Welcome to the North American Subaru Impreza Owners Club Thursday December 14, 2017
Old 12-19-2013, 05:25 PM   #76
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
Car: 2006 Subaru wrx
Tuner: Andrei Mitine
Dyno Info: Dynojet
Transmission: PPG 5-Speed Dogbox
Gear: 4th
Peak HP at RPM: 570whp
Peak Torque at RPM: 486ftlb
Target Boost: Spike to 26psi then down to 23psi
Target AFR: 12.0
Fuel: E85
Engine/Power Modifications:
Built 2.5L (Stock sleeves)
Crower AVCS 272 cams
Custom Roated Kit
Precision JB 6262 .82 A/R
Tial 44mm
AP Equal Length Header
'07 N/A Impreza Intake Manifold
Five0 Motorsports 1400cc Inj
FMIC
Merp's SD Patch
We were pretty impressed by the car making 570whp on only 23psi! We were having a problem with the car not holding boost. I have since fixed the issue but haven't got back on the dyno yet.
banshee04 is offline   Reply With Quote
Old 12-19-2013, 11:47 PM   #77
bjohnson_55
Member#: 216580
.82 A/R?
Spooling late but making good power.
bjohnson_55 is offline   Reply With Quote
Old 12-20-2013, 01:10 AM   #78
banshee04
Member#: 179014
'06 WRX/STi
Originally Posted by bjohnson_55 View Post
.82 A/R?
Yes, .82 A/R. It shows to spool a bit faster on the street from what the logs say.
Old 12-21-2013, 03:22 PM   #79
bjohnson_55
Member#: 216580
Still should make pk tq around 5k with that exh housing.
Old 12-23-2013, 12:37 AM   #80
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Pull was started rather late?
Any more 5858 or 5862 cars?
Old 12-25-2013, 05:04 PM   #81
bjohnson_55
Member#: 216580
I just noticed its an old jb 6262.
Old 02-26-2014, 09:08 PM   #82
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
6466 29psi KillerB rotated setup
20psi by 41-4200rpm on e85 4th gear
2012 STI stock wheels and tires
Old 02-26-2014, 09:20 PM   #83
Nemesis_STI
Member#: 325545
2006 STI
Left or right lane? (Hoping right!)
Nemesis_STI is offline   Reply With Quote
Old 02-26-2014, 09:24 PM   #84
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
LOL.. Yea the faster side.. I should clarify that
Old 02-27-2014, 01:00 PM   #85
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Added it to the list.
Old 02-27-2014, 01:58 PM   #86
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Is this the fog light kit?
Old 02-27-2014, 02:24 PM   #87
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I think that's called the low-mount setup. The rotated setup is just a different up-pipe with no flanges welded on it. It comes with a manifold to up-pipe flange and you supply your own up-pipe to turbo flange and then orient it however you need to and weld on the flanges.
WRXt4cy is offline   Reply With Quote
Old 02-28-2014, 10:51 AM   #88
Jcfabworks
Member#: 368772
In order to be added to the list or claim a time you have to not only run it but back it up no?
Jcfabworks is offline   Reply With Quote
Old 03-08-2014, 07:31 AM   #89
onurba32
Member#: 203150
1996 gf8
red
I am newprecisionturbouser
I am not install my 5858 jb yet
However I am in trouble to use oil restrictor or not
My oil pressure when cold start @idle 110psi when It is hot 80 90 psi @ high rev
Journal bearing pte turbos need .065" oil restrictor on subaru?
Some of audi owners have some problems with high oil pressure on jb pte turbos
onurba32 is offline   Reply With Quote
Old 03-24-2014, 12:11 PM   #90
banshee04
Member#: 179014
'06 WRX/STi
Precision 6262, 26psi, E85, NT555 245/45/17
Old 03-24-2014, 02:24 PM   #91
bjohnson_55
Member#: 216580
Street tires?
Old 03-24-2014, 03:30 PM   #92
banshee04
Member#: 179014
'06 WRX/STi
Street tires?
I just edited that into my last post.
But yes, it was on street tires. They are NT555 245/45/17 (26in Tall)
Old 03-25-2014, 10:15 AM   #93
Jcfabworks
Member#: 368772
Originally Posted by onurba32 View Post
I am newprecisionturbouser I am not install my 5858 jb yet However I am in trouble to use oil restrictor or not My oil pressure when cold start @idle 110psi when It is hot 80 90 psi @ high rev Journal bearing pte turbos need .065" oil restrictor on subaru? Some of audi owners have some problems with high oil pressure on jb pte turbos
Vibrant makes a 1/8"not to -4 restrictors that you can use to help the life of the leaky turbos.
Old 05-07-2014, 06:24 AM   #94
onurba32
Member#: 203150
1996 gf8
red
Car: 1996 impreza gf8 turbo
ej20 with forged internals
std v4 sti heads with ppr portpolish
wrc intake manifold
pte 5858 82ar jb
91 octane
with water/meth injection
18psi
Mustang dyno
rev 7500rpm
Old 07-07-2014, 04:46 PM   #95
Bansheeboy11
Member#: 182415
1999 RS
Holy lag batman!
Bansheeboy11 is offline   Reply With Quote
Old 07-08-2014, 09:13 AM   #96
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Originally Posted by Bansheeboy11 View Post
Holy lag batman!
It's a 2.0 Boy Wonder.
Old 07-08-2014, 09:35 AM   #97
Bansheeboy11
Member#: 182415
1999 RS
No $hit sherlock. I can read just so you know, i dont want you to go out of your way to help me, im a big boy i got this.
Old 07-08-2014, 10:15 AM   #98
2000subie
Member#: 207638
2004 WRX
Yellow
He is right in that it spools super late. That's a lot of power band to give up for that little of power. I spooled a 3076 that fast with 282/278 cams and everything ported. I also made 450whp on the boost creep dyno and 516whp virtual dyno and pulled it out to 8200rpm.
2000subie is offline   Reply With Quote
Old 07-08-2014, 10:32 AM   #99
Bansheeboy11
Member#: 182415
1999 RS
Yeh thats really laggy, even for an EJ20. I know its 91 and 20G's arent the best at making power but your talking that thing not even getting into power until almost 4500ish, with meth?
Old 07-08-2014, 11:40 AM   #100
maperformance
Member#: 141043
2015 WRX
2013 Subaru BRZ
MAP turbo kit
PTE 5858
E85 17psi
Stock block
maperformance is offline   Reply With Quote
