Welcome to the North American Subaru Impreza Owners Club Wednesday July 26, 2017
Old 03-17-2014, 10:16 PM   #26
dalt1225
Member#: 383594
Which part again had both cruise control and hands free? Thanks
dalt1225 is offline   Reply With Quote
Old 03-19-2014, 03:13 AM   #27
Raritiescarlover
Member#: 385031
I must have to agree with you there.Thank you
Raritiescarlover is offline   Reply With Quote
Old 03-20-2014, 06:01 AM   #28
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Originally Posted by VegasSubie View Post
I called the local Subaru dealership here about this and they told me that the ECM isn't wired for cruise control to work. They said there's no real way to get cruise control installed on a base model. Is this just something they're trying to hide or will it really work on any base model impreza?
Good question. My guess is that they actually don't know. When I mentioned the secret menu on the HU that people have discovered here, along with a couple of other things NASIOC members have discovered, the service manager at my nearest dealership didn't have any idea that these things could be done. Sadly, dealers seem to be giving out answers based on assumption rather than facts, unless that is what Subaru is telling the techs.
John
Old 03-24-2014, 04:12 PM   #29
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Can someone confirm which part number it is that has the hands free and the cruise control buttons?
VegasSubie is offline   Reply With Quote
Old 03-24-2014, 09:10 PM   #30
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Not finding the actual part number but hopefully this link works:
http://heubergersubaruparts.com/part...iagram=7595290
Item #5, cruise switch w/satellite, $128.25
John
Old 03-25-2014, 06:32 AM   #31
emiliobadillio
Member#: 376596
2017 WRX Premium 6MT
CWP
83154FJ160 is the correct part number.
emiliobadillio is offline   Reply With Quote
Old 03-26-2014, 03:13 PM   #32
Skyless
Member#: 380145
im dumb
Skyless is offline   Reply With Quote
Old 03-26-2014, 05:48 PM   #33
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Originally Posted by Skyless View Post
Anyone confirm this works on the 2014 base impreza?
You obviously didn't read the thread.
Originally Posted by RKNewell View Post
Dealers told me "Naaaaah, you can't add cruise control to your 2014 base Impreza." Still, I had to try, and luckily, part # 83154FJ160 works like a charm! My thanks to all of you who contributed the info I needed.
Old 04-03-2014, 05:24 PM   #34
emiliobadillio
Member#: 376596
CWP
Just installed on my 2012 Subaru Impreza 2.0i hatchback. Confirmed the cruise buttons works without any problems! Now I need to figure out how to get the audio controls to work with my Pioneer...
Old 04-04-2014, 07:10 PM   #35
123parker
Member#: 384890
Unfortunately this did not work on my 2010 Subaru Exiga. I got an Imprezza cruise control pad for $30 delivered on Ebay which fitted extremely easily (same steering wheel, no airbag clips) but the cruise button does nothing other than turn the dash cruise light on! I think some software download thing happened when I first installed the switches but perhaps I needed to enter something on the screen like "run" or "install". Unfortunately my car is an import from Japan and all the screen commands are in Japanese! Any suggestions? I suspect some bit of hardware is missing to activate the brakes.
cheers
Richard
123parker is offline   Reply With Quote
Old 04-06-2014, 06:06 PM   #36
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Just got my cruise control installed. Was a bit of a pain to install but it works great. I messed up a little doing mine so it took a little longer. When I put it all back together I forgot to bolt the steering wheel on. Had to take it apart and bolt it back up. Then I didn't put the steering wheel on completely straight. I'm pretty much a pro at taking it apart and putting it back together now. Make sure you pay attention to how the wiring is routed. And you'll also have an extra connector that clips into the back piece on the steering wheel. I think it might be for paddle shifters, but I don't know.
Old 04-13-2014, 02:49 AM   #37
bunchofcod
Member#: 374502
2013 Impreza 2.0i
Red
Is it possible to plug in the cruise control without removing the steering wheel? It looks like it plugs right in after the air bag module comes out.
bunchofcod is offline   Reply With Quote
Old 04-13-2014, 09:13 PM   #38
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
No, it all needs to come out. The SWC's have screws from the back. Really, getting the air bag out is about the worst part anyway. After that it goes pretty easy. I did a write up when I replaced my steering wheel with the factory leather one. Same procedure to do what you want.
John
edit: here is the link: http://forums.nasioc.com/forums/show....php?t=2435531
Old 04-14-2014, 12:49 AM   #39
123parker
Member#: 384890
You need to remove the wheel to get access to the nut for fitting the switch. It's really easy, just don't forget to disconnect the battery. I could do it all in 15 mins now but sadly the cruise control just doesn't work!
Old 04-14-2014, 06:12 PM   #40
123parker
Member#: 384890
Could it be I'm missing a relay? There is nothing in the stop lamp relay spot...
Old 04-17-2014, 01:05 AM   #41
123parker
Member#: 384890
Well, the relay wasn't connected but am not giving up yet. My switch has 5 wires (not 3) and the plug has 8 pins (not 10 or 12). Anyone know the significance of the extra 2 wires? Maybe I need to move the wires?
Old 04-22-2014, 02:50 AM   #42
Htownman
Member#: 388320
2014 Subaru impreza
So if I order the number five I wouldn't have to mod the harness.
Htownman is offline   Reply With Quote
Old 04-22-2014, 10:36 AM   #43
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
You're probably not gonig to get much help in this thread. This is for the newest generation of Impreza. Your car may be completely different than ours so nothing you see here is probably going to work for you.
That's correct. It plugs in to the same spot with the same connector as just the audio controls. You'll have an extra connector that clips into an area near the bottom of the steering wheel.
Old 04-23-2014, 03:25 AM   #44
Htownman
Member#: 388320
2014 Subaru impreza
is the 12-13 subaru Legacy 83154AJ180 compatible with 2014 subaru impreza 2.0i
Old 04-25-2014, 04:43 AM   #45
Htownman
Member#: 388320
2014 Subaru impreza
Anyone know because I have a chance to buy the legacy version for 45.00
Old 04-28-2014, 11:39 AM   #46
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Doesn't look like it does.
Old 04-28-2014, 10:59 PM   #47
subie_newbie13
Member#: 387191
2012 Impreza 5-Door
Dark Grey
Thanks for posting this, definitely going to be trying it soon!
On a side note, does anyone know if a 2012 Impreza Hatchback Base with CVT transmission can be upgraded to the paddle shifters in the same fashion? Just plug and play? It probably won't work because the shifter/transmission is set up for Drive and Low (to the side), but I figured I would ask since I didn't think the cruise control install would be that easy.
subie_newbie13 is offline   Reply With Quote
Old 04-29-2014, 10:13 PM   #48
tomtom88
Member#: 388806
2014 Impreza 2.0i
Victorian Red Pearl
I'm just guessing here, but I don't think it's possible. My reasoning, our 2.0i doesn't have the ability of being put into manual drive mode. Like you mentioned, we only have the option to select low gear. I believe that is our limiting factor regarding your query.
tomtom88 is offline   Reply With Quote
Old 04-30-2014, 01:05 AM   #49
123parker
Member#: 384890
Finally got my cruise control working! The problem was I had the 2 pin stop light switch rather than the 4 pin combined stop light and brake switch. This meant I was getting a brake switch error which disabled cruise. It was a breeze to install because the 4 pin connector was already wired into the loom. Total cost of cruise buttons and stop switch was NZ$80 (that's about US$60)! Subaru and several auto electricians told me it was not possible, what a load of bull!
Old 04-30-2014, 09:58 AM   #50
Thefifth
Member#: 389497
So what is the part number for the 2012 impreza? There's at least 4 different part numbers posted in here. I ONLY want the cruise controls, I have an aftermarket head unit and I don't want to rewire it to use audio controls.
Edit: is it #4 here? http://heubergersubaruparts.com/part...agramCallOut=4 and that's just plug and play right, no cutting up harnesses?
Thefifth is offline   Reply With Quote
