Welcome to the North American Subaru Impreza Owners Club Friday February 21, 2020
Old 04-08-2014, 12:22 AM   #1
NIL8GM428
Member#: 126558
2015 WRX
ISM
Hey guys, I should be taking ownership of my 2015 WRX in early May. In the meantime I have been searching for a wheel and tire combo to replace those hideous(to me) 17's.
For those of you that have your cars already what size of wheel/tire combo do you feel would complement the car? Looking for a semi aggressive set up but not interested in rolling any lips. Car will be lowered(mild) once someone offers a spring. I was hoping to run 18's in the 265/275 range. Think this is a possiblility? Any recomendations on rim size/offset??
thanks
Rick
NIL8GM428 is offline   Reply With Quote
Old 04-09-2014, 12:30 AM   #2
willimprez
Member#: 91655
15 STI
CWP
I'm in the same boat , just picked up my 15 WRX and will be swapping to some nicer wheels and tires ASAP.
I'm aiming for 18x9.5 Et 35-48ish with 265/35-18
willimprez is offline   Reply With Quote
Old 04-09-2014, 12:34 AM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
Already tested on our new 2015 STI launch edition
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
19x10.0 +35mm 5x114.3
RavSpec is offline   Reply With Quote
Old 04-09-2014, 12:38 AM   #4
RavSpec
Member#: 26854
2002 Impreza
WRX
roll fender, coil over, camber arms needed.
Old 04-09-2014, 12:53 AM   #5
NIL8GM428
Member#: 126558
2015 WRX
ISM
So what do you think the largest wheel/tire that can be fit in without any other mods? Of the above wheels that you tried what was the best fit?
Old 04-09-2014, 01:50 AM   #6
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Should fit fine with a 255 tire with no fender roll on 45 offset. Just by eye on the new STi there is still room for more tire, and they are 245s with 55 offset wheels. 255 with 45 offset will stick out 15mm farther than stock STi.
DrDanimalSize is offline   Reply With Quote
Old 04-09-2014, 08:22 AM   #7
sc00by4life
Member#: 97135
Offset means nothing without width.
Old 04-09-2014, 12:15 PM   #8
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
shortly.
Tested... What were the tires? What were the verdicts?
colin1234567 is offline   Reply With Quote
Old 04-09-2014, 12:30 PM   #9
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
hmmm not that i don't believe you i'm just a bit surprised by the coils and camber arms... I was hoping it had clearance to fit a 18 x 9.5 +38 without major work. Do you think a thinner tire like 245/35 - 235/35 would make a difference?
awd1927 is offline   Reply With Quote
Old 04-10-2014, 10:10 AM   #10
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Of course a thinner tire would make a difference, that's why I mentioned a thinner tire in my post. With 45 offset it should fit just fine. (Again, just going by eye, I haven't measured or test fitted)
Old 04-10-2014, 10:17 AM   #11
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
True ... I'm just thinking of a concave style rim and a 45 offset will kill the look.
Old 04-10-2014, 10:52 AM   #12
sc00by4life
Member#: 97135
Concave depends on the wheel, not the offset.
Old 04-10-2014, 10:59 AM   #13
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
I personally have never seen a deep concave rim without a low offset ... doesn't mean it doesn't exist lol
Old 04-10-2014, 11:12 AM   #14
sc00by4life
Member#: 97135
i guess this is the problem with being a wheel whore.
can you guess which one has a lower offset?
or
or
or
that last one is a little tricky.
Old 04-10-2014, 11:31 AM   #15
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
I was thinking along the lines of the style and look of those rota grids in gold ...the ones above it I didn't define in my head as concave (which I can totally be off as far as my definition goes lol)
Old 04-10-2014, 11:33 AM   #16
sc00by4life
Member#: 97135
Lol no worries, I was merely using them as an example of wheel face changes based on offset.
Each pair has identical faces and different offsets .
Old 04-10-2014, 11:40 AM   #17
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
So I am correct that the lower the offset the more sunken in the center of the rim is giving it a more concave look? If i were to purchase a rota grid with a 18x9.5 +45, +48 offset it would have the same face but totally different concave look than a 18x9.5 +38 or +35 offset. That was the point i was trying to make I guess i explained myself wrong.
Old 04-10-2014, 11:43 AM   #18
sc00by4life
Member#: 97135
No, same face is same face.
The first pictures I posted are an 18x9.5 +44 and +35 dpt.
The last two pictures of grids are 17x9 +25 and +42.
The 18" concave grids came in a few sizes, 18x9.5 +38, +35 and 18x10 +30 - all have the exact same face.
Old 04-10-2014, 11:48 AM   #19
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
Hey learn something new everyday ...lol thanks
Old 04-11-2014, 10:03 PM   #20
RavSpec
Member#: 26854
2002 Impreza
WRX
Confirmed fitment , best with spring drop 18x9.5 +38
Old 04-11-2014, 11:37 PM   #21
NIL8GM428
Member#: 126558
2015 WRX
ISM
RavSpec could you please elaborate a little bit. Are you still saying that fender roll, coil overs and camber arms would be needed to run 18x9.5 +38? What tire size would you recommend with this wheel? Any info is greatly appreciated.
Thanks Rick
Old 04-12-2014, 02:26 AM   #22
DrDanimalSize
Member#: 254097
2010 2014 Impreza
also in for what tire size
Old 04-12-2014, 09:43 AM   #23
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
RavSpec: How usable was the 18x10 +22's ? I'm considering a rim in exactly this size, but only if it's actually usable.
Was thinking 245/255 40/18s for rubber.
spyrule is offline   Reply With Quote
Old 04-12-2014, 11:26 AM   #24
sc00by4life
Member#: 97135
Originally Posted by spyrule View Post
RavSpec: How usable was the 18x10 +22's ? I'm considering a rim in exactly this size, but only if it's actually usable. Was thinking 245/255 40/18s for rubber.
How is a 10" wheel "useable" if you're stretching tires?
Old 04-12-2014, 01:42 PM   #25
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Yeah, truthfully, I hadn't thought about the rubber width.
Ok, lets day 265/40/18's
