Welcome to the North American Subaru Impreza Owners Club Friday February 21, 2020
Old 11-08-2013, 12:59 PM   #376
sexyyrex
Member#: 128022
2015 Mustang GT
It does look pretty similar! CXR550 is rated at 52lb/min vs. 56lb/min for the GTX3071 compressor. I didn't see any wheel dimensions listed for the CXR turbo's, so I'm not too sure how the dimensions compare. I think this turbo could do 400WHP on pump. Hopefully a bit more on E85.
Guess that would depend on the dyno. Car made 401 on e85 with just injectors, fuel pump and TBE, stock inlet, stock top mount, stock intake, stock header/up pipe on a dyno jet, all on 22 psi.
I think it did around 440whp on 24 psi, fmic, intake, TBE, 2.4" inlet on the same dyno.
Car did 380whp with full bolt ons, FP Red, 3" inlet, fmic, header, and conserative tune on 22 psi on 93 on a mustang, and 471whp on 26 psi on e85, again, mustang dyno.
Regardless, she should make good power and be quick for such a little car.
sexyyrex is offline   Reply With Quote
Old 11-08-2013, 01:10 PM   #377
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Are these numbers Dynojet or Mustang? You mention both.
My 2011 WRX with 20G XTR (47lb/min) made 462WHP/492WTQ on the local Dynojet. That was on E85 at 28psi peak tapering to 25psi. Compared to this car the mods were pretty similar. The 2011 did have an EWG and FMIC, but it was still on the stock catback and stock cams.
Realistically, I hope this new turbo would do at least that much power if the boost is cranked to similar levels. The internal wastegate and TMIC may limit top end a bit, but I still think it should do pretty well. The slightly more aggressive cams should help.
Old 11-08-2013, 02:22 PM   #378
CJ12
Member#: 202539
02 WRX MBP 6SPD
94 LandCruiser/84 NH 650
Yep. Sure am.
Oh?? When do you plan to do so?
Probably already a line of people waiting haha
CJ12 is offline   Reply With Quote
Old 11-08-2013, 02:27 PM   #379
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Sold it pretty much instantly after posting that. Lol.
Old 11-08-2013, 02:29 PM   #380
CJ12
Member#: 202539
02 WRX MBP 6SPD
Damn it, figured as much. They're still fairly easy to come by though. Might as well just put the money towards next year's power goals.
Old 11-08-2013, 04:23 PM   #381
sexyyrex
Member#: 128022
2015 Mustang GT
Are these numbers Dynojet or Mustang? You mention both. My 2011 WRX with 20G XTR (47lb/min) made 462WHP/492WTQ on the local Dynojet. That was on E85 at 28psi peak tapering to 25psi. Compared to this car the mods were pretty similar. The 2011 did have an EWG and FMIC, but it was still on the stock catback and stock cams. Realistically, I hope this new turbo would do at least that much power if the boost is cranked to similar levels. The internal wastegate and TMIC may limit top end a bit, but I still think it should do pretty well. The slightly more aggressive cams should help.
Two different setups, two different dynos, CXR550 setup was tuned on the dyno jet, FP red was tuned on the mustang. I couldn't believe how inflated the dyno jet numbers were over the mustang. 400whp on the dyno jet felt only a little more powerful over my stage 2 car. 380whp on the mustang feels real strong, and 471whp on the mustang on e85 feels like a complete beast.
The cams will definitely help mid range and top end for sure. I remember following your '11 WRX build. Real excited to see what this one turns into.
Old 11-08-2013, 04:51 PM   #382
blk05wrx
Member#: 180559
2016 WRX STi Limited
Sold to me! I asked a few pages ago when I saw the motor was coming out.
blk05wrx is offline   Reply With Quote
Old 11-09-2013, 10:05 AM   #383
toph
Member#: 78640
19 Tundra
04 STi
I'm wondering where you got the Grimmspeed hose that runs from the inlet under the throttle body to the BPV? I searched Importimage's page and couldn't find it.
toph is offline   Reply With Quote
Old 11-09-2013, 10:12 AM   #384
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I believe it is fairly new. They only sell it as a full kit. Here is the link.
http://www.grimmspeed.com/catalog/pr...roducts_id=265
Old 11-09-2013, 11:37 AM   #385
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep there are still plenty of the around!
My stock turbo did 340WHP on Dynojet. My 20GXTR did 390WHP at 22psi on Mustang and then 460WHP at 28psi on Dynojet.
Yep it went fast! Thanks!
Old 11-10-2013, 10:12 PM   #386
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Photos from last night. Got the intake manifold on and dropped the motor in! Still a bunch of little things to do, but it's getting a lot closer!
Longblock all together.
ACT HD with unsprung 4 puck disk.
Ready.
Real tools.
Ready to go in.
Didn't trust the straps so we dropped it in by hand.
Safely in place.
More things attached.
Cleaning up wiring. MapDCCD, VSSPro, Wideband AFR, Boost, Oil Pressure.
Also changed the PS/alternator belt on my brother's car. Easy fix for a loud squeal he had.
Old 11-10-2013, 10:37 PM   #387
Ultimateone
Member#: 48025
17 BMW M2
AW
damn getting closer
Ultimateone is offline   Reply With Quote
Old 11-10-2013, 11:08 PM   #388
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Is that the bugeye garage?
Looking good! I hope you didn't teak your back with the motor install! Funny pic!
Old 11-11-2013, 01:17 AM   #389
OMG Turbo
Member#: 370022
2003 WRX Impreza
Platinum Silver
I really like that sonic yellow on the bugeye. The build is coming along nicely and it is fun to see progress on it. Keep it up!
OMG Turbo is offline   Reply With Quote
Old 11-11-2013, 11:38 AM   #390
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Ultimateone View Post
damn getting closer
Slowly, but surely it's getting there.
Yolo is the one under the motor. He's got a pretty fast Bugeye too
http://forums.nasioc.com/forums/show....php?t=2564389
Thanks!
Old 11-11-2013, 12:57 PM   #391
manitou
Member#: 193757
2006 XTI Limited
Thanks for the link. It's a beauty wagon! I like! I hope Yolo's back is good! He does look like a sturdy lad!
Old 11-14-2013, 10:05 AM   #392
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Last night I put on the driveshaft, downpipe, exhaust, coolant overflow, windshield washer fluid, boost controller lines, turbo coolant lines, moved intake manifold grounds (due to plastic TGV's), and connected the head-to-chassis grounds.
I think these are the only things I have left: TMIC, FPR, alternator bracket and alternator, hood, wheels, oil change, coolant fill and burp, and tuning. I am still waiting on the FPR and alternator bracket, but hopefully they arrive soon and I can get to work.
Old 11-14-2013, 05:36 PM   #393
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Engine:
  • OEM 2012 STI 2.5L Case
  • OEM 2012 STI Heads
  • OEM STI Nitrided Crank
  • OEM STI 11mm Oil Pump
  • OEM STI Gasket Set
  • CP 99.75mm 8.2:1 Pistons
  • Manley Turbo Tuff I Beam Rods
  • ACL Rod and Main Bearings
  • ARP Head Studs
  • GSC S1 Camshafts
  • GSC Beehive Springs w/Retainers
  • GSC Valve Seals
  • Torque Solution Motor Mounts
Intake/Exhaust/Fuel:
  • GrimmSpeed CrossPipe
  • GrimmSpeed Uppipe
  • GrimmSpeed Downpipe
  • Perrin CatBack Exhaust
  • TD06SL2-5371 Turbo
  • GrimmSpeed Gaskets
  • GrimmSpeed TMIC w/Gold Tape
  • GrimmSpeed TMIC Splitter
  • GrimmSpeed Y-Pipe Kit
  • GrimmSpeed MBC
  • 04 STI Fuel Pump Hanger
  • Walbro 255 Fuel Pump
  • ID2000cc Injectors
  • TurboSmart FPR
Drivetrain/Transmission
  • OEM 2012 STI 6MT
  • OEM 2004 STI Driveshaft
  • OEM STI R180 Rear Diff Flange
  • Anarchy Motive Shift Knob
  • Kartboy Short Shifter
  • Kartboy Front Shifter Bushings
  • Karboy Rear Shifter Bushings
  • Torque Solution Tranny Mount
  • Torque Solution Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Unsprung Disk
Suspension/Wheels:
  • OEM 2002 WRX Wheels
  • 04 STI Struts
  • 04 STI Springs
Interior/Electronics:
  • MapDCCD
  • VSSPro
  • ProSport EVO Boost Gauge
  • ProSport EVO Oil Pressure Gauge
  • Innovative LC1 Wideband O2 Gauge
  • Odyssey Slim Battery
Exterior:
  • Installed OEM Hood Scoop
Old 11-14-2013, 06:19 PM   #394
OMG Turbo
Member#: 370022
2003 WRX Impreza
Platinum Silver
Quite the list
Old 11-14-2013, 10:49 PM   #395
02_Bugeye_Life
Member#: 373172
2002 Wrx
Rally sport blue
Looks like a fun build man, and yeah that's quite a list there sir lol
02_Bugeye_Life is offline   Reply With Quote
Old 11-15-2013, 09:33 AM   #396
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Well, it turns out I ordered the wrong fittings for the FPR, so the car won't be done this weekend Hopefully the parts arrive sometime next week and I can get it finished then. Crossing my fingers there won't be any major issues
Old 11-15-2013, 11:30 PM   #397
Lrn2Corner
Member#: 246224
2018 Type RA 271/500
CWP
Damn, for a moment before i read your mod list I honeslty thought you managed to salvage the custom 6 spd you made for your hatch and put it in the bugeye. Any plans to do that same mod to get rid of the crap 5th and 6th gear ratios?
As always though, masterfully done Ben.
Lrn2Corner is offline   Reply With Quote
Old 11-16-2013, 10:40 AM   #398
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks. No this is just a stock 2012 6MT. It has the long 1-4 so that should be OK for drag. 4th at 9k does 140mph. I won't rev that high but it should still be plenty fast for now. The tall 5th and 6th are more for improved cruising. That's not a huge deal to me with this car.
Someone locally was actually looking to trade my 2012 STI 6MT for one that he had just put all new synchros and the Spec B gears into. I didn't want to spend the $1000 he wanted for it (on top of the trade).
Old 11-16-2013, 11:14 AM   #399
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Glad you're making some good progress! That little Bug Eye is going to surprise some people. "What was THAT!?"
Cheers.
bicycle_wreck is offline   Reply With Quote
Old 11-16-2013, 10:39 PM   #400
quizno73
Member#: 299835
2002 wrx wagon
Midnight pearl blue
lol i like my beer & bacon & my slow lesbian wagon :P
quizno73 is offline   Reply With Quote
