Welcome to the North American Subaru Impreza Owners Club Friday February 21, 2020
Old 08-17-2014, 04:45 PM   #901
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by thatsilverwrx View Post
Car should make some nice power now! I'm always tempted to replace my UEL with EL but I'm not sure the gains are worth the money.
How long is this set up sticking around? I'm shocked you didn't go to a rotated set up right from the beginning because it seemed you loved the one you had on your 2011, but I guess that takes away the fun of trying out all new stuff.
I hope so. Should be able to tune it once the weather settles down. It's been hit or miss on the last couple days. Compared to the stock header I think it will definitely be worth it for me.
I'll have this setup at least for the first week of September. Then over the fall/winter I will probably work on figuring something else out. No set plans yet. The motor isn't too crazy so idk how hard I'll push it.
Old 08-18-2014, 07:02 PM   #902
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are a couple more shots of my 2002 WRX Bugeye with the 2004 STI BBS wheels and WRX hood.
Old 08-23-2014, 02:09 AM   #903
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I determined my ID 2000 injectors were installed (by me) with the wrong gaskets. I bought them used and they didn't come with the right ones, so I just used an OEM gasket on the bottom and nothing else. After a little research I found that it needs two gaskets on the bottom and one addition one on the top. I ordered them from ID and they came today so I installed them a little bit ago. Here is a photo.
Left is correct and right is how I had them (incorrect). I noticed it because I had some occasional leaks at idle/rest and then I checked and found that the injectors could move up and down considerably (when the rail was bolted down). With all of the correct gaskets in place the injectors can still rotate, but there is no up and down movement. This should help ensure a good seal on both the top (fuel) and bottom (boost) of the injector.
Old 08-23-2014, 01:57 PM   #904
TS7XREX
Member#: 287450
2011 Impreza WRX
Do you know if this is with all ID injectors? The 1000s specifically. I don't think I did this....
TS7XREX is offline   Reply With Quote
Old 08-23-2014, 02:01 PM   #905
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No. That is a different injector core. The seals will be much more like the OEM Subaru ones with the ID1000. I think the ID2000 may be the only ones like this but I'm not positive.
Old 08-28-2014, 09:24 AM   #906
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I bought a cheap ELM Bluetooth adapter in an attempt to run the Torque app on my Bugeye. It wouldn't log live data and I spent the day yesterday trying to figure it out. I eventually have come to the conlusion that it is due to the Carberry ECU ROM. The hardware and app works perfectly on my 2012 Forester. A few others with Carberry have noted the same thing. So far I don't know of any workaround.
http://forums.nasioc.com/forums/show....php?t=2660385
Resolved: Carberry ECU ROM doesn't have the same PID's as normal, so it connects, but won't read the realtime data.
The ELM Bluetooth adapter and Torque app work perfectly on my Forester.
Old 08-28-2014, 09:25 AM   #907
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I thought my boost gauge was broken (ProSport EVO). It was ready low (vs. the ECU sensor) for a while and then it just stopped reading at all. Just showing 0 all the time.
I figured it was a dead sender, but last night I found that the inline filter was broken completely in half! Big boost leak there! Didn't notice because I'm on speed density.
I replaced it with a straight fitting and now the gauge is working perfectly. Turned the MBC down a little because boost went up a bit now that the leak source has been fixed.
Old 08-28-2014, 10:49 AM   #908
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Old 08-28-2014, 11:21 AM   #909
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, it wasn't an MBC issue, it wasn't a temp change issue, it was a nice big boost leak. LOL.
Old 08-28-2014, 02:57 PM   #910
06rexLTD
Member#: 281793
2004 STi
i had this issue with my Fuel Injector Clinic 1100's - upon start up it sprayed fuel out from the tgvs - so with fic1100s this is also necessary just thought id add that in here for anyone who may stumble across it.
06rexLTD is offline   Reply With Quote
Old 08-28-2014, 03:50 PM   #911
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Good to know! I didn't really even think about it when installing mine, and it wasn't a real obvious leak (no fuel spraying all over), so I didn't pick up on it right away.
Old 08-28-2014, 04:01 PM   #912
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's a quick speedo video with the EL header installed:
Old 08-28-2014, 07:01 PM   #913
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
jeez i hope that doesn't happen to my prosport evo filter. i've got mine tucked under the fuel lines, i'd never even notice until it was too late. *runs outside to inspect filter* lol
Mr. Lin is offline   Reply With Quote
Old 09-04-2014, 09:57 AM   #914
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Weight reduction since the last time at the track:
Removed all speakers: 5lbs
Swapped to WRX hood: 20lbs
Swapped to 04 STI wheels: 21lbs
Swapped to EL header: 10lbs
Removed front sway bar: 7lbs
Removed rear sway bar: 10lbs
Removed rear bumper beam: 30lbs
Removed scissor jack and tools: 6lbs
Removed trunk liners: 3lbs
Total weight saved: 112lbs
Weights are based on what I could find online. I didn't actually weigh anything myself...
Old 09-04-2014, 10:01 AM   #915
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I did a few last minute things last night. Swapped the front right strut (from wagon to sedan). Front left was already sedan so the mismatch was making the camber way off between sides. Then I removed the rear sway bar.
Later in the evening I removed the rear bumper beam. It was a huge pain. I broke all the plastic clips and half of the bolts. Ended up having to cut them off. Tight space so I cut the bolt heads into 1/4's and then snapped them off.
After all that I noticed a transmission fluid smell. Look under and find a huge puddle. Apparently I pulled the axle out of the transmission while swapping the strut and then it leaked a bunch out. I put the axle back in, then did a full drain and fill on the tranny.
Looking forward to the track this weekend. I am hoping all goes well and I can put down a better time than last time!
Old 09-04-2014, 10:35 AM   #916
Ultimateone
Member#: 48025
17 BMW M2
AW
Good luck dude!
Ultimateone is offline   Reply With Quote
Old 09-04-2014, 10:36 AM   #917
mkvaron
Member#: 326317
2011 WRX hatch
SSM
Love the weight reduction haha! That bumper been looked like a PITA to remove.
mkvaron is offline   Reply With Quote
Old 09-04-2014, 11:45 AM   #918
Augstar
Member#: 354389
2015 WRX Limited
Galaxy Blue
May the grip be with you.....
Sent from my iPhone using NASIOC
Augstar is offline   Reply With Quote
Old 09-04-2014, 01:21 PM   #919
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Ultimateone View Post
Good luck dude!
Yes, very much so. Very, very rusty.
Thanks. Looks like high's in the low 70's this weekend.
Old 09-04-2014, 03:17 PM   #920
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Post/text updates throughout the weekend. Curious to see how this thing does!
Matt Beenen
Engineering
Old 09-04-2014, 03:41 PM   #921
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Matt Beenen
Engineering
Are you going to run yours? We could race!
Old 09-04-2014, 03:42 PM   #922
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
How much do you think it weighs now?
Almost to the 2800's maybe?
RavensFan7 is offline   Reply With Quote
Old 09-04-2014, 03:44 PM   #923
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Doubt it unless maybe the gas tank is on E. Probably around 3,000 or a little under with half a tank of fuel and no driver.
Old 09-04-2014, 03:49 PM   #924
RavensFan7
Member#: 346388
SRP
Hmm, I thought the bugeyes were 3,000 from factory?
Although, I did forget you have the 6 speed stuff, so that probably added a bunch. Good job on the weight reduction though....110+ lbs is a lot!
Old 09-04-2014, 03:59 PM   #925
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This is what is posted on Cars 101:
  • 2002 WRX Sedan 5MT: 3085lbs
  • 2004 WRX Sedan 5MT: 3085lbs
  • 2004 STI Sedan 6MT: 3263lbs
So if we'd assume the STI weight is basically what my car is (GD chassis with 2.5L and 6MT) and I weigh in at 29XXlbs, then that would say I've pulled out 200-300lbs total. I had many other things pulled out prior to going to the track before:
  • Spare tire
  • Trunk floor
  • AC compressor
  • AC condenser
  • Front bumper beam
  • Front U brace
  • Undertray
  • Fender liners
  • Fog lights
  • Lightweight battery
  • Radio
  • Aftermarket uppipe
  • Aftermarket downpipe
  • Etc...
