Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 04-21-2014, 09:57 AM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Killer B Motorsport Spoolinator TURBO Kit with GTX3576-R RESULTS!
Event: dyno tune
Ambient Temp: lower 90s
Elevation: sea level-ish
Weather: hot/humid
Conditions: Shop/Street
Tires: OEM
Car: 2012 STi Hatch
Tuner: JRTuned
Dyno Info: Mustang Dyno
Transmission: Stock
Gear: 4th
Pump 93 Peak WHP 450
Pump 93 Peak WTQ 450
E85 Peak WHP 597
E85 Peak WTQ 574
Baseline hp/tq for a stock on same dyno: tock STi ~200whp, Stage II ~275whp
Target Boost: 22 psi Pump 93
Target Boost: 28 psi E85
Fuel: Flex Fuel
Engine/Power Modifications: ID1300 injectors, Flat4Motorsport Fuel Rail Kit, Cobb/Custom intake, Perrin Pro EBCS, Perrin 3" turbo Inlet, GTX3576-R w/modified inlet and Tial V-Band Housing (0.83 A/R), Tial MV-S Wastegate, Killer B Header and EWG Up-Pipe, KILLER B MOTORSPORT - SPOOLINATOR TURBO KIT, Megan Cat-Back, Killer B Motorsport Performance Oil Pan/Pickup/baffle, Killer B Motorsport Air/Oil Separator, and TGV Deletes.
Other Modifications: Killer B Motorsport Upper Turbo Reservoir, Killer B Motorsport Dual Washer/Coolant Reservoir, Killer B Motorsport Radiator, Killer B Motorsport Radiator Shroud and Alternator Cover, and Killer B Motorsport Delrin Shift Knob.
Boost plot with previous GTX3067-R in place on stock block.
Pump 93
E85
Testing observations... TMIC was well beyond it's capabilities with temps out the TMIC +175. This somewhat hindered high RPM performance at temps ran up during pulls and timing was pulled by the ECU.
Feel free to post questions, comments, etc.
Teaser of things to come...
Just to keep things interesting... Something we're working on, Garrett G-Series Spoolinator.
Old 04-21-2014, 09:59 AM   #2
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Price and release date!
Also, when you say OEM location, what parts would this kit include, and what can be reused from an existing car?
Old 04-21-2014, 10:46 AM   #3
fobiawrx
Member#: 91074
04 sti
white
that's a smart flange design! i like it!
fobiawrx is offline   Reply With Quote
Old 04-21-2014, 10:48 AM   #4
besthaticouldo
Member#: 279660
Can we see the finished product in the car?
besthaticouldo is offline   Reply With Quote
Old 04-21-2014, 12:01 PM   #5
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Love the location of the TQ and HP peaks.
sweet setup
Breezio is offline   Reply With Quote
Old 04-21-2014, 12:05 PM   #6
Griever423
Member#: 118749
2013 BRZ
Beautiful guys. Just beautiful. Now buy a BRZ and make a turbo kit for it too and I'm sold!
Griever423 is offline   Reply With Quote
Old 04-21-2014, 01:21 PM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Is this a bolt on adapter that allows the v-band housing to attach to the OEM Subaru style uppipe flange? Or does this require permanent modification to the turbine housing (ie. you weld on the new flange)? Are you going to be making a downpipe that pairs with it?
Old 04-21-2014, 01:50 PM   #8
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
rotate that EWG flange so it's compatible with RHD subarus and you'll definitely have an extremely popular kit.
ohemgeeitsNiko is offline   Reply With Quote
Old 04-21-2014, 01:52 PM   #9
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Very neat set up!!! Im loving the powerband.
Old 04-21-2014, 02:06 PM   #10
rjp4419
Member#: 292796
2021 F250
I would definitely be interested in buying this.
rjp4419 is offline   Reply With Quote
Old 04-21-2014, 02:07 PM   #11
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Those are some very nice numbers and powerband figures for 93 can wait to see this set up on some corn
st205wrx is offline   Reply With Quote
Old 04-21-2014, 03:32 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No release date yet, but ~$1,728 with everything to run a GTX turbo.
Thanks! It sure did take some thinking!!
here ya go. Not much to see here folks, it's stock I swear!
sweet setup
Thanks. It's a blast to drive EXTREMELY responsive.
Thanks!... You're not the first to ask us that one!
Correct. The kit is a bolt-on to v-band housing adapter, downpipe and all the anxilliary pieces to run the GTX turbocharger (oil feed, drain, etc.).
The compressor housing needs to be cut down a bit (which we can do) and it does require a 3" turbo inlet.
Send is a RHD car and we'll see what we can do about that
Thanks. We are too!
Thanks and stay tuned!
Thank you. I know a certain someone that is considering a 3076 on E-85 with a ~500whp in mind. We'll see!
Old 04-21-2014, 04:26 PM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Sounds nice. But why not just offer your header with the uppipe v-band flanged instead? Using two matching flanges seems like a better/easier idea than two non-matching flanges with an adapter.
The only reason this adapter makes sense is if you wanted people to be able to use it with a kit other than yours. And why would you want that?
Old 04-21-2014, 04:50 PM   #14
NA STI
Member#: 285083
2006 STi
WOW that curve just looks unreal... I was waiting for someone to test out a gtx3067. Also looking forward to seeing results of stock tmic vs ets tmic as well.
I have a rotated vband kit, EL header, gtx2867/Tial .64 vband housing setup with ets tmic on a 06 STi, makes for a super fun car that will start making boost instantly at any rpm in any gear when needed Car rolls too, trapped 126mph.
Id love to snag one of your killer B upper turbo coolant tanks as well, just cant see spending 275$ for it You guys should do a group buy on those things and advertize them a little better, I never even knew about them until now, they look and are deisgned very good thoe... Keep up the work, you guys been setting the bar very high in the subie game.
NA STI is offline   Reply With Quote
Old 04-21-2014, 04:50 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Because the has lots more versatility if the setup is parted out or changed.
For those that have made incremental mod upgrades and are at the point of upgrading the turbo next, this eliminates having to get rid of parts you've already bought. Lower cost alternative to rotated and better performing than OEM location housings. I don't mind that it plays well with other's stuff
Old 04-21-2014, 04:54 PM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Garrett twisted my arm some on this one. I'm glad they did. Nearly the same performance we were seeing from the GTX3071, but with better spool and transient response. Full boost under 3,000RPMs is terrifically fun!
Thanks for the kind words!
Old 04-21-2014, 05:03 PM   #17
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Looks fantastic. Now I know why the Legacy TMIC has been slow to come out Set-ups with early power are just more fun to daily drive.
I swear by a turbo blanket. Heat coat all you want but it still falls short of a coat. Will be neat to see what a good TMIC can add.
tazswing is offline   Reply With Quote
Old 04-21-2014, 05:25 PM   #18
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's not the direction you went in only offering a header/uppipe v-band connection, but I do understand what you're saying. Does that mean this adapter is coming in at a much lower cost than a new uppipe (with v-band flange) would cost?
If I already had your header (and I was dead set on a non-rotated 30R with Tial v-band housing) and I had the choice between an adapter or buying a new uppipe with v-band, I would go for the new uppipe.
Looks cool. Just seems like it fills a very, very small corner of the market.
Old 04-21-2014, 05:47 PM   #19
NA STI
Member#: 285083
2006 STi
Yeah sounds like a fun setup. Alot of people also dont realize the 60mm-67mm gtx comp wheels also only have 10 full blades vs 11 full blades on the 71mm+ gtx wheels. 4mm smaller ontop of 1 less full blade on the gtx3067 vs gtx3071 should be alot lighter and alot easier to torque.
Old 04-21-2014, 06:49 PM   #20
Mad Ra88it
Member#: 113563
98 Unicorn
When and where do you want the RHD car?
Mad Ra88it is offline   Reply With Quote
Old 04-21-2014, 07:20 PM   #21
Bru1212
Member#: 178770
06 STi
17 Fozz
I WAS dead set on a EFR6758, but this has my attention.
Bru1212 is offline   Reply With Quote
Old 04-21-2014, 09:48 PM   #22
Ilovecugars
Member#: 299442
2005 Forester XT
I never understood why when bigger stock location turbos first started coming out why they didn't go with a design like this, whether it be an adaptor or just a new up pipe. To be able to get away from the pain in the ass stock style flanges and go to v band makes so much more sence.
Ilovecugars is offline   Reply With Quote
Old 04-21-2014, 09:59 PM   #23
reid-o
Member#: 103631
2004 STI
Gray
Nice design
How does it do with the 82?
Old 04-21-2014, 10:01 PM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Definitely more fun to drive daily! Negotiating traffic is effortless.
The housing is Swain Tech Coated so putting a blanket on isn't a great idea, but I do like them too. We'll be posting an update once we get the larger TMIC and back on the dyno.
Hadn't thought of offering the up-pipe adapter separately, since it requires the V-Band down-pipe to go with it.
If you already had an up-pipe, why would you want to buy another one?
Anyone with an EWG up-pipe can run this kit. I don't think that's a very small corner of the market. Almost half the headers we sell are sold with the EWG option.
Correct. The 3067 is 'special' in that the compressor wheel is a bit different. It actually has better aero than the larger compressor wheels. This setup is VERY VERY responsive.
PM me when you get a chance.
There are definitely benefit to the Tial housing
Old 04-22-2014, 07:50 AM   #25
Bru1212
Member#: 178770
06 STi
17 Fozz
So if people buy this when they do eventually want more power what are our upgrade options? Just switch hotsides or? Example : If I get the EFR 6758 and want more I can just swap in an EFR7163 with no other fuss.
