Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 06-08-2014, 07:39 PM   #651
alucardm911
Member#: 393067
dont have a pic atm. 2005 sti
295 hp 330 tq
16g and downpipe back exhaust
alucardm911 is offline   Reply With Quote
Old 06-09-2014, 12:47 AM   #652
dmacnz
Member#: 330289
1995 GC8
Type of Dyno: Virtual Dyno
Baseline # for a stocker at the dyno: around 170
Boost: 20psi
Fuel: 96 Octane
Target AFR: 11.2
SAE Corrections: SAE
Peak HP at RPM: [email protected]
Peak Torque at RPM: 340 @ 5100
Mods:EJ20G Forged build, V4 STI heads, TD05-20G Billet, 750cc injectors, 3 Bar map sensor, ESL
dmacnz is offline   Reply With Quote
Old 06-09-2014, 09:51 PM   #653
Jonesy35615
Member#: 353367
2006 Impreza WRX
TP Tuned 255whp/295wtq
Default 2006 WRX Limited Stage One TP Tune
2006 WRX Limited
Torqued Performance Custom Stage 1
93 Octane, 16.5lbs Boost Target
SPT sri
Kompact BPV
Grimmspeed TMIC
Custom 2 1/2 inch catback
Jonesy35615 is offline   Reply With Quote
Old 06-10-2014, 06:37 PM   #654
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Mo's 2012 Wrx in Pearl White
Mods @ Time Of Dyno:
Cobb 2" Up Pipe
Cobb 3" Catted Down Pipe
Cobb Intake
QTP Cutout
Stage II Snow Performance Meth Injection
Cobb Crank Pulley
Cobb BoV
Stage II Map @ 18psi
307/351 on 93 Octane
No Limit Motorsport is offline   Reply With Quote
Old 06-27-2014, 07:28 PM   #655
WrX509
Member#: 393349
good stuff
WrX509 is offline   Reply With Quote
Old 07-17-2014, 09:00 PM   #656
guzie
Member#: 380573
Default Post your Dyno Plot and Mods, see format inside.
2015 wrx sti.
Stock engine
Ecutek
Visconti tuning stage 1 canned tune
93 octane
S setting 17 psi dyno pull. I forgot to switch it to S# for the 20 psi before running. 297hp/ 297 tq. Baseline was 262hp/ 254tq. Should have broke 300 with the S#. Love the tune. Visconti tune is top notch. No knock events very clean datalog.
http://instagram.com/p/qkkEeVpnnK/
guzie is offline   Reply With Quote
Old 07-18-2014, 02:05 AM   #657
ckbeep
Member#: 350233
2006 WRX
Tttttt
ckbeep is offline   Reply With Quote
Old 07-20-2014, 12:42 PM   #658
Dshorty15
Member#: 369946
Default 2008 wrx 243whp/306wtq
Facility: EStuned (Tucson, AZ)
Type of Dyno: Mustang
Baseline: 226/224 crank hp/tq ~ 188/187 wheel hp/tq
Boost: 17lbs
Fuel: AZ91 octane
Target AFR: 14.4
SAE Corrections:? (about 2500 ft elev)
Peak HP at RPM: 243whp @ 3400RPM
Peak Torque at RPM: 306whp @ 5200RPM
Mods: Cobb AP
Invidia Q300 CBE
Invidia downpipe and uppipe*
Cobb CAI and airbox
Grimmspeed EBCS
Fuel pump
Kartboy short shifter and bushings
*This was a tune for the uppipe install only. Interesting numbers: the uppipe contributed to a 7whp gain and a 32wtq gain!
Dshorty15 is offline   Reply With Quote
Old 07-23-2014, 06:36 PM   #659
N-Bomb
Member#: 309465
1999 GC + ver 9 swap
Silverish
Car: Ver 9 EJ207 twinscroll-swapped GC
Facility: Neetronics (Toronto, ON)
Type of Dyno: Dynojet?
Peak boost:22 PSI
Fuel: Ultra 94
Target AFR: 11.5ish
Peak HP: 268whp @ 5630RPM
Peak Torque: 305lbft @ 3820RPM
Power mods: Perrin inlet, Grimmspeed EBCS, turbo blanket, Lachute catted DP, H&S axleback
Er... the red lines were the previous tune straight after the swap (stock dp, no blanket, stock BCS)
Planned: 2.2L stroked, carbon driveshaft, upgraded turbo MAYBE.
N-Bomb is offline   Reply With Quote
Old 07-23-2014, 07:17 PM   #660
Jhead016
Member#: 373688
14 EVO GSR
Wicked White
2008 STI
Rebuilt, Stock.
Mods: K&N Panel Filter, Grimspeed EBCS, ZeroLift TGVs, Cobb DP, Magnaflow Catback, Tomei Equal Length, Injector Dynamics 1000cc, 1 step colder plugs.
Mustang Dyno.
Peak boost was 15 psi
Max HP 280WHP
Max lbft 308WTQ
Jhead016 is offline   Reply With Quote
Old 07-26-2014, 01:31 PM   #661
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
479 WHP / 483 WTQ
Motor
BPV: Forge Motorsport FMDVSUB03 alloy recirculating valve
Inlet: Perrin turbo inlet
DCCD: DCCDPro active center differential control
Turbo: Blouch Dominator 2.5XT-R (heat shield ceramic coated)
Clutch: Exedy Stage 4 Heavy Duty Twin Metallic Disc Clutch Kit
Intake: SpeedFactory Racing Custom fabricated CAI intake
Uppipe: GrimmSpeed External Waste Gate (EGW)
Pistons: JE EJ257 FSR 2618 T6 high tensile forged aluminum pistons
Exhaust: Invidia Q300 catless exhaust (with custom Flowmaster mufflers that are Plasti-dipped black, since the Invidia mufflers kept rusting out)
Headers: Agency Power Equal Length
Flywheel: Comes with the Exedy clutch kit
Downpipe: 3" Invidia (ceramic coated)
Injectors: Injector Dynamics ID1300s, balanced and flow tested
Fuel Pump: Walbro 460 LPH with modified fuel sock (FXT fuel pump controller bypassed)
Intercooler: SpeedFactory Racing Custom fabricated Front Mount with 4" Extreme Turbo Systems (ETS) core
Spark plugs: Denso iridium
Access Port: COBB Access Port, V2 – SUB - 003
Map Sensor: AEM 3.5 Bar Map Sensor with COBB adapter
TGV Deletes: Composite TGV Deletes
Transmission: '11 STI 6 speed
Boost Control: AEM Electronic Boost Controller
Fuel Regulator: Cobb Subaru 08-14 STI Fuel Pressure Regulator Kit
Air Pump Deletes: KS composite Tech air pump deletes with Phenolic Thermal Intake Spacers
Crankshaft pulley: GrimmSpeed lightweight crankshaft pulley
eugeneutopia is offline   Reply With Quote
Old 07-26-2014, 01:39 PM   #662
guzie
Member#: 380573
Originally Posted by eugeneutopia View Post
491 WHP / 483 WTQ
Motor
Access Port: COBB Access Port, V2 SUB - 003
Nice power but your plot says 479 not 491.
Old 07-26-2014, 01:47 PM   #663
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Oh S*. Wishful thinking. Opps
When I was writing it up U had full numbers (EX: 479.1) and I left the "." and the "7" out in my editing.
Thanks!
Old 07-26-2014, 02:24 PM   #664
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
479 WHP / 483 WTQ
Motor
what fuel was used? Who tuned it?...MPS?
Seems to spool alil late. I have a twin scroll 2.5xtr on my 2.0l and mine spools within a couple hundred rpms of this
Old 07-26-2014, 02:30 PM   #665
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
This is Mikey's tune (PIA). It's E85. The front mount has a lot to do with the delayed spool.
Old 07-26-2014, 04:42 PM   #666
Paul
Member#: 56203
00 RSTI Coupe
I'm rocking a fmic also but the core isn't huge and the counter clockwise piping is on the smaller size.
Awesome numbers tho!! I hope to get close to that with my E85 tune
Old 08-14-2014, 09:10 PM   #667
DamonFlynn33
Member#: 370089
05 Legacy GT
Default 302hp Legacy GT, 310tq
Facility: BrennTuning 8/11/14 85 degrees
Type of Dyno:Mustang
Boost: 17.8lbs
Fuel:93 Octane Summer blend
Target AFR:
SAE Corrections:
Peak HP at RPM: 302
Peak Torque at RPM: 310
Mods:EVO 16g, DW850 inj, Borla Exh, Megan Up/down pipe, Walbro 255, Perrin Intake, Fast Motorsports FMIC
DamonFlynn33 is offline   Reply With Quote
Old 08-22-2014, 09:09 PM   #668
v_khotsky
Member#: 303995
2012 Impreza STI
2006 Yamaha YZF-R1
Default 2012 Sti
http://s18.postimg.org/a1itoln09/20140822_195619.jpg
cp pistons ,
manley h-beam rods ,
crosworth bearings and head gaskets,
apr studs,
high volume oil pump.
invidia tbe
tomei elh
tomei fpr
1000cc ID injectors
355 AEM fuel pump
stock fuel rail
methanol injection (480cc nozzle)
AEM CAI , stock inlet
TGV delete
Dom 3.0xtr 8cm hotside
Stock TMIC
Competition clutch (stage 3) - do not buy for daily driving )
Next in line - FMIC w rotated intake , oil cooler in tmic location , aluminum radiator.
v_khotsky is offline   Reply With Quote
Old 08-22-2014, 09:34 PM   #669
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Facility: Racing Greed
Baseline # for a stocker at the dyno: ~120whp
Boost: 8psi peak
Fuel: Chevron 94
Target AFR: 11.5:1
SAE Corrections: don't think so
Peak HP at RPM: 174hp @ 5300rpm
Peak Torque at RPM: 204ft-lbs @ 3600rpm
Mods:
-ej257 stock block with stock ej251 SOHC heads with sti HG
-AVO320 turbo kit (GT2560R garrett turbo with 4psi WG) with top mount intercooler
-Greddy emanage ultimate piggyback tuned poorly by myself
-Greddy profec b spec2 boost controller
-TWE long tube EL header
-wrx 440cc injectors
-walbro fuel pump
-Cobb 2.5rs "catback", no cats
More on the way...
Zefy is offline   Reply With Quote
Old 08-27-2014, 02:19 PM   #670
dwhjr
Member#: 345890
2013 WRX
2013 WRX Hatch
Facility: Mach V Motorsports
Boost: ?
Fuel: 93
Peak HP: 284
Peak Torque at RPM: 331
Mods:
Nameless Performance Cold Air Intake
Tomei UEL headers
Tomei Uppipe
Nvidia Catted Downpipe
Nameless Performance mid-pipe and axle back
dwhjr is offline   Reply With Quote
Old 09-09-2014, 05:39 PM   #671
Springs
Member#: 401180
Nice nice
Springs is offline   Reply With Quote
Old 09-17-2014, 04:11 PM   #672
06rexLTD
Member#: 281793
2004 STi
Facility: iAG Performance
Type of Dyno: Dynojet 424
Vehicle: 2004 STi
Baseline # for a stocker at the dyno: unknown 240-250ish hp/tq ?
Boost:~24psi
Fuel: 93oct Sunoco
Target AFR:11.5 (guess?)
SAE Corrections: Uncorrected
Peak HP at RPM: 400 @ 6500ish
Peak Torque at RPM: 364 @ 4600ish
Elevation: about sea level
Temp: mid 70s , mid-low humidity
Mods:
04 STi 6spd drivetrain (stock)
06 WRX EJ255 - Stock D25 heads / Artie @ iAG built shortblock 8.2:1 comp.
Manley Forged pistons, Manley Rods, FHI updated nitrated crank
ACL coated bearings
Headstuds, block bolts, case bolts etc
SPT motor mounts, trans mount, pitchstop
iAG Airpump Delete
iAG Billet Half moons
PCV Delete (and all other evap stuff deleted(emissions))
KillerB Oil Pickup
Grimspeed ported headers with Highflow X-pipe
FobiaFab Rotated Uppipe (2-bolt ~ vband)
FobiaFab EWG dump tube (vband)
FobiaFab Rotated Downpipe (vband)
Tial 38mm EWG (vband)
Grimspeed 3port EBCS
Precision 5858 JB .82 vband in/out ex.housing
iAG custom shortram Intake w/ Long Cone filter
Rotated intake manifold
Deleted TGV's (DIY)
Grimspeed 3mm phenolic spacers
Custom 2.5" FMIC piping (aluminum)
Synapse Syncronic Blowoff valve (newer 2port version)
Treadstone TR1045 fmic
Mishimoto 3row Xline Radiator
Mishimoto aluminum fan shroud/fans
Element Tuning Catch Can
Walboro 400lph pump (w. wiring mod to pump & controller)
Fuel Injector Clinic 1100cc topfeed injectors
iAG fuel rails
Aeromotive FPR w/ -8an braided lines
OMNI 4bar map sensor
GM open element intake air temp sensor
CleoTuned APv2 Speed Density
i took a pic of the graph on the screen right before the next pull, on the next pull it misfired on all cylinders (crank pos sensor went bad) so that limited smoothing and i may see a cpl more whp/wtq but this is pretty much where its going to be on 93oct for now. Once the Meth kit is installed, ill come back and edit.
When i go to pick it up, i will also get a cleaner graph for you guys for sure, like i said, i was lucky to even take this picture due to the unforseen crank pos. sensor issue right after i snapped it on the next pull.
cleaner graph as promised & after smoothing ~ (final numbers on 93oct)
06rexLTD is offline   Reply With Quote
Old 09-23-2014, 08:08 PM   #673
Hkssubie25
Member#: 402248
2007 Wrx
Pearl white 401whp 398wtq
Facility: pure tuning Toledo Ohio
Vehicle: 2007 wrx
Baseline for wrx: 190 HP 210 TQ
Boost: 22psi tapering to 19psi
Fuel: 93 octane
Temp: 83 degrees humid
Peak hp at rpm: 401hp @ 5500rpm
Peak tq at rpm: 398tq @ 4947rpm
Mods: top feed fuel kit, air oil seporator, rare HKS prototype ball bearing 8262 turbo, pure stage 2 shortblock 9:1 cp pistons ( gold top with moly sides), manly rods, acl bearings, cosworth head gasket, arp l-19 head studs, spec -b cylinder heads, Ferra complete valvetrain, Brian crower 272 cams, high volume oil pump, smaco radiator hoses, Kevlar timing belt, omni 4 bar map sensor,killer b oil pan, cob oil cap, pure custom front mount with titanium piping, custom intake with titanium piping, tail q blow off valve, hallman Manuel boost controller, tomei 4-1 exhaust manifold & up pipe, Invidia divorced down pipe, Walbro fuel pump, 1000 cc injector dynamic injectors, exedy stage 1 clutch, exedy lightweight flywheel, sti 6 speed, sti driveshaft, r-180 sti rear diff, custom chromolly axles from the driveshaft shop
Hkssubie25 is offline   Reply With Quote
Old 10-02-2014, 09:49 PM   #674
akalawur77
Member#: 355378
Facility: EFI Logics
Type of Dyno: Mustang Dyno
Baseline # for a stocker at the dyno: ~214awhp
Boost: 19.5
Fuel: 93
Target AFR: 11.4:1
Peak HP at RPM: 320awhp @~5600 RPM
Peak Torque at RPM: 360awtq @~4300 RPM
Mods: Cobb intake, Perrin Inlet Hose, RacerX Engineering FMIC kit, IAG TGV Deletes, GrimmSpeed EBCS, GFB BOV, Tomei EL Header, Grimmspeed Uppipe, Tial 38mm EWG, Tsudo Catless Downpipe, QTP Electric Cutout, Nameless Performance Axleback, DW65C Fuel Pump, NGK One Step Colder Plugs, Injector Dynamics 1000cc Injectors, Speed Density Conversion (OmniPower 4 Bar MAP Sensor, AEM IAT)
akalawur77 is offline   Reply With Quote
Old 10-16-2014, 04:55 PM   #675
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
Car: 2004 WRX
Facility: Church Automotive Testing
Type of Dyno: Dynapack
Baseline # for a stocker at the dyno: ~185 whp (guess)
Boost: 14 lbs tapering to 10
Fuel: 91 octane
Target AFR: ?
Peak HP at RPM: 232 @ 5257
Peak Torque at RPM: 279 @ 3125
Mods:
- EJ257 w/ JE pistons
- STi injectors
- STi intercooler
- Walbro fuel pump
- uppipe
- Stromung catback
- (stock TD04, stock WRX heads, stock downpipe)
(before plot is old EJ20 w/ uppipe)
Hagbeard is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-03-2016 12:43 AM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 11:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 03:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 03:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 06:40 PM
