Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 03-20-2013, 12:13 PM   #151
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Decided to grind down my Kartboy shifter from my WRX and give it a try. Turned out great, over two inches shorter + 35% shift reduction!
JungleFevre is offline   Reply With Quote
Old 05-08-2013, 07:46 AM   #152
mikenmel08
Member#: 336683
The CEL has to work for an emissions test...if the light doesn't come on when you turn the key on its an instant fail...
mikenmel08 is offline   Reply With Quote
Old 05-08-2013, 08:24 AM   #153
Benhart21
Member#: 149617
That depends on where you are and your local laws. There are plenty of people here that run a standalone setup but still pass the sniffer test.
Benhart21 is offline   Reply With Quote
Old 07-03-2013, 01:36 PM   #154
TurBaja05
Member#: 360425
2005 baja turbo
Originally Posted by slagman View Post
The Cusco bar is a guaranteed fit, even with a bigger top mount intercooler.
i know this is old, but which cusco bar?
TurBaja05 is offline   Reply With Quote
Old 01-11-2014, 09:31 AM   #155
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
The red steel spt bar fits too. Basically any gc8 strut bar should fit. The red spt one is a super tight fit against the firewall and is the most rigid bar I have found for the baja.
2.5 turbo hyped is offline   Reply With Quote
Old 01-11-2014, 09:34 AM   #156
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Legacy b4 jdm mines bars fit on the turbo bajas.
Old 01-11-2014, 09:36 AM   #157
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Bc racing made me a custom set of coilovers per my specs: 14k swift springs and 50mm longer struts on all 4 corners. Best set of coilovers I have ever owned. I am so impressed with the swift springs that I am ordering a set for my STI bc racing coilovers.
Old 01-11-2014, 09:42 AM   #158
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Corbeau lg1 seats fit.
Old 01-11-2014, 09:44 AM   #159
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Whiteline kca399 rear camber kit fits.
Old 01-11-2014, 09:47 AM   #160
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Enkei rpf1 gold 17x9 5x100 +35 (size only available from oakos) fits perfect.
Old 01-11-2014, 09:49 AM   #161
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
I have updated this thread with all of my fitment related test/trial items.
My current project slated for the baja and projected to be finished before next winter is this:
Old 01-14-2014, 12:34 AM   #162
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
For everyone that has contributed to this. Thank you.
I am signing papers on a baja tomorrow and this helps me tremendously.
RustyHinge is offline   Reply With Quote
Old 01-14-2014, 09:38 AM   #163
97cv
Member#: 151048
2003 Baja
Black/ Silver
wOOT! !
97cv is offline   Reply With Quote
Old 01-14-2014, 09:52 AM   #164
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Installed Whiteline Front Steering rack bushings (KSR202) on my 05 turbo last week
Old 01-14-2014, 01:51 PM   #165
Benhart21
Member#: 149617
Should've bought mine.
Old 01-19-2014, 03:34 PM   #166
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
'71-FF1/05 Saab-92X-Aero
Very impressive modding you've done on your Baja!
Can you provide more info on your coilovers? I run a set, but ones from Megan designed for the Outback.
If others wanted to order a set like yours what specs/dimensions/model no. are these parts? Thanks for any info you can share.
frogmonk is offline   Reply With Quote
Old 01-19-2014, 04:05 PM   #167
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Sure thing. They are bc racing coilovers designed specifically for the baja. I requested 50mm longer strut cartridges on all 4 corners and upgraded all of the springs to 14k swift springs. I was only able to do this because Josh (the owner of import image racing) is great friends with the owner of bc racing. Order them through import image racing and tell Josh you want the same baja setup Sean Fillner has. It was 1206 shipped for the custom setup.
Old 01-19-2014, 04:42 PM   #168
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
^ Great info. Thanks!
I've dealt with Josh but not for custom stuff. I run the ER series on my Forester & also got a carbon driveshaft from him.
Old 01-19-2014, 04:54 PM   #169
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
What kind of hp figures warrant a carbon driveshaft?
Old 03-27-2014, 08:00 PM   #170
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
Did we ever get conformation of 2009 STi struts being a direct fit?
Patrikman is offline   Reply With Quote
Old 03-27-2014, 11:55 PM   #171
Patrikman
Member#: 234499
2004 Outbrat XT
Also, the TMIC. Is that Baja specific? Will an FXT one fit?
Old 03-28-2014, 04:41 AM   #172
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
The TMIC has been covered numerous times in this thread. Check it out. :-)
Old 03-30-2014, 12:06 AM   #173
SoobieDoobieDoooo
Member#: 156440
-_- I am da wheeler
dealer king! Yeea buddy!!
Looking good Sean!
-Carlos
SoobieDoobieDoooo is offline   Reply With Quote
Old 03-30-2014, 10:37 PM   #174
lockmedic
Member#: 314893
Man I thought I was blazing trails with mine, then I found this thread. . .lol! This is mine (work in progress):
Here's what I can add:
-Invidia downpipe for LGT/WRX/STi will not fit without modification to either the pipe or the frame gusset. I just removed the gusset, I'll notch and box it when I get time.
-I took a different approach to the STi TMIC ducting issue. I got a stock STi splitter with the IC and turbo I bought, so I opted to try and use it. After much studying I wound up using a regular flat Legacy/Outback NA hood and added a STi scoop to it. Wasn't too bad to do. Bonus is I have a functional IC water spray system. . . used a washer fluid tank from a Saab 9-2x which mounts inside the fender under the battery. Build thread over on subaruoutback.org. . .although it's a mess. Hood scoopyness starts around here:
http://www.subaruoutback.org/forums/...rbo-5mt-4.html
-Picked up an Agency Power short throw shifter on CL from an unknown year WRX. It worked after I milled it down to fit. . . it was about 1/4" too wide (as has been mentioned elsewhere in this thread:
and installed:
-I'm running 08 LGT brakes. Direct bolt on, but they do require 17" wheels. Not as pretty as Brembos but you can pick up a set for 1/4 the cost, and they're a big improvement over stock. Rotors are over 1" larger diameter and waaay thicker too.
-I swapped crossmembers while I had the engine out and am using essentially an 05 STi crossmember and steering rack. Steering rack requires a u-joint from something like a 4th gen Legacy as the spline pattern is different than that of the Baja. I used an 08 LGT one. STi crossmember has tabs for a subframe brace which helps support the lower control arm and strut mounting points. Haven't bolted on the subframe brace yet as I don't have a straight one but i'll make that happen eventually. I'll attach it to the body with J-nuts. Crossmember is a bolt-up piece, but the attachment points for the LCA's are wider. I'm using stainless washers to take up the slack (about 6mm) but eventually I'll switch to aluminum STi LCA's which won't need 'em.
Crossmember madness here:
http://legacygt.com/forums/showthrea....html?t=221606
-05-09 Legacy/Outback seats fit if you cut the rear brackets off and reuse the Baja/2nd gen Outback ones. If you score some GT Limited seats, you also get heat and power on both sides. These are from an 08 LGT Limited. The seat heater switch does not fit, I had to make a bezel and use copious amounts of hot glue to put it in the place where the coin holder lived in the Baja.
-02-07 Impreza gauge pillar pod works if you take a heat gun to it and reshape the ends. This is a GlowShift one, they're vacuum molded ABS so they use heat to form them initially anyway. Gauges are Prosport electronics with opening ceremony. Thought I'd like them but they're kinda noisy (stepper motors) and the backlighting only changes color, it does not dim, and they're kinda buggy on the whole 'color change' bit if you turn the car on with the headlights already on. One works consistently, the other 2 do what they wanna do. I guess you get what you pay for for $50 each, senders included.
I stripped the wiper de-icer electronics off an LL Bean Outback. I'll swap the windshield for an Outback one with heat pretty soon. Put the switch where the "sport light" switch would go. Snaps right in. Eventually I want to swap over the auto HVAC as my other Outbacks have it and it's ruined me.
lockmedic is offline   Reply With Quote
Old 03-31-2014, 11:06 AM   #175
Trucklett
Member#: 334882
2006 Baja Turbo 5MT
WOW! Nice work. Ooh. I am very interested in this use of the Legacy GT seats. I already have the 05 Turbo Auto leather seats in my Baja. Do you think I can make these work with that switch set up?
Trucklett is offline   Reply With Quote
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
