Welcome to the North American Subaru Impreza Owners Club Friday November 17, 2017
Old 11-08-2013, 10:29 AM   #1
jmcskis
Member#: 373118
2013 Subaru WRX
Gray
Default 2013 Oil Change Tips
I'm looking for some tips to help make my oil changes easier and cleaner on my 2013 WRX.
The biggest issue I've had after a couple of oil changes is that the oil filter is buried up behind an exhaust pipe (I'm assuming it's my turbo uppipe but I have no idea as I'm new to turbos) and when I take the old filter off I get oil on said pipe. As a result, I get a burning oil smell for the first 20 miles or so until it's burned off and if I don't let it run long enough to get it all burnt off it'll smoke out of the hood scoop. Before all the oil has burnt off the pipe, it makes me really nervous that I've messed something up.
Any tips on how to keep this from happening?
jmcskis is offline   Reply With Quote
Old 11-08-2013, 11:12 AM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Wrap the pipe in aluminum foil or something to keep the oil off of it.
Fumoto Valve
Jiffy Lube.
But seriously, if you can't do an oil change without freaking out, maybe working on your car is not for you.
Old 11-08-2013, 11:15 AM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Hammer a nail in the middle of the filter, let drain. Loosen with tool to where it is hand unscrewable, then use a plastic grocery bag to spin off and contain 100% of mess.
Old 11-08-2013, 12:02 PM   #4
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Everybody has to start somewhere. You weren't a bit nervous the first couple oil changes you ever did?
I may have to start doing some of unabombers idea. I never get any on the exhaust or heat shields, but I do get a fair amount on my hands..
Breezio is offline   Reply With Quote
Old 11-08-2013, 12:17 PM   #5
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
No doubt. Everyone is nervous after the first one or two. But the OP realizes what the problem is (oil falling on the pipe during the change) and that after "20 miles or so it's fine". After the first few times, you should realize that it's the same thing that's going on and not freak out about it. Find a way to fix it? Sure, I offered up one, Unabomber (in a bizarre act of kindness) offered up another.
Wolverine's claws hurt when he shnicks them out. This is the same as the smoke coming out and the OP worrying about it.
Wolverine continues to do so because he knows what it is and the pain (smoke) goes away.
Can you imagine a world in which Wolverine is afraid to shnick?
OP, take this as a compliment. You need to be Wolverine.
Old 11-08-2013, 12:19 PM   #6
FrozenIce
Member#: 349378
1993 Impreza WRX Sti
Get some brake clean an spray off the area once the new filter is tightened on. Don't forget to check for double gasket.
FrozenIce is offline   Reply With Quote
Old 11-08-2013, 12:20 PM   #7
mejifair
Member#: 11356
2012 WRX STi Hatch
This is AWESOME. Best advice I have heard in a long time. I am changing my oil this weekend, and will definitely do it this way.
Thank you Unabomber!!!!
mejifair is offline   Reply With Quote
Old 11-08-2013, 12:43 PM   #8
[email protected]
Member#: 301037
2004 Forester XT
Don't forget a new crush washer on the drain plug.
art@grimmspeed is offline   Reply With Quote
Old 11-08-2013, 01:08 PM   #9
Beau M
Member#: 345079
13 Wrx sedan
Take it to the dealership you bought it from to get the change so they have records and you have one less thing to worry about if a warranty issue comes up? Thats worth the $30 difference to me.
Beau M is offline   Reply With Quote
Old 11-08-2013, 01:34 PM   #10
rwfloberg
Member#: 327538
2012 WRX (307/344)
Never did like the upside down oil filter. Stupid.
rwfloberg is offline   Reply With Quote
Old 11-08-2013, 02:56 PM   #11
jmcskis
Member#: 373118
2013 Subaru WRX
Gray
Thanks for the advice guys. I would've come up with a solution, just wanted to see what methods others were using.
Old 11-08-2013, 03:30 PM   #12
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Yeah, me neither, so I just stand on my head while I'm changing my oil and filter.
And Wolverine. lol. Priceless.
Gallo2011 is offline   Reply With Quote
Old 11-08-2013, 11:49 PM   #13
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
fumoto oil drain valve. i also cover my wrapped headers in foil to prevent oil on the wrap.
