasm is offline   Reply With Quote
Old 10-22-2013, 10:59 AM   #2882
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Have you checked to confirm that your brake pads aren't worn out?
Old 10-22-2013, 11:33 AM   #2883
Angelus911
Member#: 89967
2012 Impreza Sport
A lot of the time the sound is normal just rubbing off residue/moisture from the rotors...but yes, wouldn't hurt to get the pads checked out. I would be more concerned if it sounded like that all the time - in the am leads me to believe its normal
Old 10-22-2013, 01:06 PM   #2884
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Supposedly at the last service they were fine. If they wore out in 17,000 miles I'd be concerned. That's Bentley brake wear.
Old 10-22-2013, 01:16 PM   #2885
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I would agree, as long as you aren't an aggressive driver.
Here's something you can eyeball in about 10 seconds: Check your brake fluid level. If it has dropped far below the MAX line, then your pads and/or rotors are worn. If the level is close to MAX, then your pads/rotors are fine.
NOTE: This assumes you (or anybody else) have not "topped off" your brake fluid level, which should generally be avoided between brake services.
Old 10-22-2013, 05:58 PM   #2886
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
I've looked at the brake fluid (and other crap) about weekly since I've got the car. As far as I know it looks about the same.
Old 10-23-2013, 05:12 PM   #2887
shredjesse
Member#: 369265
2013 Impreza 2.0L
Pearl White
Originally Posted by averagewhiteboy View Post
http://www.carusomotorsports.com/?page_id=307
That link may work. If not, just Google search "Crosstrek skid plate".
This skid plate would be a nice feature, especially if I'm going to lower this puppy a little bit up front (not much, just a bit). It's almost unacceptably lazy though for this product to not have a place for the oil drain.
shredjesse is offline   Reply With Quote
Old 10-23-2013, 06:25 PM   #2888
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yeah, the skid plate I mounted on my VW TDI also did not have an access hole for the oil drain plug. I was about to buy an oil extractor so that I could do oil changes on that car topside (which is how VW dealerships do oil changes), but then the car crapped out on me, so I replaced it with the Impreza.
Old 10-24-2013, 03:06 PM   #2889
shredjesse
Member#: 369265
2013 Impreza 2.0L
Pearl White
A good metal hole saw really aught to solve the problem anyways.... although it will expose your oil pan a bit...
Old 10-25-2013, 12:05 AM   #2890
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Well, I have been running a 22mm rear sway bar for a couple months now with stock end links and have had no problems. However, I guess I felt the need to buy my car a present so I just ordered some Kartboy end links lol.
kinger37 is offline   Reply With Quote
Old 10-25-2013, 06:23 AM   #2891
TRSAndrew
Member#: 360634
2012 FJ Cruiser
Re-wrapped a new OEM leather knob in Alcantara and matching orange stitching to the other Alcantara stuff
TRSAndrew is offline   Reply With Quote
Old 10-25-2013, 07:07 AM   #2892
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
That looks really nice.
ronjr8102 is offline   Reply With Quote
Old 10-25-2013, 07:17 AM   #2893
TRSAndrew
Member#: 360634
2012 FJ Cruiser
Between that and the steering wheel, I think the exorbitant cost is worth the every day feel of using them.
Old 10-25-2013, 05:51 PM   #2894
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Can anyone point me in the right direction for a roof rack setup? Been seeing a lot of nice Thule and Yakima ones on other cars on the road. But Subaru also has nice ones too..
I have never looked into racks before, so I have no idea where to even start. Some type of multi-purpose rack would be fine, but bars, not a "basket". Preferably black to match the existing Sport side rails. Attachments used would be POSSIBLY bike and snowboards.
If anyone could shine any light on this, that'd be helpful. Do I need to get the Subaru aero-bars and add from there, or are there any options to simply add a whole assembly and eliminate the need for the Subaru cross bars?
Old 10-25-2013, 07:02 PM   #2895
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I use the Malone cross bar setup with lockable clamps, and a Thule fairing. I did add the Malone kayak setup as well. I love it. Great for the kayak, hauling tubing and even a little giant ladder sometimes.
G2Spfld is offline   Reply With Quote
Old 10-25-2013, 07:51 PM   #2896
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Excellent! Any links or pics by chance?
Old 10-26-2013, 09:06 AM   #2897
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
I have the Yakima with the round bars. Its probably the cheapest/most versatile. But its really noisy. A fairing will get rid of the "wump wump wump," but there is still a ton of wind noise. Also, I take about a 3 mpg hit when its on. Between those two things, its not something I leave on the car when I'm not using it. But it only takes a few minutes to attach.
I would be interested in hearing how well the aero cross bars do against wind noise and mpg.
I believe the current Outback has built in cross bars that fold out from the rails. That would be pretty awesome.
foghelmut is offline   Reply With Quote
Old 10-26-2013, 10:07 AM   #2898
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
http://forums.nasioc.com/forums/show....php?t=2313537
Old 10-26-2013, 02:48 PM   #2899
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Didn't see that thread.
Thanks.
Old 10-27-2013, 07:19 AM   #2900
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
Cusco # 965 017 F
xv_hybrid_toe_****_front by Dijm8, on Flickr
Dijm8 is offline   Reply With Quote
