Welcome to the North American Subaru Impreza Owners Club Friday November 27, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 09-06-2014, 12:07 PM   #1
BtSsm
Vendor Sales Rating: (0)
Member#: 400888
Default New product announcement - BtSsm
BtSsm is a combination Android app and OBD2 adapter for 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT
  • Displays realtime data on your Android phone/tablet using the SSM protocol (which gets the good Subaru-specific data)
  • Logs data with great resolution. Logging rate is much better than generic OBDII solutions. Logs can then be emailed/shared to yourself or your tuner
  • Allows you to place and resize gauges of your choice on the display
  • Monitors for knock events (when app is running), and captures all of your selected fields at that point in time (great for tweaking timing tables)
  • Shows you Learned Values that your ECU is applying to fuel/timing, as well as the current IAM value
  • Supports user-defined field alerts. For example, you can be alerted if IAM drops, or if certain cylinders misfire, and more
  • No need to carry around your laptop. Just use your phone/tablet!
It consists of an Android App, and a specific piece of hardware:
  • APP: The Android app BtSsm, available on Google Play for $15
Prerequisites: Android phone or tablet, running at least V4.0, with Bluetooth or USB/OTG support
  • HARDWARE ADAPTER: Currently supported adapters are the BtSsm "K" adapter (bluetooth), OBDLink LX (bluetooth), OBDLink MX (bluetooth), KKL cable (usb/otg), Tactrix OP2 cable (usb/otg). These each have their own supported model years and prerequisites, which are too involved to describe here, please see the BtSsm hardware page for more details.
Please visit http://www.btssm.com for more info/ordering. Thank you.
App running on an Android phone - realtime data display
Learned Values - see what fuel/timing corrections the ECU is applying
Capture knock events while app is running. See exactly what was going on at the time of the knock. Great help when you are tuning your timing tables (or send to your tuner).
View your log file in raw format, or render it as a graph
Please visit us at www.btssm.com for more info!
Last edited by BtSsm; 11-25-2015 at 07:13 PM. Reason: updated to include up to 2014 WRX/STi
BtSsm is offline   Reply With Quote
Old 09-06-2014, 12:16 PM   #2
Louie
Member Sales Rating: (48)
Member#: 43393
2014 Audi a6
Daytona Gray
No iPhone capability?
Sent from my iPhone using NASIOC
Louie is offline   Reply With Quote
Old 09-06-2014, 12:42 PM   #3
BtSsm
Member#: 400888
I'm sorry, not at this time. If the product becomes popular, then it should be available at some point.
Old 09-08-2014, 09:00 PM   #4
BtSsm
Member#: 400888
This is the field chooser, where you pick what to monitor in real-time, log, or display as a gauge.
__________________
[SIGPIC][/SIGPIC][B]
[/B] - Android app/Bluetooth adapter. LV, logging, gauges, and more! For 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT
Old 09-09-2014, 12:00 AM   #5
DjKlown
Member Sales Rating: (11)
Member#: 167104
Pretty impressive.. any info on 04 wrx auto available. .
DjKlown is offline   Reply With Quote
Old 09-09-2014, 09:08 AM   #6
BtSsm
Member#: 400888
Thanks. It's not currently available for the 04 wrx, but I'll log your request, and if it becomes available, I'll be sure to pm you.
__________________
Old 09-14-2014, 11:16 PM   #7
BtSsm
Member#: 400888
Graphing of logs was just added to the app itself! An update was just pushed to Google Play.
Tap anywhere on the graph, and it will display the values for each field.
__________________
Old 09-17-2014, 04:05 PM   #8
BtSsm
Member#: 400888
__________________
Old 09-22-2014, 01:49 PM   #9
enduroxt
Member#: 310796
05 obxt
Bump for a good vendor. He is serious and has done a great job. It is awesome to use this app without having to carry around a laptop! Pull LVs whenever you want, get warning whenever there is a knock event, get real fast refresh rate, log data as you would with RR by hitting the rear defrost button. And all that on your phone! I think this is priceless.
enduroxt is offline   Reply With Quote
Old 09-28-2014, 08:23 PM   #10
BtSsm
Member#: 400888
Error code retrieval feature has just been added to BtSsm
On the main menu click "Codes". The update has just been published to Google Play.
__________________
Old 10-03-2014, 04:50 PM   #11
BtSsm
Member#: 400888
Attached is a sample log file from BtSsm with 19 fields that shows the sampling rate is high compared to generic obd2 logging. No drop-outs. Great when you're tuning, or send them to your tuner.
__________________
Old 10-04-2014, 06:08 PM   #12
Paul
Member Sales Rating: (42)
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Pretty cool. I'd buy one if worked on a 2003 jdm STI and on a IPhone
Old 10-04-2014, 09:24 PM   #13
BtSsm
Member#: 400888
Thx. Will notify you if such an application and device become available.
__________________
Old 10-06-2014, 12:40 PM   #14
BtSsm
Member#: 400888
FYI - just published an update to Google Play that includes a new "ECU reset" feature. It is located inside the Trouble Codes dialog.
__________________
Old 10-09-2014, 01:57 PM   #15
BtSsm
Member#: 400888
Here's a screenshot of the new "Dyno Chart Estimate" feature. It is a bit experimental at this point, but with some refinement it could be a helpful piece of BtSsm.
An update with this new feature has just been published on Google Play.
__________________
Old 10-12-2014, 12:30 PM   #16
BtSsm
Member#: 400888
New update V1.0.9 just published to Google Play includes:
  • added metric unit support
  • added to settings: "snap-to-grid" gauge movement
  • added to log graph: share button
  • miscellaneous enhancements
__________________
Old 10-20-2014, 01:51 PM   #17
BtSsm
Member#: 400888
A new update of BtSsm has just been published to google play
  • added speed correction option in settings (affects only BtSsm app)
  • when sharing LV, it is now an image rather than text (improved appearance)
  • renamed VVT fields to include "int" or "exh" as needed
Many thanks!
__________________
Old 10-22-2014, 04:31 PM   #18
BtSsm
Member#: 400888
Hey all - BtSsm model coverage should now extend to the following model years:
05-08 LGT (was 05-06)
06-08 WRX (was 06-07)
04-08 STI (was 04-07)
04-08 FXT (was 04-06)
05-08 OBXT (was 05-06)
__________________
Old 10-25-2014, 11:47 PM   #19
BtSsm
Member#: 400888
An update was just published to Google Play:
  • Expanded model-year coverage to 2009
  • Added STi-style gauge option:
  • Revised existing LGT-style gauge option:
  • To protect gauges from inadvertent movement, a long-press is now needed to move them
__________________
Old 10-28-2014, 08:50 PM   #20
BtSsm
Member#: 400888
FYI - some have had success using the BtSsm adapter to do RomRaider logging from a laptop (provided that the laptop has bluetooth support, which can usually be added if it doesn't have it already). You need to create an outgoing BT connection from your laptop, pair it with your BtSsm device, assign a virtual com port, then you should be able to use that com port in RR.
__________________
Old 11-03-2014, 11:03 AM   #21
BtSsm
Member#: 400888
Happy November!
Announcing a price reduction for the BtSsm adapter: as of today, it is now available for $99 (includes shipping to US). The Android app remains priced at $15
Also, an update to the app is being pushed out to Google Play today. It includes:
  • new feature: throttle-triggered logging via long press of rec button (suggested by snow05gtRI)
  • enhancement: added Car/ECU info to LV (suggested by xt2005bonbon)
  • enhanced appearance of LV
  • append log filenames with "_knock" when a knock is detected during a log (suggested by snow05gtRI)
  • enhanced knock notification logic (bug found by xt2005bonbon)
  • added field VVT-Exhaust to ADM 2.0 GT (suggested by bigBADbenny)
__________________
Old 11-13-2014, 02:05 PM   #22
BtSsm
Member#: 400888
Just published an update to Google Play (should be available within a couple of hours):
  • Added widgets for 0-60mph and 0-100kmh. Located at bottom of field list.
  • Added field for Fuel pump duty cycle (%). Located in field list.
  • Field "Fuel Learn (%)" is now based on a higher resolution value
  • Formatting enhancements when sharing an LV
  • Also made it an option to have the recently added "glow" effect to the gauges, since it seems as though it doesn't display properly on some devices. Located in "Settings/Gauge glow effect"
__________________
Old 11-21-2014, 09:46 AM   #23
BtSsm
Member#: 400888
An update to the BtSsm app was just published to Google Play.
  • updated to support 2002+ WRX with 16-bit ecu
  • updated to be compatible with Android 5 (Lollipop)
  • bug fixed where sometimes switching vehicles could reset field selections (discovered by bonbon)
__________________
Old 11-21-2014, 10:16 AM   #24
Perscitus
Member#: 378214
Please PM or post when support is added (unless already there) for 2010+ Legacy/Liberty/Outback and 2015 WRX. Thanks.
Perscitus is offline   Reply With Quote
Old 11-21-2014, 11:49 AM   #25
BtSsm
Member#: 400888
pm sent.
__________________
