Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 01-11-2014, 10:19 AM   #551
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Hmmm....
Old 01-11-2014, 10:47 AM   #552
bnasty49
Member#: 351310
2013 WRX
Crystal B RIP
Hmmm....
Perhaps a reverse scoop hood? *wink*
bnasty49 is offline   Reply With Quote
Old 01-11-2014, 11:00 AM   #553
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
No, probably that scoopless hood on the rafters in the garage from a couple pages back.
RavensFan7 is offline   Reply With Quote
Old 01-11-2014, 11:03 AM   #554
bnasty49
Member#: 351310
2013 WRX
Crystal B RIP
Dream crusher. =p
Old 01-11-2014, 11:56 AM   #555
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Oh hell no.
Yeah...
Old 01-11-2014, 04:01 PM   #556
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
TurboSmart Dual Port BOV is for sale:
http://forums.nasioc.com/forums/show....php?t=2589442
Old 01-12-2014, 11:04 PM   #557
enjoilife1991
Member#: 322400
03 WRX 360whp
i used to have the turboxs hybrid on my 09 and i had to get rid of it because it was leaking all over. check yours out because on mine there was no type of o-ring around the vent to keep it sealed when closed. let me know.
enjoilife1991 is offline   Reply With Quote
Old 01-13-2014, 05:43 AM   #558
mother_russia
Member#: 378574
Damn dude those are some nice numbers!
Haha I love the fact that you're proud of your miles on the car!
mother_russia is offline   Reply With Quote
Old 01-13-2014, 08:07 AM   #559
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Love scoop-less
ocdpvw is offline   Reply With Quote
Old 01-13-2014, 08:27 AM   #560
Joebie
Member#: 270313
2014 STI Hatch
DEEGEE-EMM
One of the NF guys has a GC with a 6266 and ignition cut LC set up. Shoots lots of flames and is really loud. I got to take it down the strip and it basically just builds full boost instantly.
Nuke has had some good luck playing with timing and fueling along with the fuel cut LC and gotten some decent boost off the line. That is what is used for the Speeding Bullet STI that ran in the 9's.
I didn't think FFS worked with DBC? How does it reduce the rev's when the gas is all the way to the floor. Isn't the throttle just staying wide open? Never really looked into it before I guess.
I know this is an older post, but I've always associated fuel cut LC being lean in cylinder and it does sketch me out a bit. Also worried about the EGT's when doing it as well. I run spark cut LC on a different car of mine with pretty good success, able to build an easy 10PSI with the old turbo setup. Since it is just a project/poop car I was running a chinabay "60 trim" turbo and it didn't seem to mind the abuse of the un-burnt fuel surprisingly. Since I have switched to a Garret 57 trim and it doesn't seem to mind it yet either, but I haven't had a lot of time with it lately due to weather.
Also, as always, dig your build threads, like reading a good book.
Joebie is offline   Reply With Quote
Old 01-13-2014, 10:31 AM   #561
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I ran the same valve on my 2011 for a while. It is a series design like most other 50/50 valves. It will vent back into the inlet first, and then then to atmosphere second (only when the valve is fully open). It worked well for me and had a nice, subtle sound. I did not have any issues.
This valve is 100% VTA and has the trumpet on it, so it should be much louder. It is also more of a risk for leaks at idle, but on a speed density setup a small leak isn't got to make much of a difference, unlike on a MAF setup where it will cause huge problems. Although, when properly set up it shouldn't leak at idle in either case.
Thanks. I'm not really "proud" of them, but I think that stock motor and trans did pretty well for the miles they had on them. Glad to have them replaced now though!
Originally Posted by ocdpvw View Post
Love scoop-less
Yep, I'm definitely a fan.
Ignition/spark cut LC is much, much harder on the car than fuel cut. Ignition cut causes huge EGT's and can very easily damage the valvetrain components (even moreso than the turbo). Fuel cut puts no fuel into the cylinder. It is not "lean", there is just no fuel. There is very little risk. Ignition cut is more fun (and builds way more boost), but it is way harder on the car.
Old 01-14-2014, 02:17 AM   #562
enjoilife1991
Member#: 322400
03 WRX 360whp
I did a smoke test on mine and under just 5 lb's of pressure it was smoking like a chimney! I could only imagine what it would be like with 20+ pounds of boost. I understand that with the speed density tune it wont cause any detrimental problems but with the leak (small or big) it should take longer to hit full boost. Right?
Old 01-14-2014, 09:06 AM   #563
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The design of that BPV (and most BPV's) requires pressure on the top and bottom of the valve. Pressurizing the inlet, like most smoke tests do, will only put pressure on the bottom of the valve, but not the top. This will surely cause the valve to lift and let air past.
With a recirc valve it just recirculates and you don't see it. With a BOV or 50/50 it will vent out to atmosphere and look like a huge leak. But in reality when the car is actually in boost the valve is held firmly shut by boost pressure on the top of the valve. Here are some more links that explain it in much more detail:
http://www.gfb.com.au/tech/troublesh...lve-is-leaking
http://www.gfb.com.au/tech/tech-arti...ng-boost-leaks
Old 01-15-2014, 03:32 PM   #564
enjoilife1991
Member#: 322400
03 WRX 360whp
Oh I see! I didn't even think about the fact that the intake manifold wasn't being pressurized... that makes a lot of sense now. thanx!
Old 01-18-2014, 06:09 PM   #565
Letty-Ortiz
Member#: 379104
2014 GBS FRS
i can't remember a thing
so....how soon until full retard.
Letty-Ortiz is offline   Reply With Quote
Old 01-18-2014, 06:39 PM   #566
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Maybe next year.
Old 01-18-2014, 06:42 PM   #567
Subaru Guy
Member#: 234928
2005 Tacoma
Fantastic haha.
Subaru Guy is offline   Reply With Quote
Old 01-18-2014, 10:34 PM   #568
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My brother and I took off the front end stuff last night:
Forester is covered in salt. This was after getting a car wash earlier in the day
Also seen in this photo is the full size fridge I moved out there when we got a new one for the kitchen
Old 01-21-2014, 12:56 AM   #569
paulpat
Member#: 237145
02 WRX
12 FXT
Originally Posted by WRXt4cy View Post
Ahh - so what did you do with the heads in regards to AVCS? Just running without or did you do something else?
Your ECU supports the CarBerry rom which has some pretty cool features like speed density, LC w/ boost, FFS, etc.
If you ever miss a gear your engine is going to be like
I am still upset that there was no Ej207 swap for the heads and the ecu/avcs. But I guess having the 02 WRX ecu and the CarBerry rom makes up for it. Its a future dilemma that I hope to make or not to make. lol.
Its just... not using the avcs, people keep saying that there is so much low end left on the table. The huge turbo is cool and all but I like the instant spool of the td04 especially for autoX. Would you even consider autoX in the future?
Sorry. I'll stop being a troll.
-paul
paulpat is offline   Reply With Quote
Old 01-21-2014, 08:47 AM   #570
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-paul
Low end isn't a huge concern for me on this build. This isn't a daily driver and my goal is strong top end. The added complexity to try and get AVCS just wasn't worth it to me. If I wanted to do an autocross car I wouldn't do a WRX! But I don't have any plans for a dedicated autocross car any time soon.
Old 01-29-2014, 09:32 PM   #571
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
New oil line:
Old 01-30-2014, 12:29 AM   #572
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
Details about the oil line please? Specifically does it fit VF39's and where did you get it?
ehawthorne521 is offline   Reply With Quote
Old 01-30-2014, 08:52 AM   #573
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's the FP non-AVCS oil line kit:
http://store.forcedperformance.net/P...LSSSubaru.html
This kit bolts to the back of the head. It has fittings to work with an OEM turbo (or any other turbo with the same threading on the oil input).
They also make another version of the kit that pulls the oil from the top of the AVCS at the front of the head (on cars with AVCS).
http://store.forcedperformance.net/P...ubaruAVCS.html
My car has all AVCS items in place (but not used due to ECU limitations), but I got the non-AVCS kit because it is a cleaner/easier option for install.
Old 02-03-2014, 01:29 AM   #574
ehawthorne521
Member#: 149686
Great!! Awesome to know, I have been looking for something like this. The hard line is a pain when pulling the turbo off.
Old 02-04-2014, 10:28 PM   #575
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
A new noisemaker arrived today. TurboSmart Comp-Gate40.
