Welcome to the North American Subaru Impreza Owners Club Monday August 10, 2020
Old 07-17-2014, 02:29 PM   #801
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by 2011rex18 View Post
320whp 376lbs at 21.5 psi stock plugs I believe are .32gap
Sent from my iPhone using NASIOC
For that type of setup the stock plugs should work great. Could gap them down a little if you'd like. I believe the OEM spec is like 0.028-0.031" and you could go to the bottom of that range.
Originally Posted by juanmedina View Post
It seems like something for the speedo ...
Hmmmm....
Old 07-17-2014, 11:58 PM   #802
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I did the DIY $10 Remote Oil Pressure Sender mod today. FYI - This is needed with the normal ProSport oil pressure sender, due to its large size (hits the alternator). The Defi and ProSport Premium sensors are much smaller and can be bolted right into the galley plug without any issues. I'm not sure about other brands/models. Also keep in mind that some brands are NPT and some are metric. ProSport is NPT, so it is easy to find hardware that fits.
Prior to that I was running two 90 deg fittings to allow the ProSport pressure sender to clear the alternator. This was OK, except it wasn't screwed in real tight due to the necessity to be able to "clock" it for proper alternator clearance. Eventually it developed a small leak and it didn't seem like it was going to get any better, so I went for the remote install mod.
Here's a shot of the "before" setup:
I bought the parts from Home Depot. Online they show a 12" hose for $5, but in the store they only had the 18" hose that costs $9.62. The 1/8" straight coupler was $2.65 so the total with tax came out to be just over $10. If you order parts online, or go to Harbor Freight, you could probably do this for close to $5. I would keep in mind where you want to mount the sender, I think 18" is actually just about perfect.
Here's a shot of the parts:
First step is to remove the grease gun adapter from the end. It appears to be held on with red Loctite, but I got it off with just normal wrenches and no heat.
Here's a photo with it off:
Then just screw all the parts together. This is a mock up. I ended up deciding to put the strain relief spring on the end that goes into the galley plug and into the block. I figured there was more chance for stress there since it was hard mounted. I don't think it really matters though.
Here's a shot of it going into the block:
I ran it behind the alternator and zip tied it to the alternator wire's loom.
So far so good. Seems to be a great solution and much cheaper than the kits they sell. And waaay better than the two 90 deg fittings that I was using before.
Old 07-18-2014, 03:17 PM   #803
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 07-19-2014, 06:30 AM   #804
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
I did the same set up for the oil gauge, do you think it's less accurate than when you had it much closer? I've only had it set up this way and some days I feel the readings are fluctuating and some days they aren't. I know it's a prosport gauge and "you get what you pay for" but how's your experience with it?
thatsilverwrx is offline   Reply With Quote
Old 07-19-2014, 08:08 AM   #805
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No, it should not be any less accurate. It is just measuring pressure so flow is not really important. Some actually prefer this type of mounting because it dampens vibration and reduces the chance of sensor damage or the housing cracking. ProSport are usually fine. Until they just so working. Luckily mine havent gotten to that point yet.
Old 07-22-2014, 11:57 AM   #806
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
FYI - The website has now been updated with the full info on the VSS.
Link to Website:
http://mapdccd.com/vss.html
Link to Manual:
http://mapdccd.com/media/MapDCCD_whe...tall_guide.pdf
Old 07-24-2014, 08:59 AM   #807
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Did a few small things last night:
  • Installed Lower Radio Storage Slot (Upper Still Empty)
  • Removed BPV Hose (Plugged) and Installed 1.25" Cap on Inlet Port
  • Removed Front and Rear Door Speakers (No Radio Installed)
  • DIY LIcense Plate Relocation (Screwed to Fog Light Cover)
  • Filled Up on E85 (Currently $2.34/Gallon)
Old 07-24-2014, 11:20 AM   #808
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
that license plate location though...
Old 07-24-2014, 11:21 AM   #809
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What is wrong with that location?
Old 07-24-2014, 11:36 AM   #810
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
damn 2.34!!!! ugh! very jealous
SenorDucK is offline   Reply With Quote
Old 07-24-2014, 12:24 PM   #811
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Isn't that pretty much normal?
Old 07-24-2014, 12:49 PM   #812
besthaticouldo
Member#: 279660
No, I think its like 3.18 here.
besthaticouldo is offline   Reply With Quote
Old 07-24-2014, 01:56 PM   #813
2011rex18
Member#: 321728
2011 WRX Limited
Yes 3.19 I paid last
2011rex18 is offline   Reply With Quote
Old 07-24-2014, 02:07 PM   #814
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Whoah. That adds up to over $10,000 per year more than what I pay!
If you drive 200,000 miles a year.
Old 07-24-2014, 02:29 PM   #815
xsv141
Member#: 231904
2007 WRX
UGM
lowest its been in colorado is $2.89 so thats pretty good
xsv141 is offline   Reply With Quote
Old 07-24-2014, 10:33 PM   #816
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
A few new shots of my car:
Old 07-25-2014, 06:37 AM   #817
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
E85 here in the North East is $355 and really is only E75
Android287 is offline   Reply With Quote
Old 07-25-2014, 08:51 AM   #818
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
$355/gal is pretty high. I don't think I'd pay that.
Old 07-25-2014, 09:32 AM   #819
2011rex18
Member#: 321728
2011 WRX Limited
I would pay that still better than 412 or higher for 93
Old 07-25-2014, 09:38 AM   #820
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
It may not be better with the drop in mpg.
Old 07-25-2014, 09:49 AM   #821
2011rex18
Member#: 321728
2011 WRX Limited
I don't always boost light to light so I don't see this big drop in mpg that everyone else talks about as far as the access port is concerned(not sure how accurate the numbers are) the difference for me between e85 and 93 just driving the way I do everyday is only about 2mpg I'll deal with it
Old 07-25-2014, 10:12 AM   #822
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
E85 is a far better deal than race gas (which produces similar power). Comparing to an inferior fuel like normal 93 octane pump gas doesn't make sense.
I'd gladly pay $4, $5, $6+ per gallon for E85 because the performance is so much better. I wouldn't pay $355 per gallon though. That is insane.
Old 07-25-2014, 10:24 AM   #823
Wirtz
Member#: 286408
WFC #952
Function:error!
E85 is great too depending on how you drive. Mine is a highway cruiser so I get good gas mileage (18-20) and range gas is $1.50 cheaper on average. Ben I'll be at C&C next weekend but staying on E coming from WI just because I'd rather run that than switch to my 91 map lol.
The gas mileage is with the 95whp/135ft-lb for my car lol
Wirtz is offline   Reply With Quote
Old 07-25-2014, 10:28 AM   #824
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I drove my 2011 WRX from Minneapolis to Chicago and back last year. It was 30psi, 600WHP, E85 tune the whole time. I think mileage was around 18MPG.
Old 07-25-2014, 10:41 AM   #825
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Incredible build.
Just my thoughts, but you should throw the stock wheels back on and paint that front mount black. Would look even more stealth. Too bad you couldn't delete the front plate too and maybe shave that part off the bumper.
Subscribed!
Bak3rSkat3r is offline   Reply With Quote
