Welcome to the North American Subaru Impreza Owners Club Monday October 21, 2019
Old 12-07-2013, 03:37 PM   #1
elijah.botez
Member#: 365711
2003 Impreza WRX
Black Wagon
Default Jdm Ej205 Into Usdm 03 Wrx?
Hi everyone! I have put a good amount of time in research about my issue here but still didn't find a solid answer.
I have 2003 WRX with all stock ej205. What happened was my turbo decided to go kaboom in the middle of a freeway. After I realized that it might of took out my internals I took the engine apart to see.
Sure enough I had a hole in piston 4. Also looked like it had a cracked camshaft. Basically a full rebuild is needed, which would cost me no less than 2k. On the other hand I've seen some good JDM ej205 engines for about $1k.
Let's say a JDM engine will have AVCS - will I need extra wiring or JDM Ecu to work properly?Or will it work with my USDM Ecu? I've seen people say yes and no so I am kind of confused. I am not considering any big power upgrades, so far I just want to go stock and make sure everything will work like it should. And yes I want to be able to pass emissions. I am a student so my budget for this project is minimal. Please help!
elijah.botez is offline   Reply With Quote
Old 12-07-2013, 03:45 PM   #2
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
To the best of my knowledge, you dont have to hook up avcs, but it certainly wouldnt hurt. Other than that theres only some subtle differences (?), but dont quote me on that.
Im curious about this as well since my 02 wrx jumped timing n hurt my motor prettttyyy badly. Any other thoughts on this??
AlexWRXbruh is offline   Reply With Quote
Old 12-10-2013, 06:50 PM   #3
boostfreak305
Member#: 366515
02 02 wrx
rally blue
all i could say is i got a ej207 and im having a hell of a time to get it to run.. so go with usdm instead of a jdm cause u might find a cheaper motor around and wont have the issues im running with now
boostfreak305 is offline   Reply With Quote
Old 12-13-2013, 09:49 AM   #4
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Yeh, you went to a v5 engine on an 02 wrx, completely different electronics platform. No wonder you can't make it work.
Op, a Jdm ej205 with avcs will run with your usdm ecu but you will not have functional avcs. You will need the correct Jdm ecu and additional wiring to make the avcs functional.
D-Rodman is offline   Reply With Quote
Old 01-01-2014, 06:47 PM   #5
JoshP
Member#: 94350
Where are these JDM EJ205s for 1k?? Just rebuild yours and you will have a better engine. Or just rebuild the heads and get a low mile shortblock.
JoshP is offline   Reply With Quote
Old 01-02-2014, 04:41 PM   #6
snake32
Member#: 167338
11 Wrx hatch
Dgm
never heard that is hard to have a V5 ej207 run on the 02-05wrx, from what i can see is just matter of switch cam gears, cam and cranck sensor, reuse the whole intake manifold from the wrx and it should be ready to go. isn't this all it needs?
snake32 is offline   Reply With Quote
Old 01-16-2014, 06:11 PM   #7
johnnieski
Member#: 150125
2003 WRX wagon
Red
Default 2003 WRX USDM engine blown, replace with JDM EJ205?
Bump! And adding my questions. I've read a lot of the JDM swap threads, and there is tons of contradicting information even when discussing this somewhat "like-for-like" replacement.
PROBLEM: I have Stock 2003 WRX USDM with a blown motor (no compression in #4) and several other lesser concerns. So I'm considering all options, but in this thread I hope folks can provide straightforward information on an engine replacement to an EJ205 JDM motor. I'm hoping there are folks out there that have completed the swap that can provide insight. I'll return the favor with a clean write up of my experience, once it is all done!
A Subaru tech will do most of the work. He has a bug eye himself but has not done a JDM swap yet.
JDM ENGINE DEALER INSTRUCTIONS/ASSUMPTIONS:
1) It's a fairly straight forward bolt on replacement - (Sure it is )
2) Use USDM wiring harness and ECU
3) Use USDM cam pulley and sprocket (ensures USDM timing is maintained)
4) Use USDM intake manifold (for US emissions) and exhaust manifold.
5) Use USDM accessories (A/C comp, Alternator, P/S pump). Some JDM accessories "may" fit, but best to have your originals on hand.
6) Japanese and US octane levels are NOT different, so no gas difference concerns or tuning concerns.
7) Tune is a good idea, but not required
8) JDM and USDM compression ratios are both 8:1, so no issue (Some NASIOC/WRXtuner folks claim JDM is 9:1)
9) Good idea to replace gaskets/seals (OEM complete kit ~$200)
MY QUESTIONS:
1) Are any of these assumptions misleading?
2) I'm not interested in AVCS b/c of the added complexity and possible issues, do I need a to ensure I have a non-AVCS EJ205 for simplest installation, or will an AVCS EJ205 be okay?
3)Are there any other major problems that we will come across?
4) Are there any other customization or USDM parts that I will need from my car?
5)Are there any defining characteristics on the JDM motor that will help ensure the simplest replacement. (non-AVCS, parts to make sure come with motor, etc)
Essentially, I'm looking for a clean-ish engine replacement experience with the end result being a reliable daily driver for 2-3 years (hopefully longer). I want to avoid getting bogged down with fabrications or hunting down hard to find (JDM) parts with no warning.
Thanks for any insight you can provide through your experience! Again, I'll post a clean/detailed write up once we are done with the project for folks that are looking to do the same in the future. I haven't been able to find one yet, and will all the aging EJ205 motors out there, this may become an increasingly relevant topic.
Eat, Sleep, Turbo!
2003 WRX mostly stock with Perrin uppipe, Mishimoto radiator
johnnieski is offline   Reply With Quote
Old 01-16-2014, 06:32 PM   #8
ToneWrx02
Member#: 239095
2002 Wrx
If its the right ej205 then all you need is to swap it in.
I didnt even change my cams or intake manifold.
I was told the engine harness but after looking at it. They are both the same. Only dofference is avcs wires added.
Just get a tune.
People say if u dont change the cams you will lose abit of power but my tune says other wise.
ToneWrx02 is offline   Reply With Quote
Old 01-16-2014, 06:48 PM   #9
johnnieski
Member#: 150125
2003 WRX wagon
Red
Default Thanks Tone!!!!
Thanks so much for the reply Tone, and glad to hear! Hope your car is still running strong! I hope I can PM you with follow ups, but if it is as straightforward as advertised I'll just send you the "Done!" message!
Old 01-16-2014, 10:04 PM   #10
ToneWrx02
Member#: 239095
2002 Wrx
Yep! Il can email you my airboy if you like.
It really is straight forward. The ej205 v7 has small differences. For example some vac lines are missing near the turbo inlet. Thw intake manifold on us vwrsion has a little plug sticking out from it. The jdm version jusy plugged it. I like it as it looks cleaner.
The turbo is a different version. Td04 hl 15t.
Heads flow abit more.
Just unpluged the clips to the avcs it will leave values at 0.
If you ever want to run avcs you just need the jdm ecu and iac bulk kit.
Like i said before avcs cames will work.
Supposebly if you dont plug them you lose abit of power but im making more power then a usdm version is making with my mods so eh.
Old 01-17-2014, 09:37 AM   #11
johnnieski
Member#: 150125
2003 WRX wagon
Red
Default Bump - JDM EJ205 replacement into a stock 2003 USDM WRX
Bump, Any other folks with tales of caution or words of wisdom before I start ordering parts and the engine? Anyone have a preferred JDM engine vendor? Thanks again to all that have helped!!!
Old 02-21-2014, 06:23 PM   #12
03slowrx
Member#: 382277
I'd also like to know any words of advice on this... I'm getting ready to swap mine over.
03slowrx is offline   Reply With Quote
Old 03-01-2014, 12:14 AM   #13
Nudnik
Member#: 284947
2002 WRX Wagon
Bump. I'm in the need for a good write up on a JDM ej205 swap into a bugeye too. Johnnieski, I'll be looking for your write up.
I've heard a 2005 ej205 will be a plug n play as long as you switch over the cam stuff. You can still use the USDM harness & ECU. I'm hoping its that easy.
Nudnik is offline   Reply With Quote
Old 03-09-2014, 08:51 AM   #14
Ballz2dwallz
Member#: 291305
Bump looking for any updates
Ballz2dwallz is offline   Reply With Quote
Old 03-09-2014, 11:10 AM   #15
JoshP
Member#: 94350
Swap the cam and crank gears, and intake manifold with all electronics on it and that's it. Your ecu can run AVCS with different roms but you would have to do some wiring. There's your good write up.
Old 03-09-2014, 12:12 PM   #16
ToneWrx02
Member#: 239095
2002 Wrx
Dependinh on which jdm ej205 you have you might not even need to swap parts.
My ej205 i got has avc but evrything was exactly the same. Sure i dont have avc wired in but i will soon. Am i losing power because i left the avcs cams in there. Yes quite abit. Do i notice it? No i dont
Old 05-01-2014, 12:11 PM   #17
grindian
Member#: 380954
I picked up a jdm 03 ej205 from an IMPREZA wagon to swap into my 02' USDM WRX... clips were all the same, and used the JDM harness to harvest the AVCS wires... went to start it up...and it turns over, but isnt starting.... throwing only TGV code... anyone experience anything like this before?
grindian is offline   Reply With Quote
Old 06-02-2014, 04:25 PM   #18
stus03
Member#: 363549
Just got a JDM engine for my 03 wrx. I checked the timing pulleys, and as far as I can tell, they are the same... Same tooth count and diameter. Is there any chance I won't have to swap pulleys?
stus03 is offline   Reply With Quote
Old 06-28-2014, 03:45 PM   #19
silver70lt1
Member#: 249650
2015 STI
I have a 2002 wrx that has a spun rod bearing. I am ordering a 2004 jdm engine with ecu, and I will either use the i wire harness extension or I will make an extension to activate the AVCS. I will post my experience.
silver70lt1 is offline   Reply With Quote
Old 07-16-2014, 06:50 PM   #20
SpecR1081
Member#: 363133
07 Sti
Hey all,
I just finished a VF39 setup on my 03 wrx and motor starting knocking after 5 pulls on the dyno during tuning.
Now looking for a cheaper fix than going with a V7 ej207, there is a shop in Montreal that sells jdm ej205's (non-avcs for $1650, with avcs for $1800) so this looks like the route that Ill take.
Have any of you guys finished your swaps and have good results? Works pretty much the same as usdm ej205?
Thanks!
SpecR1081 is offline   Reply With Quote
Old 07-20-2014, 09:55 AM   #21
samir please
Member#: 367000
im looking at a v5v6 ej207 280hp
samir please is offline   Reply With Quote
Old 07-29-2014, 06:06 PM   #22
saab-story
Member#: 397600
Default 02-03 wrx jdm ej20 swaps
How did the swaps go? people are waiting your saab stories lol.
saab-story is offline   Reply With Quote
Old 08-04-2014, 01:26 AM   #23
option5
Member#: 393856
2004 WRX
Originally Posted by SpecR1081 View Post
Hey all,
Thanks!
What is the name of the shop? I'm looking to possibly do this swap soon.
option5 is offline   Reply With Quote
Old 08-13-2014, 05:16 PM   #24
snoicyellow03wrx
Member#: 398988
Default 03 wrx jdm swap
hello im am looking for help to see if some one has came completed this swap
I have a 03 non avcs impreza wrx I bought the car with a rod knock.
I recently swapped in a jdm ej20 block used all usdm sensors and intake extc. only thing jdm is motor. everything is plugged in all coil packs are receiving 12volts but two cylinders one on each side are not giving a spark and I have used multiple coil pack and plugs.
please if some one would know what is causing this I was told it coud be the ecu but If I used my usdm harness and senors shouldn't I still get a spark? idk please share the knowledge
snoicyellow03wrx is offline   Reply With Quote
Old 09-15-2014, 08:36 PM   #25
Dag Yo
Member#: 369878
2004 Impreza WRX
WR Blue
Default JDM EJ205 into '04 USDM WRX
Hey guys,
I recently got a used JDM motor and ECU to swap into my '04 WRX. I was told it was essentially "plug and play," though that never seems to be the case. Got everything hooked up (except for the AVCS wiring because that's a headache for another day), the engine runs, but I am getting low compression in cylinder 3. The company I bought the motor from did a compression test at their warehouse and showed 150psi on all 4 cylinders.
Right now I have very little power, and my mechanic and I are kinda stuck. I really don't want to have to pull the motor out and ship it back, so I'm hoping someone has some sage advice, perhaps something I've missed or overlooked that could be causing my compression woes.
Dag Yo is offline   Reply With Quote
