Tire & Wheel Forum sponsored by The Tire Rack |
11-25-2013, 02:43 PM | #201 |
Member#: 365312
NWIC
Vehicle:2011 STI White |
11-26-2013, 12:29 PM | #202 |
Member#: 242077
NESIC
Vehicle:1999 2.5RS Silver |
post deleted!
11-26-2013, 03:45 PM | #203 |
Member#: 220808
AKIC
Vehicle:2005 WRX Wagon Silver |
^^^This thread is designed more as a database for rim specifications not so much as a thread for will this fit on my car.. Just letting you know if no one gives you an answer or decides its prick day and chews you out for your question. I also do not know the answer to your question. Im sure you can search it though. Nasioc is loaded w/ info
12-02-2013, 11:06 AM | #204 |
Member#: 242077
NESIC
^Thanks! I'll delete the post. I searched through the aggressive wheel fitment thread but its mostly wheel set ups designed to maximize traction.
12-07-2013, 02:31 PM | #205 |
Member#: 26316
Vehicle:2014 WRX WRB |
Offset for 2014 WRX rims?
This thread is a great resource! Not terribly surprised that the 2014 WRX isn't listed because the model year is pretty new.
I have a set of Black Racing Pro N1 17x7.5 with +48 offset from my former 2002 WRX, and I am thinking of using them to mount winter tires for my 2014. Does anyone have the offset for the original equipment 17x8 rims on the 2014? I need to figure out whether my rims will work on the '14. Thanks! |
12-07-2013, 03:14 PM | #206 | |
Member#: 97135
NWIC
12-13-2013, 01:59 AM | #207 |
Member#: 225500
SCIC
Vehicle:2013 WRB WRX Sedan 11 Mazda 2 |
If anyone is wondering, 2011+ WRX wheels i took one without the tire to work today and put it on the shipping scale.
Confirmed at 21 pounds |
12-13-2013, 10:56 AM | #208 |
Member#: 30071
MAIC
Vehicle:2001 RS-T 2015 XT |
12-17-2013, 11:05 PM | #209 |
Member#: 317244
Vehicle:12 Impreza White |
2012 Impreza Premium Size: 16x6.5" Offset: +48 Bolt pattern: 5x100 Weight: 18.6 (estimate) OEM-equipped tire size: 205/55R16 Just weighed a rim today and my scale came back at 15 lbs even with wheel weights, tpms and valve stem. I'm going to verify this on a different scale thought. Edited: weighed on a postal scale at 16lbs oz. Last edited by Sticman; 12-20-2013 at 09:05 PM. |
12-21-2013, 01:30 PM | #210 |
Member#: 302874
Vehicle:1995 Impreza L wagon White |
I am looking at a set of the 2002-2005 Impreza and WRX wheels that are on page-1 of this thread. Both are identical dimension-wise, except for the offset. The Impreza has a +55, while the WRX has a +53.
The stock steel wheels on my 95 Impreza wagon are +55 and I've chosen to use these now solely as my winter tire wheels. I will not swapping tires anymore, so looking at the wheels I mentioned above for my spring-fall tires. Will the +53 wheels fit fine on my Impreza or should I stick with the +55? I can't see it being an issue, but wanted to check before I go after either wheel choice. Thanks! |
12-21-2013, 01:47 PM | #211 | |
Member#: 97135
NWIC
12-21-2013, 01:57 PM | #212 |
Member#: 302874
I know, and I was actually hesitant about asking, but I'd rather be safe than sorry. Didn't know if there was a reason for the difference between the wheel for the Impreza and the one for the WRX. Thanks for helping me answer my own question.
12-21-2013, 07:11 PM | #213 |
Member#: 235777
MAIC
Vehicle:2000 RS BuRP 2007 2.5i CGM |
Not sure of it's been posted but I didn't see it on the original lineup. 06-07 Impreza 2.5i OEM wheels by Enkei 16x6.5 et55 Don't have them measured separately but the OEM Potenza RE92A weighs 21 lbs per the Bridgestone site and the combined weight is 38.7 lbs. So I'd say the wheel weight is around 17.7 lbs. References:
12-21-2013, 07:25 PM | #214 | |||
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
12-21-2013, 07:28 PM | #215 |
Member#: 235777
MAIC
01-01-2014, 09:36 PM | #216 | |
Member#: 308649
Vehicle:1998 Legacy GT Wagon |
Photo of GT-B Limited, on which they were original equipment: (Photo credit: Reuben) The photo that Panda205 linked above (but had trouble posting) is shown here: JDM wheels by stisik89, on Flickr As it turns out, this is the EXACT SET that I bought, and yes, was in the craigslist ad that was mentioned by Panda205 above. (Minds = Blown, I know, lol). Here is my own snapshot and confirmed specs: 1996-1998 JDM Legacy Twin Turbo GT-B Wagon (BG chassis) and TS-R Sedan (BD chassis) Size: 17x7" Offset: +53 Bolt Pattern: 5x100 Wheel Weight: 17.8 lbs/8.1kg OEM-equipped tire size: 215/45R17 EDIT: Color: confirmed as the powdercoat version of 89N Titanium Pearl Additional info: Made In Japan by Fuji Heavy Industries (Subaru parent) Outer Rim Max Diameter: 18.5"/470mm Outer Rim Max Width: 8"/205mm Rim Flange Type: JJ Center Cap part number: 28811 Ac020 Edited for brevity and clarity by OP's request. Some pertinent additional info left intact for the sake of completeness. Last edited by camroncamera; 02-20-2014 at 03:27 PM. Reason: Edited for clarity by OP's request |
01-02-2014, 09:21 PM | #217 |
Member#: 375618
MAIC
Vehicle:2014 WRX Hatch Blue |
how much would a 4th gen stock wheel go for you think and how hard is it to get those/price? I shaved mine and want to replace it.
01-08-2014, 12:50 PM | #218 | |||
Member#: 12029
MAIC
--Dan Mach V FastWRX.com |
01-22-2014, 10:48 AM | #219 |
Member#: 379466
International
Vehicle:1997 Legacy GT-B Silver (406?) |
So has anyone got a photo of those BG5 wheels on a classic, i.e. GC8, Impreza at all? I'm considering a set for my 406 silver Impreza turbo
01-22-2014, 04:23 PM | #220 |
Member#: 379498
very useful
01-26-2014, 08:35 AM | #221 |
Member#: 378358
Vehicle:2014 WRX hatch DGM |
In looking through this thread, I've determined that the 2011 OEM wheel for the WRX is 17x8 +53.
Is it safe to assume this carried throughout the subsequent years? I know the 2013 and 2014 are identical, but I cannot seem to find any post in this thread that specifically mentions those years (or if there was a change after 2011). The latest I could find was the 2011 post. Thanks! BC |
01-26-2014, 09:11 AM | #222 | |
Member#: 97135
NWIC
Yep. Wheels are the same. |
01-26-2014, 04:09 PM | #223 |
Member#: 378358
OK. Sorry if I am just too dense to understand this, but according to the "Offset Nirvana" post, a 8" wide rim should have an offset between +43 and +47.
If that's the case, why does the OEM rim have an offset of +53? I'm not trying to be difficult, I'm just trying to understand. Thanks in advance! BC Last edited by zeitgeist; 01-26-2014 at 05:01 PM. |
01-26-2014, 05:27 PM | #224 | |
Member#: 97135
NWIC
But OEM isn't always (usually not) optimal. |
01-27-2014, 10:15 AM | #225 |
Member#: 373084
Tri-State
Vehicle:2008 WRX Hatch SWP |
just subscribed, this is an awesome thread and just wanted to thank the OP and everyone who has contributed. this has been very helpful so....thanks!
Similar Threads | ||||
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels | MR2fanatic | Tri-State Area Private Classifieds | 7 | 04-03-2011 09:24 PM |
WTT: OEM subaru wheels/tires for Gold 17" wheels | veselik3 | NWIC Private Classifieds | 2 | 05-16-2006 03:24 PM |
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels | anthonyrb98 | Private 'For Sale' Classifieds | 53 | 04-27-2006 12:43 PM |
Anyone have a set of OEM WRX wheels they want to get rid of? | Skibum4444 | North West Impreza Club Forum -- NWIC | 2 | 01-31-2003 12:48 AM |
Subaru Wheel Specs | Snowrider | Brakes, Steering & Suspension | 3 | 10-07-2001 09:20 PM |
