Welcome to the North American Subaru Impreza Owners Club Monday September 21, 2020
Old 12-09-2013, 12:12 PM   #501
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by WRXt4cy View Post
Nice build so far! I'm happy to see that you are back it again.
How are you liking the MapDCCD?
I put one in the wife's car last year as all it had was a manual dccdpro. I spent some time last winter dialing in a pretty fun/useful custom snow map for it that I never really got to use until yesterday. I set it up so it turns great (stays unlocked) and starts to lock up quickly and progressively with throttle and speed. As you enter a slick corner, the first bit of gas can bring the rear out a bit and then applying more gas adds lock-up and the car pulls nicely though the corner. I had a lot of fun with it yesterday.
Have you played with the mapping much? If you want to try my snow-map, let me know!
I really like the control system so far. I've flipped through the included maps but mostly have just been on the auto setting and playing with different settings on the knob. Setting it low makes it really tail happy. Higher settings seem to lock the center diff very quickly with added throttle. Small throttle inputs show immediate response on the MapDCCD. It is obviously still unlocked at low speed, low throttle so there is no issue turning or normal driving. Seems to pull through very well.
My brother has a snow map, but I haven't tried it yet. He's had his a bit longer and has played with it a little more than me. He daily drives his car so it sees a lot more use than mine. I did get in 100+ miles since the tune though, so I have gotten some seat time. Mostly just commuting in the snow, not too much playing around.
Old 12-09-2013, 12:24 PM   #502
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
You still have only control over the predetermined 59/41 bias built into the later model center diff. correct?
Old 12-09-2013, 12:27 PM   #503
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Correct, bias doesn't change. The controller simply changes the lock up based on given inputs.
Old 12-09-2013, 12:49 PM   #504
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
You are confusing torque with lock-up. Its easy to to do.
The torque split is fixed, dccd does not change this. What it does is vary the amount of slip that is allowed in the center diff. Full open lets it slip about as much as possible so the rear wheels can spin as much faster than the front wheels as they can. Full lock does not allow any slip so if the rear wheels try to spin faster, the center diff clutch packs heat up, catch and force the front wheels to match the rear wheels' speed. Lock-up ratios in between open and full will allow different amounts of slip.
WRXt4cy is offline   Reply With Quote
Old 12-10-2013, 01:10 AM   #505
manitou
Member#: 193757
2006 XTI Limited
No I was referring to the torque split. I was just confirming that this did not change. Good explanation on the control of wheel slip though!
Old 12-10-2013, 01:16 AM   #506
KGwrx
Member#: 268868
2007 STi GDB
Although it may not do much, I say your next "mod" should be a prodrive front lip. It would just suit the car soo well
KGwrx is offline   Reply With Quote
Old 12-10-2013, 10:52 AM   #507
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's just the little one, right? I was thinking of that. Any chance you know of a decent one that's cheap? So hard to sift through all the eBay options.
Old 12-10-2013, 02:14 PM   #508
ssrcralliwrx
Member#: 134745
2011 FXT touring
SageGreen
I think Bayson R is the popular ebay choice. I had one when i had a bugeye, fitment was spot on fwiw.
ssrcralliwrx is offline   Reply With Quote
Old 12-10-2013, 03:59 PM   #509
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks like $94. Not super cheap, but not too bad I guess.
http://www.ebay.com/itm/02-03-Imprez...-/390588265050
Also, it looks white in the pictures, but it says it's black.
Old 12-10-2013, 04:05 PM   #510
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
It is black, I have had to order two of them lol.
They fit pretty well and usually still have the prodrive stampings but the quality is definitely not the same.
ehawthorne521 is offline   Reply With Quote
Old 12-10-2013, 04:11 PM   #511
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
So, you're saying the quality is better?
Old 12-10-2013, 04:14 PM   #512
ehawthorne521
Member#: 149686
Oh yes ebay quality, I praise thee. Far beyond that of Prodrive's.
Of course I am being sarcastic the Prodrive ones are much better of course
Old 12-10-2013, 04:19 PM   #513
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
Sarcasm is like your second language.
SSL. Not just a secure socket layer.
bicycle_wreck is offline   Reply With Quote
Old 12-10-2013, 04:25 PM   #514
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, I knew eBay had some good things on there!
Old 12-10-2013, 04:45 PM   #515
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
holy crap! nice build man!
-chet
ChesterWRX is offline   Reply With Quote
Old 12-19-2013, 10:58 AM   #516
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here is a video of the STX 71 (TD06SL2-GTX3071) @ 25psi on E85:
Video of the car running through the gears with the new motor/turbo/transmission setup. FFS'ing through the gears with wheelspin on the shifts (you can see the speedo jump during shifts). 50-100mph clocks in around 5.9 seconds. Seems about right for just over 400WHP and one shift in that range. The VF39 was mid 8-second range for 50-100mph so this is a pretty solid improvement.
50-100mph is 5.9 seconds
427WHP on Virtual Dyno (Dynojet)
Engine:
  • OEM 2012 STI 2.5L Case
  • OEM 2012 STI Heads
  • OEM STI Nitrided Crank
  • OEM STI 11mm Oil Pump
  • OEM STI Gasket Set
  • CP 99.75mm 8.2:1 Pistons
  • Manley Turbo Tuff I Beam Rods
  • ACL Rod and Main Bearings
  • ARP Head Studs
  • GSC S1 Camshafts
  • GSC Beehive Springs w/Retainers
  • GSC Valve Seals
  • Torque Solution Motor Mounts
Intake/Exhaust/Fuel:
  • GrimmSpeed CrossPipe
  • GrimmSpeed Uppipe
  • GrimmSpeed Downpipe
  • Perrin CatBack Exhaust
  • Steam STX 71 (TD06SL2+GTX3071R) Turbo
  • GrimmSpeed Gaskets
  • GrimmSpeed TMIC w/Gold Tape
  • GrimmSpeed TMIC Splitter
  • GrimmSpeed Y-Pipe Kit
  • GrimmSpeed MBC
  • 04 STI Fuel Pump Hanger
  • Walbro 255 Fuel Pump
  • ID2000cc Injectors
  • TurboSmart FPR
Drivetrain/Transmission
  • OEM 2012 STI 6MT
  • OEM 2004 STI Driveshaft
  • OEM STI R180 Rear Diff Flange
  • Anarchy Motive Shift Knob
  • Kartboy Short Shifter
  • Kartboy Front Shifter Bushings
  • Karboy Rear Shifter Bushings
  • Torque Solution Tranny Mount
  • Torque Solution Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Unsprung Disk
Old 12-19-2013, 11:23 AM   #517
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
love the powershifting with no limit on rev
SenorDucK is offline   Reply With Quote
Old 12-19-2013, 11:31 AM   #518
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
I have no words...
Old 12-19-2013, 11:32 AM   #519
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Drive by cable. Just have to shift fast. Haha.
Originally Posted by bicycle_wreck View Post
I have no words...
Cool.
Old 12-19-2013, 11:38 AM   #520
SenorDucK
Member#: 327511
13' WRX 6 Speed
Drive by cable. Just have to shift fast. Haha. Cool.
Oh yeah! I like it better anyway. I set mine above where I'm shifting so it's like no limit as well. I don't like using the FFS option. Without reminds me of my old foxbody mustang days
Cool video, it's hard getting used to this after seeing those PTE vids!
Old 12-19-2013, 11:50 AM   #521
enjoilife1991
Member#: 322400
03 WRX 360whp
its official... I have soled my 09 for an 03 bugeye all because of you.... thanks. hahaha
enjoilife1991 is offline   Reply With Quote
Old 12-19-2013, 12:01 PM   #522
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I really don't mind properly set up FFS. It allows you to shift pretty lazily with no consequences. Without it you really need to shift fast, and missed shifts can be trouble. But when it is well executed it feels great!
Not as fast as the 6266, or even the 20G XTR when I had full bolt on's and the boost turned up. But it's getting there. Hopefully I can squeeze a little more out of this turbo before I'm done with it.
I never liked 09's anyways, haha.
Old 12-19-2013, 12:17 PM   #523
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Very nice!
What are you running for an ECU in this car?
Old 12-19-2013, 12:23 PM   #524
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Very nice!
Stock.
Old 12-19-2013, 12:35 PM   #525
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Ahh - so what did you do with the heads in regards to AVCS? Just running without or did you do something else?
Your ECU supports the CarBerry rom which has some pretty cool features like speed density, LC w/ boost, FFS, etc.
If you ever miss a gear your engine is going to be like
